CrownCloud - Miami, FL - KVM - 3 GB RAM - 50 GB SSD - $30/year or 35/year
Hello,
We've been around for 10+ years and own & colocate our hardware and networking gear and have our own ARIN issued IPs for our US based locations.
We've added in some new hardware to our Miami, Florida, USA location and would like to share an offer with you ![]()
Our Site: https://crowncloud.net/
Datacenter/Test IPs
Quadranet, Miami, Florida, USA
Test IPv4: 173.44.32.10
Test IPv6: 2607:ff48:aa83:1a9d::1
Hardware
CPU: Dual Intel E5-2697 v4
RAM: 256GB RAM DDR4 ECC
Disks: 8x SSDs in RAID10
Uplinks: 10 Gbit/s / VMs set at 1 Gbit/s
| Plan | RAM | Disk | Bandwith | CPU Cores | Snapshot Slot | VPS Cost | Order |
| 1 | 3 GB | 50 GB SSD | 1 TB/month | 2 Cores Fair-Share | 1 | $35/year | Order |
| 2 | 3 GB | 50 GB SSD | 1 TB/month | 2 Cores Fair-Share | 0 | $30/year | Order |
Plan Information
- Both plans are KVM based
- Only difference is the snapshot slot being included or not, you can upgrade / addon the snapshot slot anytime you wish to.
Operating systems:
- We've got 1-click install templates for AlmaLinux 8/9, Rocky Linux 8/9, CentOS 7/Stream 8, Debian 10/11, various Ubuntu(s) upto 22.04, Windows 2012/2016/2019/2022.
- ISOs for various operating systems and also including Netboot.xyz, GRML and so on, Template for Debian 12 coming shortly.
Also do note, We do not provide licenses for Windows, the customer is responsible for the license on the machine.
Other information
1. SSH Key insert during install support is included
2. In-control panel rDNS support is included
3. Custom ISOs can be requested to be mounted onto your VPS for free as well via ticket.
4. Labels can be setup on VPSes (https://wiki.crowncloud.net/?How_to_set_a_label_on_a_VPS_in_CrownPanel)
5. 2Factor Authentication available in billing/client-area and VPS control panel (https://wiki.crowncloud.net/?2factor_authentication_in_crownpanel)
6. A Name can be setup on a snapshot (https://wiki.crowncloud.net/?How_to_Add_Name_to_Snapshots_in_CrownPanel)
7. CPU Passthrough can be enabled via control panel (for nested virtualization etc) (https://wiki.crowncloud.net/?how_to_enable_cpu_passthrough)
8. More Information about snapshot slots can be found here (https://wiki.crowncloud.net/?How_to_use_Snapshots_in_CrownPanel)
9. Port 25 is openable on request, you may contact us before purchasing with your use case if you want a confirmation/pre-approval that port 25 would be opened after purchasing as well
Point #9 was added on 14/06/2023 (dd/mm/yyyy) as I had forgotten to add this line earlier, customers who have previously purchased the service have been contacted with this information as well.
What?
Companies at LET/LES usually want to look older not younger
Hehe forgot to update that bit -- updating now
Baltimore was a pretty cool location back then, pretty bummed the datacenter just disappeared/went all sorts of unstable back then.
anyone got it share benchmark pls
I've run a YABS now
Is there any link for the offer? I cannot find it on the website.
https://crowncloud.net/clients/index.php?rp=/store/specials/mia-3g-50g-2c-1t-0s-ssd-y
https://crowncloud.net/clients/index.php?rp=/store/specials/mia-3g-50g-2c-1t-1s-ssd-y
ok I see now, the order links are white and hidden, I keep looking for green links
Change to dark theme if you are not using it already
already am
I need to open port 25 , is it open?
i need cheap vps year payment .
yes it is, I am attempting to setup exim4 currently as a secondary mx and the port is open
The port is open able on request, if you are unsure if it'll be approved or not, you can drop in a ticket to sales/billing before ordering and we'll review it and let you know
Debian 12 should be available on 2023-06-10 according to this:
https://lists.debian.org/debian-devel-announce/2023/04/msg00007.html
How long after will it take for CrownCloud to offer an option of Debian 12 on the order form?
in ~24 hours or lesser, the template was just built an hour ago and needs a bit of testing, it'll be rolled out later today
aand done, Debian 12 is on the order page, reinstall menu and ISO menu as well
