OVH KS-LE for transfer (ie/eu account)
 ehab
                Content Writer
ehab
                Content Writer
            hi,
i have KS-LE for transfer
Next Renewal: Before 24 July 2023 (€12.99 excl. VAT at €16.10 VAT incl.)
Hardware Info:
CPU-Intel Xeon E3-1245v2 - 4c/8t - 3.4 GHz/3.8 GHz
RAM-16 GB 1333 MHz
Data disks-2 x 480 GB HDD SATA Soft RAID
Ipv4 100/1000Mbps
i assume - Ipv6 1000/1000Mbps  -
asking price €16.10 + you pay paypal fees.
its easy to transfer servers on same (ie/eu account) , all i need is you OVH handle "nice" e.g : LLNNNNN-ovh i change contacts and should be done in 5 min.
let me know if you are interested, thanks hostaspace for template.
ehab
#                     v2023-04-23                    #
Sun Jun 18 15:16:00 UTC 2023
Uptime     : 11 days, 18 hours, 12 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
CPU cores  : 8 @ 3800.000 MHz
RAM        : 15.5 GiB
Swap       : 2.0 GiB
Disk       : 437.7 GiB
Kernel     : 5.15.107-2-pve
VM Type    : NONE
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH ISP
Country    : France
Read       | 194.51 MB/s  (48.6k) | 281.05 MB/s   (4.3k)
Write      | 195.03 MB/s  (48.7k) | 282.53 MB/s   (4.4k)
Total      | 389.55 MB/s  (97.3k) | 563.59 MB/s   (8.8k)
Read       | 245.95 MB/s    (480) | 261.17 MB/s    (255)
Write      | 259.02 MB/s    (505) | 278.56 MB/s    (272)
Total      | 504.97 MB/s    (985) | 539.73 MB/s    (527)
Clouvider       | London, UK (10G)          | 95.3 Mbits/sec  | 509 Mbits/sec   | 4.08 ms
Scaleway        | Paris, FR (10G)           | 95.4 Mbits/sec  | 491 Mbits/sec   | 4.16 ms
NovoServe       | North Holland, NL (40G)   | 95.3 Mbits/sec  | 926 Mbits/sec   | 5.92 ms
Uztelecom       | Tashkent, UZ (10G)        | 37.5 Mbits/sec  | 165 Mbits/sec   | 99.1 ms
Clouvider       | NYC, NY, US (10G)         | 34.1 Mbits/sec  | 29.3 Mbits/sec  | 76.3 ms
Clouvider       | Dallas, TX, US (10G)      | 28.8 Mbits/sec  | 332 Mbits/sec   | 114 ms
Clouvider       | Los Angeles, CA, US (10G) | 23.0 Mbits/sec  | 41.3 Mbits/sec  | 136 ms
Single Core     | 743
Multi Core      | 2591
Full Test       | https://browser.geekbench.com/v6/cpu/1641041
$ lshw -class disk
  *-disk:0
       description: ATA Disk
       product: INTEL SSDSC2KB48
       physical id: 0
       bus info: scsi@0:0.0.0
       logical name: /dev/sda
       version: 0132
       serial: PHYF003502XV480BGN
       capabilities: partitioned partitioned:dos
       configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096 signature=ceaf83fe
  *-disk:1
       physical id: 1
       bus info: scsi@1:0.0.0
       logical name: /dev/sdb
       version: 0132
       serial: PHYF00260CQ7480BGN
       configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096 signature=6e6333fa
$ smartctl -a /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107-2-pve] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Intel S4510/S4610/S4500/S4600 Series SSDs
Device Model:     INTEL SSDSC2KB480G8
Serial Number:    PHYF003502XV480BGN
LU WWN Device Id: 5 5cd2e4 1521b435a
Firmware Version: XCV10132
User Capacity:    480,103,981,056 bytes [480 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Jun 18 15:34:13 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x05) Offline data collection activity
                    was aborted by an interrupting command from host.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (  32) The self-test routine was interrupted
                    by the host with a hard or soft reset.
Total time to complete Offline
data collection:        (    2) seconds.
capabilities:            (0x79) SMART execute Offline immediate.
                    No Auto Offline data collection support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:    (   1) minutes.
Extended self-test routine
recommended polling time:    (   2) minutes.
Conveyance self-test routine
SCT capabilities:          (0x003d) SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       18932
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       42
170 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
174 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       40
175 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       2621 (42 65535)
183 SATA_Downshift_Count    0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error_Count  0x0033   100   100   090    Pre-fail  Always       -       0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
190 Drive_Temperature       0x0022   063   060   000    Old_age   Always       -       37 (Min/Max 22/40)
192 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       40
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       37
197 Pending_Sector_Count    0x0012   100   100   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       1647254
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       2109
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       56
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       1135868
232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
233 Media_Wearout_Indicator 0x0032   098   098   000    Old_age   Always       -       0
234 Thermal_Throttle_Status 0x0032   100   100   000    Old_age   Always       -       0/0
235 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       2621 (42 65535)
241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       1647254
242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       2102093
243 NAND_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       3595273
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     18328         -
# 2  Short offline       Completed without error       00%     18326         -
# 3  Short offline       Completed without error       00%     18326         -
# 4  Short offline       Completed without error       00%     18324         -
# 5  Short offline       Completed without error       00%     18321         -
# 6  Short offline       Completed without error       00%     18320         -
# 7  Short offline       Completed without error       00%         2         -
# 8  Short offline       Completed without error       00%         2         -
# 9  Short offline       Completed without error       00%         1         -
#10  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
$ smartctl -a /dev/sdb
Serial Number:    PHYF00260CQ7480BGN
LU WWN Device Id: 5 5cd2e4 15219ff20
Local Time is:    Sun Jun 18 15:34:57 2023 UTC
Offline data collection status:  (0x02) Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0) The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       23050
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       23
174 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       22
175 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       2615 (23 65535)
190 Drive_Temperature       0x0022   062   059   000    Old_age   Always       -       38 (Min/Max 23/41)
192 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       22
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       38
225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       122878
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       542
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       94
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       1382942
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       0
235 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       2615 (23 65535)
241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       122878
242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       2010273
243 NAND_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       863529
No Errors Logged
# 1  Short offline       Completed without error       00%     22446         -
# 2  Short offline       Completed without error       00%     22444         -
# 3  Short offline       Completed without error       00%     22444         -
# 4  Short offline       Completed without error       00%     22442         -
# 5  Short offline       Completed without error       00%     22439         -
# 6  Short offline       Completed without error       00%     22438         -
# 7  Short offline       Completed without error       00%         3         -
#10  Short offline       Completed without error       00%         1         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
it should be SSD my friend
Rotation Rate: Solid State Devicefirst time i read that .. all the time i was thinking its HDD.
so then @ariq01 you are right ... should i change it to SSD ? can't edit now.
