Public iPerf3-Server speedtest.wtnet.de upgrade to 40Gbit
Hey guys,
some of you may know me from LEB as "fLoo". I'm running the public speedtest server "speedtest.wtnet.de". We've successfully upgraded it to 40 Gbit. It is located near Hamburg/Germany. I'd be happy to hear results from you to improve on them.
https://speedtest.wtnet.de
Thanks for your time!
Florian
  • No, I didn't knew that such server or person even existed. Thank you for letting me know. 40 Gbps iperf is better than 0 Gbps.
    Thanked by (2)uniquoo Janevski
  • wget -4 -O /dev/null http://speedtest.wtnet.de/files/10000mb.bin
    --2022-04-11 13:56:57-- http://speedtest.wtnet.de/files/10000mb.bin
    Resolving speedtest.wtnet.de (speedtest.wtnet.de)... 213.209.106.95
    Connecting to speedtest.wtnet.de (speedtest.wtnet.de)|213.209.106.95|:80... connected.
    HTTP request sent, awaiting response... 404 Not Found
    2022-04-11 13:56:57 ERROR 404: Not Found.
    Thanked by (1)uniquoo
    seems to be 404?
  • edited April 2022
    Thanks for letting me know. I'm in the process of generating these files now.
    Update: Should be fixed now.
    from Stockholm
    [SUM]   0.00-10.00  sec  4.59 GBytes  3.94 Gbits/sec  206819             sender
    [SUM]   0.00-10.02  sec  4.56 GBytes  3.91 Gbits/sec                  receiver
  • From hosthatch STO,
    iperf3 -c speedtest.wtnet.de -p 5209 -6
    [ ID] Interval           Transfer     Bitrate         Retr
    [  5]   0.00-10.00  sec  1.21 GBytes  1.04 Gbits/sec    0             sender
    [  5]   0.00-10.02  sec  1.21 GBytes  1.04 Gbits/sec                  receiver
    iperf3 -c speedtest.wtnet.de -p 5209 -6 -R
    [  5]   0.00-10.02  sec  1.21 GBytes  1.03 Gbits/sec    0             sender
    [  5]   0.00-10.00  sec  1.20 GBytes  1.03 Gbits/sec                  receiver
    Anybody with >=10gbps connection? :#
  • Thanks for your public service! There are not enough iperf public servers out there especially ones to test speeds higher than 1Gbps. So thank you!
  • XenicXenic OG
    edited April 2022
    @dosai said:
    From hosthatch STO,
    🇩🇪 Norderstedt wilhelm.tel iPerf3 Server:
    [SUM]   0.00-10.00  sec  9.81 GBytes  8.42 Gbits/sec  20627             sender
    [SUM]   0.00-10.00  sec  9.78 GBytes  8.40 Gbits/sec                  receiver
    🇩🇪 Düsseldorf myLoc iPerf3 Server:
    [SUM]   0.00-10.00  sec  19.5 GBytes  16.8 Gbits/sec  726             sender
    [SUM]   0.00-10.00  sec  19.5 GBytes  16.8 Gbits/sec                  receiver
    Both were tested on a Hetzner Cloud Instance located in 🇩🇪 Nuremberg (which seems to have a 20 Gbit/s Uplink Shared)
    Thanked by (3)dosai uniquoo CamoYoshi
  • Nice server there.
    [SUM]   0.00-10.00  sec  5.76 GBytes  4.95 Gbits/sec  22286             sender
    [SUM]   0.00-10.01  sec  5.73 GBytes  4.92 Gbits/sec                  receiver
    Good connection with Brazil, I get 100% of my download speed 500mbps even with the route passing through 3 continents.
    Upload is fine too, I have 125mbps upload.
  • hi @uniquoo
    could u have a look at the iperf instances ? seems only 5200 and 5202 are working :3
  • @ThomasP said:
    hi @uniquoo
    iPerf intances are restarted every night. Do you still have problems reaching other ports ?
  • @uniquoo said:
    @ThomasP said:
    hi @uniquoo
    Hi yes
    right now only 5200 is working.
    Thanked by (1)MannDude
  • DanielDaniel OG
    edited April 2022
    @dosai said: Anybody with >=10gbps connection? :#
    I tried it with HostHatch Amsterdam (which is theoretically on a 40Gbps connection as per https://docs.hosthatch.com/features/) but I "only" got 2.45Gbps with iperf3.
    Thanked by (2)dosai uniquoo
    yeah i also got an AMS HostHatch it never realy goes above 3Gbps.
    [SUM]   0.00-10.00  sec  5.03 GBytes  4.32 Gbits/sec  395001             sender
    [SUM]   0.00-10.01  sec  4.71 GBytes  4.04 Gbits/sec                  receiver
    [SUM]   0.00-10.01  sec  10.3 GBytes  8.85 Gbits/sec  279588             sender
    [SUM]   0.00-10.00  sec  10.3 GBytes  8.83 Gbits/sec                  receiver
  • CatixsCatixs Hosting Provider
    We can help you with a test or monitor point at Tampa, FL.
    Great project after all.
  • I'm currently checking into tunables and routing issues with out backbone. Please give me some time to so i can hopefully fix this. Within Germany I've seen tests up to 19,8 Gbit so far. Yet not close enough to 40G. Sorry. Will update this post once i can update you with hopefully good news on this.
  • 04/24 01:54:32 [NOTICE] Downloading 1 item(s)
    [#22da92 5.3GiB/9.7GiB(55%) CN:1 DL:257MiB ETA:17s]
    [ 5] 0.00-10.04 sec 2.68 GBytes 2.29 Gbits/sec 0 sender
    [ 5] 0.00-10.00 sec 2.67 GBytes 2.30 Gbits/sec receiver
    It's a netcup box . :)
  • Update:
    It looks like everyone is testing against one single Port. Because iPerf3 is single threaded i'd like to ask you to test the throughput the following way:
    iperf3 -c speedtest.wtnet.de -s t1 -p 5301 -P 2 -4 &
    iperf3 -c speedtest.wtnet.de -s t2 -p 5302 -P 2 -4 &
    iperf3 -c speedtest.wtnet.de -s t3 -p 5303 -P 2 -4 &
    iperf3 -c speedtest.wtnet.de -s t4 -p 5304 -P 2 -4 &
    I was able to verify that i was able to achieve 100G locally using 4 ports (25g each using 2 threads).
  • have u tuned the TCP Settings (rmem wmem congestion_control etc..) on the Box ?
    Could help to increase the Speeds
    Yep. According to ESNETs advice for 40/100g interfaces
  • PureVoltagePureVoltage Hosting ProviderOG
    From NY seem to only be able to push around 3Gbps tried using the above commands looks like it has a typo in it.
    iperf3 -c speedtest.wtnet.de -T t1 -p 5301 -P 10 -4 &
    iperf3 -c speedtest.wtnet.de -T t2 -p 5302 -P 10 -4 &
    iperf3 -c speedtest.wtnet.de -T t3 -p 5303 -P 10 -4 &
    iperf3 -c speedtest.wtnet.de -T t4 -p 5304 -P 10 -4 &
    Their site shows with a ; at the end also but that invoked a syntax error.
    Running the above with multiples doesn't seem to help our speeds.
    We will have a 40g system online for a bit here if someone wants to test it out have fun.
    iperf3 -c nyc.iperf3.purevoltage.com -p 5201 -P16 -4
    [SUM] 0.00-10.00 sec 11.0 GBytes 9.44 Gbits/sec 275 sender
    [SUM] 0.00-10.00 sec 11.0 GBytes 9.41 Gbits/sec receiver
  • @uniquoo said: I'd be happy to hear results from you to improve on them.
    I've tested from my home connection (Vodafone Cable with 1 Gbit/s down, 50 Mbit/s up) and I get about ~850 Mbit/s down and 50 Mbit/s up while I get close to 1 Gbit/s down with Clouvider's iperf servers in AMS and FRA. But that's likely due to the peering between wilhelm.tel and Vodafone?
    HOST: nanopineo2        Loss%   Snt   Last   Avg  Best  Wrst StDev
      1. AS3209   2a02:8108:1bc0:1fc4:10:18ff:fe41:e154                              0.0%    50    1.1   1.4   0.7   2.3   0.4
      2. AS3209   2a02:8108:1:37::1                                                  0.0%    50    8.5   9.9   7.2  12.2   1.1
      3. AS3209   2a02:8100:6:2::100:5d1                                             0.0%    50    7.0  10.3   6.8  34.2   3.8
      4. AS3209   2a02:8100:6:2::90a                                                36.0%    50   10.2  10.2   8.3  15.1   1.2
      5. AS3209   2a00::afff:0:c02:c02:1                                            78.0%    50   16.0  11.3   8.9  16.9   2.7
      6. AS3209   2a02:908::54:1                                                    84.0%    50   18.6  18.2  15.7  24.6   2.8
      7. AS3209   2a02:908::54:1                                                    74.0%    50   15.7  17.5  15.7  19.1   1.2
      8. AS???    de-cix.b6695.Kruemelmonster.ipv6.wtnet.de (2001:7f8::3e47:0:2)    56.0%    50   24.1  18.2  15.5  24.1   2.0
      9. AS15943  b6969.Herr-von-Boedefeld.ipv6.wtnet.de (2a02:2028:ff00::ffff:22)  46.0%    50   16.5  17.4  15.1  19.7   1.0
     10. AS15943  b40069.Graf-Zahl.ipv6.wtnet.de (2a02:2028:ff00::ffff:115d)        46.0%    50   22.7  23.8  22.2  29.1   1.6
     11. AS15943  b379.Bert.ipv6.wtnet.de (2a02:2028:ff00::3d:1)                    18.0%    50   23.3  25.2  22.3  29.9   2.1
     12. AS???    ???                                                               100.0    50    0.0   0.0   0.0   0.0   0.0
  • debaserdebaser OG
    edited May 2022
    Looks like they're peers so should be good?
    I'm getting around 940/940 Mbps on my home connection at the moment. That's in the Netherlands, but my ISP has IX peering with WTNet too. Best I got from this speedtest server was ~ 16 Gbps on a 40 Gbps connection.
    traceroute to speedtest.wtnet.de (213.209.106.95), 64 hops max, 72 byte packets
     3  195-190-228-64.fixed.kpn.net (195.190.228.64)  4.624 ms  3.090 ms  2.706 ms
     4  * * *
     5  nl-ix.v7.b34307.Kermit.ipv4.wtnet.de (193.239.118.187)  5.183 ms  4.135 ms  3.917 ms
     6  b31040.bibo.ipv4.wtnet.de (84.46.113.252)  13.330 ms  11.986 ms  11.192 ms
     7  b54.graf-zahl.ipv4.wtnet.de (84.46.112.65)  12.148 ms  12.376 ms  11.929 ms
     8  b379.bert.ipv4.wtnet.de (84.46.112.61)  13.413 ms  12.552 ms  12.018 ms
     9  * * *
    10  *^C
  • edited May 2022
    To be honest with you, i've yet to find the bottleneck which causes the problems described. I've tested locally with multiple streams (using multiple ports and so multiple iPerf3-daemons on multiple cores) and was able to achieve 100 Gbit consistently.
    Right now i'm debugging with our backbone department to rule out anything between the server and our core router and/or between the core and the endcustomer. Not that of an easy task.
    Tested from our speedtest:
    [SUM] 0.00-10.00 sec 5.85 GBytes 5.03 Gbits/sec 8 sender
    [SUM] 0.00-10.08 sec 5.23 GBytes 4.46 Gbits/sec receiver
    iperf3 -c nyc.iperf3.purevoltage.com -p 5201 -P16 -4 -R
    [SUM] 0.00-10.09 sec 3.19 GBytes 2.71 Gbits/sec 36574 sender
    [SUM] 0.00-10.01 sec 3.13 GBytes 2.68 Gbits/sec receiver
    Interesting, yeah it seems odd on the speeds. I know someone else did some tests and got 18Gbps in PHX.
