Okay so I've worked on TYOC040 probably way too long and it just hit me. I don't know if you guys remember but I said something weird is going on with the disks because a bunch of LVMs are missing and it was fixed and has been working/appears as it's all fine. Then I was thinking about TYOC002S and how that's also acting a lot different in terms of usage patterns for the region and finally thought "wait, there's no way up to 40% of the people are offline with missing LVMs because ...? No, but then for how many tickets we've been getting about it enough people would have mentioned they did that since it's a pretty important thing to mention, right?" Well I don't know, maybe some people did but I'd say we got pretty much every type of ticket possible for this, from not pinging, GFW concerns, VPS is offline, doesn't work, it's been down for 1 day, it's been down for 2 days and so on, outage report, and so on, over and over.
And then I actually went through and checked every single one.
Yep, turns out it is. It looks like what happened was at some point in time, everything was normal/fixed. Then, a disk dropped off (it timed out.) So online VMs would have seen I/O errors and usually what would happen is people would report that, or make a ticket saying they have important data, etc.
But this is Tokyo and the use case is different. What would cause 40% of the LVMs to just disappear? Make your guess now and remember, this is logs from just about 40% of virtual servers on a single node.
24/09/2022 03:43 AM Reinstall OS
01/09/2022 2:32 AM Reinstall OS
28/08/2022 09:21 PM Boot
28/08/2022 09:16 PM Reinstall OS
20/08/2022 04:48 AM KVM reconfigure
20/08/2022 04:45 AM Boot
20/08/2022 04:45 AM Change Boot Order
20/08/2022 04:34 AM Reinstall OS
20/08/2022 04:33 AM KVM reconfigure
15/08/2022 06:21 AM Reinstall OS
15/08/2022 12:54 AM Reinstall OS
14/08/2022 06:33 PM Boot
14/08/2022 06:06 PM Reinstall OS
14/08/2022 10:20 AM Reboot
14/08/2022 10:11 AM Boot
02/08/2022 2:48 AM Reboot
02/08/2022 2:44 AM Reinstall OS
24/08/2022 08:41 AM Reinstall OS
15/08/2022 10:06 PM Reinstall OS
15/08/2022 10:05 PM Disable rescue mode
15/08/2022 10:05 PM Reboot
15/08/2022 10:00 PM Enable rescue mode
15/08/2022 10:00 PM Reboot
28/09/2022 09:35 AM Reinstall OS
26/09/2022 07:31 AM Reinstall OS
23/09/2022 07:02 AM Reinstall OS
23/09/2022 07:01 AM Reinstall OS
23/09/2022 07:00 AM KVM reconfigure
23/09/2022 07:00 AM Disable rescue mode
23/09/2022 07:00 AM Reboot
23/09/2022 06:57 AM Enable rescue mode
23/09/2022 06:57 AM Reboot
23/09/2022 06:56 AM Boot
23/09/2022 06:55 AM Reinstall OS
23/09/2022 06:55 AM Boot
13/09/2022 09:16 AM Boot
13/09/2022 09:15 AM Reinstall OS
09/09/2022 9:29 PM Reinstall OS
08/09/2022 3:37 AM Reinstall OS
03/09/2022 1:17 AM Reinstall OS
02/09/2022 10:46 AM Boot
01/09/2022 4:15 AM Reinstall OS
01/09/2022 4:14 AM Boot
31/08/2022 06:59 AM Reinstall OS
31/08/2022 06:58 AM Boot
31/08/2022 12:10 AM Reinstall OS
31/08/2022 12:10 AM Boot
23/08/2022 01:47 AM Reinstall OS
22/08/2022 10:01 AM Boot
22/08/2022 10:01 AM Reinstall OS
16/08/2022 09:09 AM Boot
15/08/2022 06:02 AM KVM reconfigure
15/08/2022 06:01 AM Reinstall OS
15/08/2022 05:57 AM Boot
15/08/2022 05:54 AM Reinstall OS
01/08/2022 6:14 PM KVM reconfigure
01/08/2022 6:12 PM Boot
01/08/2022 6:12 PM Reboot
06/07/2022 10:19 PM KVM reconfigure
16/08/2022 06:50 AM Reinstall OS
15/08/2022 04:53 AM Reinstall OS
26/08/2022 05:23 AM Reinstall OS
21/09/2022 07:20 AM Reinstall OS
10/09/2022 9:34 PM Reinstall OS
09/09/2022 5:21 AM Reinstall OS
16/08/2022 06:29 AM Reinstall OS
15/08/2022 08:07 PM Reinstall OS
15/08/2022 01:00 AM Reboot
06/07/2022 7:14 AM Reinstall OS
06/07/2022 7:11 AM KVM Change Root Password
20/09/2022 03:34 PM Reinstall OS
20/09/2022 03:33 PM Reboot
11/09/2022 8:08 PM Reinstall OS
27/08/2022 03:22 AM Reinstall OS
27/08/2022 03:20 AM Reboot
22/08/2022 05:52 AM Reboot
19/08/2022 12:00 AM Reboot
14/08/2022 04:01 PM Reinstall OS
14/08/2022 04:00 PM Reboot
14/08/2022 04:00 PM Shutdown
14/08/2022 03:58 PM Reboot
14/08/2022 03:57 PM KVM reconfigure
14/08/2022 03:51 PM Reinstall OS
14/08/2022 03:47 PM Reboot
14/08/2022 03:47 PM Shutdown
14/08/2022 03:40 PM KVM reconfigure
14/08/2022 03:37 PM Reboot
01/08/2022 3:03 PM Reboot
29/09/2022 04:00 PM Reinstall OS
29/09/2022 01:28 AM Reboot
28/09/2022 11:24 PM KVM reconfigure
22/09/2022 04:23 PM KVM reconfigure
22/09/2022 04:23 PM Reinstall OS
22/09/2022 04:20 PM Reboot
20/09/2022 02:31 AM Reinstall OS
08/09/2022 4:06 PM Reinstall OS
30/08/2022 05:07 PM Changed Clock Settings
30/08/2022 05:07 PM Reinstall OS
30/08/2022 05:05 PM KVM reconfigure
30/08/2022 05:04 PM Reinstall OS
28/08/2022 03:54 PM Reinstall OS
28/08/2022 03:53 PM Change Boot Order
28/08/2022 03:52 PM Reboot
28/08/2022 03:50 PM Boot
24/08/2022 05:15 PM Boot
19/08/2022 03:47 PM KVM reconfigure
19/08/2022 03:44 PM Reinstall OS
17/08/2022 03:50 AM Reinstall OS
15/08/2022 03:58 PM Shutdown
15/08/2022 03:55 PM KVM reconfigure
15/08/2022 03:54 PM Reboot
15/08/2022 01:52 AM Shutdown
15/08/2022 01:51 AM Boot
14/08/2022 04:17 PM Shutdown
14/08/2022 04:16 PM Reboot
01/08/2022 5:59 PM Reboot
01/08/2022 5:57 PM Boot
01/08/2022 5:56 PM Shutdown
26/07/2022 12:26 AM Reboot
03/09/2022 10:21 AM Reinstall OS
03/09/2022 10:20 AM KVM reconfigure
03/09/2022 10:17 AM Reinstall OS
20/08/2022 09:38 AM Boot
20/08/2022 09:38 AM Hard Power Off
20/08/2022 09:36 AM Change Boot Order
20/08/2022 09:36 AM Reinstall OS
20/08/2022 09:36 AM Shutdown
20/08/2022 09:29 AM Reinstall OS
16/08/2022 07:37 PM Reinstall OS
16/08/2022 07:37 PM Hard Power Off
09/08/2022 8:47 PM Reinstall OS
08/08/2022 9:22 AM Boot
08/08/2022 9:21 AM Reinstall OS
08/08/2022 9:21 AM Hard Power Off
08/08/2022 9:21 AM Disable rescue mode
08/08/2022 9:21 AM Reboot
08/08/2022 9:20 AM Shutdown
08/08/2022 9:18 AM Enable rescue mode
08/08/2022 9:18 AM Reboot
08/08/2022 8:36 AM Reboot
08/08/2022 8:34 AM Reinstall OS
08/08/2022 8:34 AM Change Boot Order
02/08/2022 9:18 AM Reinstall OS
24/09/2022 11:22 PM Reinstall OS
19/09/2022 07:30 AM Reinstall OS
15/09/2022 03:02 AM Reinstall OS
31/08/2022 09:15 PM Reinstall OS
21/08/2022 06:41 PM Reinstall OS
04/08/2022 8:16 PM Reinstall OS
04/08/2022 8:15 PM Mounted CDROM
04/08/2022 8:14 PM Change Boot Order
04/08/2022 8:13 PM Unmounted CDROM
04/08/2022 8:08 PM Boot
04/08/2022 8:06 PM Mounted CDROM
04/08/2022 8:06 PM Unmounted CDROM
01/08/2022 11:37 PM KVM reconfigure
01/08/2022 8:02 PM Reinstall OS
01/08/2022 7:59 PM Reinstall OS
19/09/2022 02:59 AM Reinstall OS
13/09/2022 05:03 AM Reinstall OS
11/09/2022 11:52 AM Reinstall OS
01/09/2022 6:39 AM Reinstall OS
29/08/2022 08:20 AM Reinstall OS
28/08/2022 04:20 AM Reinstall OS
22/08/2022 06:31 AM Reinstall OS
21/08/2022 06:00 AM Reinstall OS
06/07/2022 8:55 PM Reinstall OS
13/09/2022 09:01 PM Reinstall OS
06/07/2022 4:17 AM Reinstall OS
06/07/2022 3:55 AM Reinstall OS
06/07/2022 3:48 AM Reinstall OS
06/07/2022 3:36 AM Reinstall OS
04/07/2022 4:58 PM Reinstall OS
29/09/2022 07:20 AM Reinstall OS
27/09/2022 09:31 AM Reinstall OS
23/09/2022 08:56 AM Reinstall OS
20/09/2022 03:38 AM Reinstall OS
14/09/2022 07:07 AM Reinstall OS
14/09/2022 06:32 AM Reinstall OS
10/07/2022 5:57 AM Reinstall OS
10/07/2022 5:39 AM Reinstall OS
06/07/2022 9:18 PM Reinstall OS
06/07/2022 8:07 PM Reinstall OS
28/09/2022 05:11 PM Boot
28/09/2022 05:11 PM Shutdown
24/08/2022 01:35 AM Reinstall OS
20/08/2022 03:47 AM Reinstall OS
22/09/2022 10:31 PM Reboot
20/09/2022 06:39 AM Reboot
06/09/2022 6:58 AM Reboot
04/09/2022 8:02 PM Reboot
02/09/2022 10:30 PM Reboot
02/09/2022 10:30 PM Reinstall OS
01/09/2022 9:54 PM Reboot
30/08/2022 09:05 AM Reinstall OS
30/08/2022 09:04 AM KVM reconfigure
30/08/2022 09:03 AM Reboot
30/08/2022 09:02 AM Change Boot Order
30/08/2022 09:01 AM Reboot
25/08/2022 12:38 AM Reboot
25/08/2022 12:38 AM Change Boot Order
21/08/2022 08:17 PM Reinstall OS
19/08/2022 09:31 AM Reboot
17/08/2022 09:32 AM Disable rescue mode
17/08/2022 09:32 AM Reboot
17/08/2022 04:09 AM Enable rescue mode
17/08/2022 04:09 AM Reboot
15/08/2022 09:25 PM Reboot
15/08/2022 09:25 PM Change Boot Order
15/08/2022 09:24 PM Reboot
15/08/2022 03:20 AM Reboot
14/08/2022 11:13 AM KVM reconfigure
14/08/2022 11:11 AM Boot
14/08/2022 11:11 AM Hard Power Off
14/08/2022 11:11 AM Disable rescue mode
14/08/2022 11:11 AM Reboot
14/08/2022 11:08 AM Enable rescue mode
14/08/2022 11:08 AM Reboot
14/08/2022 11:06 AM Reboot
14/08/2022 11:02 AM Reinstall OS
14/08/2022 10:50 AM Reboot
01/08/2022 8:23 PM KVM reconfigure
01/08/2022 8:22 PM Boot
01/08/2022 8:22 PM Shutdown
27/09/2022 06:31 AM Reinstall OS
21/09/2022 05:36 AM Boot
02/09/2022 8:38 PM Boot
20/08/2022 05:06 PM Reinstall OS
20/08/2022 07:46 AM Reinstall OS
20/08/2022 07:44 AM Boot
20/08/2022 07:35 AM Boot
20/08/2022 07:29 AM Reinstall OS
08/07/2022 10:29 PM KVM Change Root Password
07/07/2022 6:38 AM Reinstall OS
25/09/2022 09:14 PM Boot
25/09/2022 09:13 PM Unmounted CDROM
25/09/2022 09:13 PM Reinstall OS
25/09/2022 09:10 PM Boot
25/09/2022 09:10 PM Reboot
19/09/2022 06:02 AM Reinstall OS
19/09/2022 06:00 AM Disable rescue mode
19/09/2022 06:00 AM Reboot
11/09/2022 7:21 PM Reboot
11/09/2022 7:20 PM Enable rescue mode
11/09/2022 7:20 PM Reboot
06/09/2022 4:36 AM Reinstall OS
29/08/2022 01:06 AM Reinstall OS
29/08/2022 01:05 AM Disable rescue mode
29/08/2022 01:05 AM Reboot
29/08/2022 01:03 AM Enable rescue mode
29/08/2022 01:03 AM Reboot
29/08/2022 01:01 AM Reinstall OS
29/08/2022 01:00 AM Reinstall OS
29/08/2022 12:59 AM Reinstall OS
29/08/2022 12:57 AM Reinstall OS
18/08/2022 05:28 PM Reinstall OS
15/08/2022 07:36 PM Reinstall OS
15/08/2022 04:04 AM Disable rescue mode
15/08/2022 04:04 AM Reboot
15/08/2022 04:01 AM Enable rescue mode
15/08/2022 04:01 AM Reboot
15/08/2022 02:17 AM Reboot
15/08/2022 02:16 AM Reinstall OS
30/09/2022 05:55 AM Reinstall OS
28/09/2022 06:51 AM Reboot
26/09/2022 08:30 AM Boot
24/09/2022 07:23 AM Reinstall OS
24/09/2022 05:06 AM Reboot
24/09/2022 05:06 AM Boot
19/09/2022 04:45 AM Reinstall OS
06/08/2022 1:23 AM Reboot
06/08/2022 12:12 AM Boot
05/08/2022 11:53 PM Reboot
05/08/2022 3:58 AM Reboot
03/08/2022 8:17 AM Reboot
02/08/2022 3:46 AM Boot
02/08/2022 3:13 AM Reinstall OS
02/08/2022 3:11 AM Reboot
02/08/2022 3:06 AM Boot
02/08/2022 3:06 AM Reboot
01/08/2022 7:55 PM Boot
01/08/2022 7:37 PM Reboot
01/08/2022 7:31 PM Disable rescue mode
01/08/2022 7:31 PM Reboot
01/08/2022 7:28 PM Boot
01/08/2022 7:28 PM Enable rescue mode
01/08/2022 7:28 PM Reboot
01/08/2022 7:27 PM Boot
01/08/2022 7:26 PM Boot
09/07/2022 4:59 PM Reinstall OS
20/08/2022 03:39 AM Reinstall OS
20/08/2022 03:22 AM Reinstall OS
21/07/2022 07:52 AM Reinstall OS
09/07/2022 8:08 AM Reinstall OS
09/07/2022 8:07 AM Reinstall OS
29/09/2022 12:12 AM Reinstall OS
23/09/2022 02:18 AM Disable rescue mode
23/09/2022 02:18 AM Reboot
21/09/2022 03:23 AM Enable rescue mode
21/09/2022 03:23 AM Reboot
19/09/2022 03:29 AM Reinstall OS
15/09/2022 10:45 AM Reinstall OS
09/09/2022 9:34 AM Disable rescue mode
09/09/2022 9:34 AM Reboot
09/09/2022 9:30 AM Enable rescue mode
09/09/2022 9:30 AM Reboot
07/09/2022 1:44 PM Disable rescue mode
07/09/2022 1:44 PM Reboot
07/09/2022 3:07 AM Enable rescue mode
07/09/2022 3:07 AM Reboot
02/09/2022 12:50 PM Disable rescue mode
02/09/2022 12:50 PM Reboot
02/09/2022 12:24 PM Enable rescue mode
02/09/2022 12:24 PM Reboot
01/09/2022 8:40 PM Disable rescue mode
01/09/2022 8:40 PM Reboot
01/09/2022 8:38 PM Enable rescue mode
01/09/2022 8:38 PM Reboot
01/09/2022 8:35 PM Reboot
01/09/2022 8:35 PM Disable rescue mode
01/09/2022 8:29 PM Enable rescue mode
01/09/2022 8:29 PM Reboot
01/09/2022 8:26 PM KVM reconfigure
01/09/2022 7:53 AM Reinstall OS
01/09/2022 7:52 AM KVM reconfigure
01/09/2022 1:46 AM Disable rescue mode
01/09/2022 1:46 AM Reboot
01/09/2022 1:23 AM Enable rescue mode
01/09/2022 1:23 AM Reboot
01/09/2022 1:20 AM Reboot
01/09/2022 1:19 AM KVM reconfigure
31/08/2022 12:43 AM Disable rescue mode
31/08/2022 12:43 AM Reboot
31/08/2022 12:41 AM Enable rescue mode
31/08/2022 12:41 AM Reboot
31/08/2022 12:40 AM KVM reconfigure
30/08/2022 05:41 AM Reinstall OS
30/08/2022 12:59 AM Disable rescue mode
30/08/2022 12:59 AM Reboot
30/08/2022 12:48 AM Enable rescue mode
30/08/2022 12:48 AM Reboot
30/08/2022 12:47 AM KVM reconfigure
30/08/2022 12:46 AM Change Boot Order
30/08/2022 12:46 AM Unmounted CDROM
30/08/2022 12:45 AM Reboot
30/08/2022 12:45 AM Mounted CDROM
30/08/2022 12:44 AM Change Boot Order
30/08/2022 12:30 AM Reinstall OS
30/08/2022 12:29 AM KVM reconfigure
29/08/2022 03:12 AM Reinstall OS
29/08/2022 03:11 AM Boot
29/08/2022 03:07 AM KVM reconfigure
29/08/2022 02:52 AM Disable rescue mode
29/08/2022 02:52 AM Reboot
29/08/2022 02:26 AM Enable rescue mode
29/08/2022 02:26 AM Reboot
28/08/2022 08:16 AM Disable rescue mode
28/08/2022 08:16 AM Reboot
28/08/2022 08:05 AM Enable rescue mode
28/08/2022 08:05 AM Reboot
28/08/2022 07:59 AM Reinstall OS
28/08/2022 07:58 AM Reboot
28/08/2022 07:57 AM Reboot
28/08/2022 07:57 AM Change VNC Password
28/08/2022 07:48 AM Reboot
28/08/2022 07:48 AM Change Boot Order
28/08/2022 07:48 AM Unmounted CDROM
28/08/2022 07:40 AM Reboot
28/08/2022 07:39 AM Change Boot Order
28/08/2022 07:32 AM Reboot
28/08/2022 07:30 AM Shutdown
28/08/2022 07:30 AM Change Boot Order
28/08/2022 07:30 AM Unmounted CDROM
28/08/2022 07:28 AM Reboot
28/08/2022 07:28 AM Mounted CDROM
28/08/2022 07:28 AM Change Boot Order
28/08/2022 07:19 AM Hard Power Off
28/08/2022 07:05 AM Reinstall OS
28/08/2022 06:55 AM Reboot
28/08/2022 06:54 AM Unmounted CDROM
28/08/2022 06:53 AM KVM reconfigure
28/08/2022 06:52 AM Boot
28/08/2022 06:51 AM Disable rescue mode
28/08/2022 06:51 AM Reboot
28/08/2022 06:32 AM Enable rescue mode
28/08/2022 06:32 AM Reboot
28/08/2022 06:31 AM Boot
28/08/2022 06:30 AM Reboot
28/08/2022 06:30 AM Mounted CDROM
28/08/2022 06:29 AM Disable rescue mode
28/08/2022 06:29 AM Reboot
28/08/2022 06:27 AM Enable rescue mode
28/08/2022 06:27 AM Reboot
28/08/2022 06:27 AM KVM reconfigure
28/08/2022 06:25 AM KVM reconfigure
28/08/2022 06:09 AM Reinstall OS
28/08/2022 06:08 AM Reboot
27/08/2022 01:12 AM Reinstall OS
26/08/2022 10:48 AM KVM reconfigure
26/08/2022 10:48 AM Boot
26/08/2022 10:47 AM Reboot
26/08/2022 10:17 AM Reinstall OS
26/08/2022 10:15 AM KVM reconfigure
26/08/2022 06:16 AM Reboot
24/08/2022 11:46 PM Boot
24/08/2022 11:42 PM Reboot
24/08/2022 11:19 PM Reinstall OS
21/08/2022 11:23 PM KVM reconfigure
21/08/2022 11:22 PM KVM reconfigure
21/08/2022 11:19 PM Reboot
21/08/2022 11:18 PM Reboot
21/08/2022 11:06 PM Reinstall OS
21/08/2022 11:04 PM Boot
21/08/2022 07:47 AM Boot
20/08/2022 12:10 AM Reboot
19/08/2022 11:27 PM Reboot
19/08/2022 11:26 PM Change Boot Order
19/08/2022 12:44 PM Reinstall OS
19/08/2022 12:41 PM Reboot
19/08/2022 12:41 PM Change Boot Order
19/08/2022 12:38 PM Reboot
19/08/2022 12:38 PM Unmounted CDROM
19/08/2022 12:37 PM Reboot
19/08/2022 12:37 PM Mounted CDROM
19/08/2022 12:36 PM Disable rescue mode
19/08/2022 12:36 PM Reboot
19/08/2022 12:35 PM Boot
19/08/2022 12:25 PM Enable rescue mode
19/08/2022 12:25 PM Reboot
19/08/2022 12:24 PM Boot
19/08/2022 12:04 PM Reinstall OS
17/08/2022 11:03 PM KVM reconfigure
16/08/2022 09:26 AM Shutdown
16/08/2022 08:57 AM Reboot
15/08/2022 10:46 AM Reboot
29/09/2022 12:36 AM Disable rescue mode
29/09/2022 12:36 AM Reboot
28/09/2022 01:44 AM Enable rescue mode
28/09/2022 01:44 AM Reboot
28/09/2022 01:41 AM Boot
28/09/2022 01:40 AM Reinstall OS
24/09/2022 08:44 AM Reinstall OS
21/09/2022 06:16 PM Reinstall OS
19/09/2022 10:49 PM Boot
19/09/2022 10:47 PM Reinstall OS
19/09/2022 10:42 PM Reinstall OS
13/09/2022 08:10 PM Reinstall OS
04/09/2022 7:37 PM Reinstall OS
28/08/2022 06:38 PM Reinstall OS
26/08/2022 01:47 AM Reboot
23/08/2022 11:38 PM Reboot
17/08/2022 12:07 AM Reboot
17/08/2022 12:06 AM Reinstall OS
16/08/2022 06:16 PM Reinstall OS
16/08/2022 08:31 AM Reinstall OS
15/08/2022 08:12 PM KVM reconfigure
15/08/2022 08:12 PM Change Network Card
15/08/2022 08:00 PM Reinstall OS
15/08/2022 07:59 PM Reboot
15/08/2022 07:58 PM Reinstall OS
04/09/2022 6:04 AM Reinstall OS
23/08/2022 07:28 AM Disable rescue mode
23/08/2022 07:28 AM Reboot
21/08/2022 08:06 PM Enable rescue mode
21/08/2022 08:06 PM Reboot
21/08/2022 09:56 AM Reboot
19/08/2022 07:40 PM Reboot
19/08/2022 07:39 PM Unmounted CDROM
19/08/2022 07:39 PM Disable rescue mode
19/08/2022 07:39 PM Reboot
19/08/2022 07:36 PM Enable rescue mode
19/08/2022 07:36 PM Reboot
15/08/2022 09:57 AM KVM reconfigure
12/08/2022 7:16 PM Reinstall OS
10/08/2022 10:57 AM KVM reconfigure
10/08/2022 10:56 AM Reinstall OS
10/08/2022 10:55 AM Disable rescue mode
10/08/2022 10:55 AM Reboot
05/08/2022 8:12 PM Enable rescue mode
05/08/2022 8:12 PM Reboot
05/08/2022 8:12 PM Reinstall OS
03/08/2022 6:24 AM Boot
03/08/2022 6:19 AM Reinstall OS
03/08/2022 6:04 AM Boot
03/08/2022 6:03 AM Reboot
02/08/2022 11:10 AM Reinstall OS
01/08/2022 7:04 PM Reinstall OS
01/08/2022 6:54 PM Reboot
01/08/2022 6:44 PM Boot
18/07/2022 07:50 AM Reinstall OS
24/09/2022 10:48 PM Reboot
24/09/2022 10:46 PM Reinstall OS
24/09/2022 10:45 PM Enable rescue mode
24/09/2022 10:45 PM Reboot
22/08/2022 05:05 AM Boot
22/08/2022 04:58 AM Reinstall OS
22/08/2022 04:58 AM Boot
22/08/2022 04:58 AM Reboot
22/08/2022 04:50 AM Reinstall OS
17/08/2022 01:45 PM Reinstall OS
17/08/2022 01:33 PM Reinstall OS
28/09/2022 08:05 AM Reinstall OS
22/09/2022 11:56 PM Reinstall OS
30/08/2022 02:27 AM Reinstall OS
21/08/2022 05:45 PM Reinstall OS
17/08/2022 10:55 PM Disable rescue mode
17/08/2022 10:55 PM Reboot
17/08/2022 10:53 PM Enable rescue mode
17/08/2022 10:53 PM Reboot
16/08/2022 08:37 AM Boot
16/08/2022 08:36 AM Disable rescue mode
16/08/2022 08:36 AM Reboot
16/08/2022 08:34 AM KVM reconfigure
16/08/2022 08:29 AM Enable rescue mode
16/08/2022 08:29 AM Reboot
16/08/2022 08:25 AM Disable rescue mode
16/08/2022 08:25 AM Reboot
16/08/2022 08:20 AM Enable rescue mode
16/08/2022 08:20 AM Reboot
16/08/2022 08:19 AM Reinstall OS
16/08/2022 08:17 AM KVM reconfigure
14/08/2022 09:27 AM KVM reconfigure
14/08/2022 09:26 AM Reinstall OS
14/08/2022 09:24 AM KVM reconfigure
14/08/2022 09:19 AM Reinstall OS
14/08/2022 09:13 AM Reinstall OS
08/08/2022 8:24 PM Reinstall OS
03/08/2022 9:22 AM Reinstall OS
02/08/2022 12:00 AM Reinstall OS
19/08/2022 04:21 PM Reinstall OS
27/09/2022 10:16 PM Reinstall OS
27/09/2022 05:44 PM Reinstall OS
19/08/2022 10:48 PM Unmounted CDROM
19/08/2022 10:48 PM Mounted CDROM
19/08/2022 10:47 PM Unmounted CDROM
19/08/2022 10:47 PM Change Boot Order
19/08/2022 10:38 PM Reinstall OS
19/08/2022 10:31 PM Reinstall OS
14/08/2022 06:04 AM Reinstall OS
21/09/2022 05:36 AM Reinstall OS
21/09/2022 05:35 AM Reboot
20/09/2022 09:35 AM Disable rescue mode
20/09/2022 09:35 AM Reboot
20/09/2022 06:26 AM Enable rescue mode
20/09/2022 06:26 AM Reboot
19/09/2022 08:21 PM Reinstall OS
19/09/2022 06:56 PM Reinstall OS
19/09/2022 06:32 PM Disable rescue mode
19/09/2022 06:32 PM Reboot
13/09/2022 07:28 AM Enable rescue mode
13/09/2022 07:28 AM Reboot
17/08/2022 03:21 AM Reinstall OS
16/08/2022 06:36 AM Boot
16/08/2022 02:38 AM Boot
15/08/2022 03:26 AM Reinstall OS
15/08/2022 03:25 AM Disable rescue mode
15/08/2022 03:25 AM Reboot
15/08/2022 03:18 AM Enable rescue mode
15/08/2022 03:18 AM Reboot
15/08/2022 03:17 AM Boot
15/08/2022 03:12 AM Boot
15/08/2022 03:11 AM Reinstall OS
15/08/2022 03:08 AM Reboot
01/08/2022 9:17 PM Boot
01/10/2022 1:14 AM Reinstall OS
01/10/2022 1:13 AM Boot
01/10/2022 1:13 AM Shutdown
23/09/2022 12:08 AM Boot
23/09/2022 12:06 AM Disable rescue mode
23/09/2022 12:06 AM Reboot
08/09/2022 4:40 AM Reinstall OS
08/09/2022 4:35 AM Enable rescue mode
08/09/2022 4:35 AM Reboot
01/09/2022 1:31 AM Reinstall OS
01/09/2022 1:31 AM Mounted CDROM
01/09/2022 1:31 AM Unmounted CDROM
28/08/2022 06:09 AM Boot
28/08/2022 06:08 AM Reinstall OS
28/08/2022 06:07 AM Boot
28/08/2022 06:07 AM Change Boot Order
28/08/2022 06:06 AM Boot
21/08/2022 02:14 AM Reboot
21/08/2022 02:12 AM Boot
18/08/2022 01:59 AM Reinstall OS
18/08/2022 01:57 AM Reboot
18/08/2022 01:56 AM Boot
18/08/2022 01:53 AM Unmounted CDROM
18/08/2022 01:52 AM Mounted CDROM
18/08/2022 01:52 AM Unmounted CDROM
18/08/2022 01:48 AM Boot
18/08/2022 01:48 AM Shutdown
18/08/2022 01:47 AM Boot
17/08/2022 07:43 PM Reinstall OS
17/08/2022 07:39 PM Reboot
17/08/2022 07:39 PM Change Boot Order
17/08/2022 07:38 PM Reboot
17/08/2022 07:37 PM Reboot
17/08/2022 07:34 PM Reboot
17/08/2022 07:27 PM Reboot
17/08/2022 06:19 PM Reinstall OS
17/08/2022 06:14 PM Reboot
17/08/2022 06:12 PM Unmounted CDROM
17/08/2022 07:28 AM Reboot
17/08/2022 07:23 AM Reboot
17/08/2022 06:55 AM Reinstall OS
19/09/2022 06:46 PM Reinstall OS
08/09/2022 2:18 AM Reinstall OS
04/09/2022 6:32 PM Reinstall OS
31/08/2022 05:52 AM Boot
31/08/2022 05:52 AM Shutdown
31/08/2022 05:50 AM Enable rescue mode
31/08/2022 05:50 AM Reboot
30/08/2022 05:20 AM Reinstall OS
28/08/2022 03:28 AM Reinstall OS
25/08/2022 07:51 AM Reinstall OS
20/08/2022 07:05 PM Reinstall OS
20/08/2022 06:57 PM Boot
19/08/2022 09:28 PM Reinstall OS
13/07/2022 08:15 PM Reinstall OS
13/07/2022 08:11 PM KVM reconfigure
13/07/2022 08:09 PM Reboot
25/09/2022 12:06 AM Reinstall OS
14/09/2022 11:57 PM Reinstall OS
14/09/2022 11:55 PM Reboot
21/08/2022 02:27 AM Disable rescue mode
21/08/2022 02:27 AM Reboot
21/08/2022 02:25 AM Enable rescue mode
21/08/2022 02:25 AM Reboot
10/08/2022 12:38 AM Reinstall OS
01/08/2022 5:51 PM Reinstall OS
29/09/2022 03:59 PM Reinstall OS
22/09/2022 09:04 AM Reinstall OS
19/09/2022 06:53 AM Reinstall OS
04/09/2022 5:58 AM Reinstall OS
27/08/2022 09:31 PM Reinstall OS
25/08/2022 02:27 AM Reinstall OS
10/08/2022 6:02 AM Reinstall OS
03/08/2022 7:41 AM Reinstall OS
03/08/2022 7:39 AM Boot
02/08/2022 8:02 AM Reinstall OS
02/08/2022 8:00 AM Boot
20/09/2022 12:34 AM Change Boot Order
20/09/2022 12:33 AM Reinstall OS
20/09/2022 12:33 AM Boot
19/09/2022 08:02 AM Reinstall OS
19/09/2022 08:01 AM Reboot
19/09/2022 08:01 AM Change Boot Order
19/09/2022 08:01 AM Mounted CDROM
19/09/2022 08:01 AM Reinstall OS
19/09/2022 08:00 AM Changed Tablet Input Device Se
19/09/2022 08:00 AM Changed PAE Settings
19/09/2022 01:11 AM KVM reconfigure
19/09/2022 01:10 AM Reinstall OS
28/08/2022 11:55 PM KVM reconfigure
28/08/2022 11:55 PM Reinstall OS
28/08/2022 11:54 PM Change Boot Order
28/08/2022 04:05 AM KVM reconfigure
28/08/2022 04:05 AM Change Boot Order
27/08/2022 05:04 AM KVM reconfigure
27/08/2022 05:03 AM Change Boot Order
24/08/2022 06:49 AM Reinstall OS
21/08/2022 03:51 AM KVM reconfigure
21/08/2022 03:50 AM Reboot
30/09/2022 06:47 PM Reinstall OS
30/09/2022 01:54 AM Reinstall OS
25/09/2022 05:30 PM Reinstall OS
25/09/2022 05:26 PM Boot
23/09/2022 09:35 PM Reinstall OS
22/09/2022 07:28 AM Reinstall OS
12/09/2022 10:03 PM Reinstall OS
21/08/2022 05:22 AM Boot
25/09/2022 06:58 PM Reinstall OS
19/09/2022 04:51 AM Boot
19/09/2022 04:37 AM Reinstall OS
19/09/2022 04:37 AM Shutdown
05/09/2022 4:36 AM Reinstall OS
27/08/2022 10:07 PM Disable rescue mode
27/08/2022 10:07 PM Reboot
27/08/2022 10:04 PM Enable rescue mode
27/08/2022 10:04 PM Reboot
27/08/2022 09:59 PM Reinstall OS
27/08/2022 09:53 PM Boot
25/08/2022 01:59 AM Reinstall OS
21/08/2022 02:13 AM Boot
21/08/2022 02:13 AM Mounted CDROM
20/08/2022 01:15 AM Reboot
20/08/2022 12:45 AM Reinstall OS
20/08/2022 12:44 AM KVM reconfigure
20/08/2022 12:42 AM Reboot
19/08/2022 08:26 PM Reboot
19/08/2022 08:25 PM KVM reconfigure
19/08/2022 08:21 PM Boot
19/08/2022 08:17 PM Reinstall OS
19/08/2022 08:11 PM Reinstall OS
19/08/2022 08:03 PM Reboot
19/08/2022 08:03 PM Unmounted CDROM
01/08/2022 7:52 PM Reboot
20/09/2022 03:53 PM Disable rescue mode
20/09/2022 03:53 PM Reboot
20/09/2022 01:19 AM Enable rescue mode
20/09/2022 01:19 AM Reboot
15/09/2022 03:51 AM Disable rescue mode
15/09/2022 03:51 AM Reboot
15/09/2022 03:48 AM Enable rescue mode
15/09/2022 03:48 AM Reboot
14/09/2022 07:57 AM Disable rescue mode
14/09/2022 07:57 AM Reboot
14/09/2022 07:55 AM Reboot
14/09/2022 07:54 AM Enable rescue mode
14/09/2022 07:54 AM Reboot
12/09/2022 8:45 AM Disable rescue mode
12/09/2022 8:45 AM Reboot
12/09/2022 8:39 AM Enable rescue mode
12/09/2022 8:39 AM Reboot
30/09/2022 10:57 AM Reinstall OS
29/09/2022 09:04 PM Reinstall OS
28/09/2022 09:19 PM Reinstall OS
28/09/2022 10:57 AM Reinstall OS
27/09/2022 09:41 AM Reinstall OS
26/09/2022 08:10 AM Reinstall OS
25/09/2022 06:55 PM Reinstall OS
25/09/2022 08:53 AM Reinstall OS
25/09/2022 08:53 AM Disable rescue mode
25/09/2022 08:53 AM Reboot
24/09/2022 09:07 PM Enable rescue mode
24/09/2022 09:07 PM Reboot
24/09/2022 09:06 PM Reinstall OS
23/09/2022 11:15 AM Reinstall OS
22/09/2022 10:04 AM Reinstall OS
21/09/2022 08:17 PM Reinstall OS
20/09/2022 07:03 PM Reinstall OS
20/09/2022 09:46 AM Reinstall OS
19/09/2022 10:19 AM Boot
19/09/2022 10:17 AM Boot
19/09/2022 10:16 AM Reinstall OS
15/09/2022 10:34 PM Reinstall OS
15/09/2022 09:35 AM Reinstall OS
14/09/2022 06:01 PM Reinstall OS
14/09/2022 05:22 AM Reboot
14/09/2022 05:22 AM Reinstall OS
12/09/2022 7:50 PM Reinstall OS
12/09/2022 10:04 AM Changed Tablet Input Device Se
12/09/2022 10:04 AM Changed PAE Settings
12/09/2022 10:03 AM Reinstall OS
09/09/2022 11:50 PM Reinstall OS
09/09/2022 1:56 AM Reinstall OS
08/09/2022 11:09 AM Reinstall OS
07/09/2022 11:24 PM Reinstall OS
07/09/2022 5:49 PM Reboot
07/09/2022 5:48 PM Boot
07/09/2022 5:47 PM Boot
07/09/2022 5:24 PM Boot
07/09/2022 5:14 PM Reboot
07/09/2022 5:12 PM Reboot
07/09/2022 4:10 PM Reinstall OS
25/09/2022 01:36 PM Reinstall OS
25/09/2022 01:33 PM KVM reconfigure
24/09/2022 12:11 PM Reinstall OS
22/09/2022 05:28 AM Reinstall OS
22/09/2022 05:25 AM KVM Change Root Password
19/09/2022 08:47 AM KVM Change Root Password
19/09/2022 08:44 AM Reinstall OS
15/09/2022 12:34 PM Reinstall OS
14/09/2022 08:50 PM Boot
14/09/2022 08:48 PM Reinstall OS
13/09/2022 07:22 PM KVM reconfigure
13/09/2022 07:21 PM Boot
13/09/2022 07:21 PM Reboot
13/09/2022 07:21 PM Shutdown
12/09/2022 1:29 PM KVM Change Root Password
12/09/2022 1:26 PM KVM reconfigure
12/09/2022 11:48 AM KVM Change Root Password
12/09/2022 11:47 AM KVM Change Root Password
12/09/2022 11:46 AM Reboot
12/09/2022 11:45 AM Boot
11/09/2022 12:35 PM Reinstall OS
11/09/2022 12:35 PM Disable rescue mode
11/09/2022 12:35 PM Reboot
11/09/2022 8:27 AM Enable rescue mode
11/09/2022 8:27 AM Reboot
11/09/2022 8:26 AM Reinstall OS
11/09/2022 8:24 AM Reinstall OS
09/09/2022 3:54 AM Reinstall OS
09/09/2022 3:02 AM KVM Change Root Password
08/09/2022 2:12 AM Boot
08/09/2022 2:12 AM Hard Power Off
07/09/2022 7:36 PM Boot
07/09/2022 7:28 PM Reinstall OS
07/09/2022 7:25 PM Boot
07/09/2022 7:23 PM Boot
07/09/2022 7:18 PM Reinstall OS
07/09/2022 7:16 PM Boot
07/09/2022 7:09 PM Boot
07/09/2022 7:01 PM KVM Change Root Password
07/09/2022 6:58 PM KVM Change Root Password
26/08/2022 09:59 AM Reinstall OS
08/07/2022 5:53 AM Reinstall OS
06/07/2022 7:41 AM Reinstall OS
22/09/2022 05:40 PM Reinstall OS
20/09/2022 07:51 PM Reinstall OS
14/08/2022 10:15 PM Reinstall OS
27/09/2022 03:29 AM Disable rescue mode
27/09/2022 03:29 AM Reboot
27/09/2022 03:27 AM Reinstall OS
27/09/2022 03:27 AM Enable rescue mode
27/09/2022 03:27 AM Reboot
27/09/2022 03:25 AM Reinstall OS
08/08/2022 3:03 AM Enable rescue mode
08/08/2022 3:03 AM Reboot
01/08/2022 7:00 PM Reinstall OS
01/08/2022 6:58 PM Reboot
01/08/2022 6:55 PM Boot
21/09/2022 04:46 AM Disable rescue mode
21/09/2022 04:46 AM Reboot
21/09/2022 04:43 AM Enable rescue mode
21/09/2022 04:43 AM Reboot
17/08/2022 07:59 PM Disable rescue mode
17/08/2022 07:59 PM Reboot
17/08/2022 07:31 PM Enable rescue mode
17/08/2022 07:31 PM Reboot
17/08/2022 06:51 PM Reinstall OS
19/09/2022 01:16 AM Reinstall OS
19/09/2022 01:13 AM KVM reconfigure
19/09/2022 01:09 AM Reinstall OS
28/08/2022 11:43 PM Reboot
28/08/2022 11:43 PM Unmounted CDROM
28/08/2022 11:40 PM Reboot
28/08/2022 11:40 PM Mounted CDROM
28/08/2022 11:38 PM Reboot
28/08/2022 11:37 PM Boot
28/08/2022 11:24 PM Reinstall OS
28/08/2022 11:23 PM KVM reconfigure
28/08/2022 11:11 PM Reinstall OS
20/08/2022 12:21 AM Reinstall OS
20/08/2022 02:42 AM Reinstall OS
22/09/2022 01:38 AM Reboot
22/09/2022 01:37 AM Boot
22/09/2022 01:37 AM Shutdown
22/08/2022 05:07 AM Disable rescue mode
22/08/2022 05:07 AM Reboot
22/08/2022 05:04 AM Reinstall OS
22/08/2022 04:50 AM Boot
22/08/2022 04:48 AM Enable rescue mode
22/08/2022 04:48 AM Reboot
22/08/2022 04:47 AM Boot
22/08/2022 04:39 AM Reboot
22/08/2022 04:09 AM Reinstall OS
22/08/2022 04:08 AM Hard Power Off
22/08/2022 04:07 AM Disable rescue mode
22/08/2022 04:07 AM Reboot
22/08/2022 03:42 AM Enable rescue mode
22/08/2022 03:42 AM Reboot
15/08/2022 11:33 PM Reboot
15/08/2022 11:31 PM Boot
15/08/2022 11:31 PM Unmounted CDROM
15/08/2022 11:30 PM Shutdown
14/08/2022 07:41 PM Reboot
02/08/2022 10:19 AM Boot
06/07/2022 1:08 AM Reinstall OS
06/07/2022 12:17 AM Reboot
06/07/2022 12:09 AM Reboot
05/07/2022 11:53 PM Reboot
05/07/2022 11:53 PM Unmounted CDROM
05/07/2022 11:45 PM Reboot
05/07/2022 11:22 PM Reboot
05/07/2022 11:15 PM Boot
05/07/2022 11:15 PM Hard Power Off
05/07/2022 11:14 PM Reboot
05/07/2022 11:13 PM Unmounted CDROM
05/07/2022 11:11 PM Boot
05/07/2022 11:08 PM Shutdown
20/09/2022 05:09 AM Reinstall OS
02/08/2022 7:57 AM Reinstall OS
18/08/2022 11:28 PM Reinstall OS
09/07/2022 9:10 PM Reinstall OS
13/09/2022 02:50 PM Reinstall OS
13/09/2022 02:42 PM Disable rescue mode
13/09/2022 02:42 PM Reboot
10/09/2022 2:35 AM Enable rescue mode
10/09/2022 2:35 AM Reboot
08/09/2022 11:37 PM Disable rescue mode
08/09/2022 11:37 PM Reboot
08/09/2022 11:34 PM Enable rescue mode
08/09/2022 11:34 PM Reboot
08/09/2022 12:31 PM Disable rescue mode
08/09/2022 12:31 PM Reboot
08/09/2022 12:29 PM Reinstall OS
08/09/2022 12:28 PM Enable rescue mode
08/09/2022 12:28 PM Reboot
08/09/2022 12:27 PM Boot
08/09/2022 12:26 PM Disable rescue mode
08/09/2022 12:26 PM Reboot
08/09/2022 12:23 PM Reboot
08/09/2022 12:22 PM KVM reconfigure
08/09/2022 12:21 PM Changed PAE Settings
08/09/2022 12:20 PM Shutdown
08/09/2022 12:19 PM Reinstall OS
08/09/2022 12:18 PM Reboot
08/09/2022 12:16 PM Enable rescue mode
08/09/2022 12:16 PM Reboot
08/09/2022 12:15 PM Boot
23/08/2022 10:43 PM Reinstall OS
23/08/2022 10:42 PM Reinstall OS
23/08/2022 10:40 PM Boot
23/08/2022 10:40 PM Reboot
11/09/2022 10:44 AM Reboot
05/09/2022 12:33 AM Reinstall OS
05/09/2022 12:32 AM Disable rescue mode
05/09/2022 12:32 AM Reboot
05/09/2022 12:31 AM Reinstall OS
02/09/2022 10:22 PM Reboot
02/09/2022 10:22 PM Change Boot Order
02/09/2022 10:22 PM Unmounted CDROM
02/09/2022 10:20 PM Enable rescue mode
02/09/2022 10:20 PM Reboot
22/08/2022 01:25 AM Reboot
22/08/2022 01:24 AM Boot
22/08/2022 01:24 AM Change Boot Order
20/08/2022 06:53 PM Reboot
20/08/2022 06:52 PM Reboot
20/08/2022 06:52 PM Mounted CDROM
20/08/2022 06:52 PM Change Boot Order
20/08/2022 06:51 PM Reboot
17/08/2022 11:51 PM Disable rescue mode
17/08/2022 11:51 PM Reboot
17/08/2022 11:50 PM Boot
16/08/2022 10:57 PM Enable rescue mode
16/08/2022 10:57 PM Reboot
16/08/2022 10:56 PM Boot
14/08/2022 11:43 PM Boot
12/08/2022 4:09 AM Reboot
12/08/2022 4:08 AM Boot
10/08/2022 2:02 AM Boot
10/08/2022 2:02 AM Hard Power Off
10/08/2022 1:58 AM Boot
10/08/2022 1:58 AM Reboot
10/08/2022 1:57 AM Change Hostname
10/08/2022 1:56 AM Unmounted CDROM
10/08/2022 1:56 AM Change Boot Order
10/08/2022 1:56 AM Change Network Card
10/08/2022 1:53 AM Disable rescue mode
10/08/2022 1:53 AM Reboot
10/08/2022 1:52 AM Reinstall OS
09/08/2022 10:33 PM Enable rescue mode
09/08/2022 10:33 PM Reboot
08/08/2022 3:35 AM Reboot
08/08/2022 3:35 AM Change Boot Order
08/08/2022 3:35 AM Mounted CDROM
08/08/2022 3:35 AM Change Network Card
08/08/2022 3:34 AM Change Disk Driver
08/08/2022 3:34 AM Reboot
08/08/2022 3:34 AM Change Network Card
08/08/2022 3:34 AM Change Boot Order
08/08/2022 3:32 AM KVM reconfigure
08/08/2022 3:31 AM Boot
08/08/2022 3:30 AM Reinstall OS
08/08/2022 3:30 AM Boot
07/08/2022 8:01 PM Disable rescue mode
07/08/2022 8:01 PM Reboot
07/08/2022 7:56 PM Enable rescue mode
07/08/2022 7:56 PM Reboot
06/08/2022 12:51 AM Reinstall OS
06/08/2022 12:42 AM KVM reconfigure
06/08/2022 12:40 AM Reboot
06/08/2022 12:39 AM Boot
06/08/2022 12:39 AM Shutdown
06/08/2022 12:36 AM Reinstall OS
04/08/2022 1:24 AM Reboot
01/08/2022 8:56 PM Reboot
01/08/2022 8:48 PM Reinstall OS
01/08/2022 8:45 PM Reboot
30/09/2022 10:45 AM Reboot
30/09/2022 10:37 AM Reboot
30/09/2022 10:37 AM Reinstall OS
30/09/2022 10:36 AM Reboot
30/09/2022 10:36 AM Changed Tablet Input Device Se
30/09/2022 10:36 AM Changed PAE Settings
30/09/2022 10:36 AM Changed ACPI Settings
30/09/2022 10:36 AM Changed APIC Settings
30/09/2022 10:35 AM Reinstall OS
30/09/2022 10:34 AM Unmounted CDROM
30/09/2022 10:34 AM Mounted CDROM
30/09/2022 10:34 AM Reboot
30/09/2022 10:33 AM Change Network Card
30/09/2022 10:33 AM Change Disk Driver
30/09/2022 10:27 AM Reboot
30/09/2022 10:27 AM Boot
30/09/2022 10:27 AM Changed APIC Settings
30/09/2022 10:27 AM Changed ACPI Settings
30/09/2022 10:26 AM Change Network Card
30/09/2022 10:25 AM KVM reconfigure
30/09/2022 10:25 AM Reinstall OS
29/09/2022 02:34 AM Reinstall OS
29/09/2022 02:32 AM KVM reconfigure
29/09/2022 02:32 AM Reboot
29/09/2022 02:32 AM Disable rescue mode
29/09/2022 02:23 AM Enable rescue mode
29/09/2022 02:23 AM Reboot
26/09/2022 02:06 PM Reboot
26/09/2022 02:06 PM Change Disk Driver
26/09/2022 02:06 PM Change Network Card
26/09/2022 02:06 PM Change Boot Order
26/09/2022 02:05 PM Change Network Card
26/09/2022 02:05 PM Changed Tablet Input Device Se
26/09/2022 02:05 PM Reboot
26/09/2022 02:04 PM Reboot
26/09/2022 02:04 PM Changed Clock Settings
26/09/2022 02:03 PM Reboot
26/09/2022 02:03 PM Change Boot Order
26/09/2022 02:02 PM Reinstall OS
26/09/2022 02:02 PM Reboot
26/09/2022 02:01 PM Unmounted CDROM
26/09/2022 02:00 PM Reboot
26/09/2022 01:59 PM Mounted CDROM
26/09/2022 01:59 PM Unmounted CDROM
26/09/2022 01:59 PM Changed Tablet Input Device Se
26/09/2022 01:59 PM Changed PAE Settings
26/09/2022 01:59 PM Reinstall OS
26/09/2022 01:58 PM Reinstall OS
26/09/2022 01:57 PM KVM reconfigure
25/09/2022 07:41 AM Disable rescue mode
25/09/2022 07:41 AM Reboot
25/09/2022 02:56 AM Enable rescue mode
25/09/2022 02:56 AM Reboot
25/09/2022 02:51 AM Reinstall OS
25/09/2022 02:48 AM Reboot
21/09/2022 11:13 AM Reboot
21/09/2022 11:13 AM Change Boot Order
21/09/2022 11:13 AM Disable rescue mode
21/09/2022 11:11 AM KVM reconfigure
21/09/2022 11:11 AM Reboot
21/09/2022 11:10 AM Change Boot Order
21/09/2022 11:10 AM Reboot
21/09/2022 11:10 AM Change Disk Driver
21/09/2022 11:10 AM Changed ACPI Settings
21/09/2022 11:09 AM Changed Tablet Input Device Se
21/09/2022 11:08 AM Enable rescue mode
21/09/2022 11:08 AM Reboot
21/09/2022 11:07 AM Reinstall OS
13/09/2022 12:35 PM Reboot
13/09/2022 12:33 PM KVM reconfigure
13/09/2022 12:33 PM Boot
13/09/2022 12:32 PM Reboot
13/09/2022 12:31 PM Reboot
13/09/2022 12:31 PM Change Disk Driver
13/09/2022 12:30 PM Reboot
13/09/2022 12:30 PM Changed Tablet Input Device Se
13/09/2022 12:29 PM Reinstall OS
13/09/2022 12:27 PM Disable rescue mode
13/09/2022 12:27 PM Reboot
13/09/2022 12:21 PM Enable rescue mode
13/09/2022 12:21 PM Reboot
12/09/2022 11:19 AM Reinstall OS
11/09/2022 2:02 AM Disable rescue mode
11/09/2022 2:02 AM Reboot
10/09/2022 1:43 PM Enable rescue mode
10/09/2022 1:43 PM Reboot
10/09/2022 1:40 PM Reboot
10/09/2022 1:40 PM Mounted CDROM
10/09/2022 1:17 PM Reinstall OS
10/09/2022 1:15 PM Unmounted CDROM
10/09/2022 1:14 PM Boot
10/09/2022 1:05 PM Reinstall OS
16/08/2022 11:26 AM Disable rescue mode
16/08/2022 11:26 AM Reboot
16/08/2022 11:23 AM Enable rescue mode
16/08/2022 11:23 AM Reboot
15/08/2022 04:09 AM Disable rescue mode
15/08/2022 04:09 AM Reboot
15/08/2022 04:07 AM Enable rescue mode
15/08/2022 04:07 AM Reboot
15/08/2022 12:34 AM Reboot
14/08/2022 09:01 PM Reboot
14/08/2022 02:22 PM Changed APIC Settings
14/08/2022 02:22 PM Changed ACPI Settings
14/08/2022 02:19 PM Reboot
14/08/2022 02:19 PM Changed VNC Settings
14/08/2022 02:17 PM Reboot
14/08/2022 02:16 PM Changed VNC Settings
14/08/2022 02:16 PM Changed ACPI Settings
14/08/2022 02:15 PM Changed APIC Settings
14/08/2022 02:15 PM Changed PAE Settings
14/08/2022 02:15 PM Changed Tablet Input Device Se
14/08/2022 02:12 PM KVM reconfigure
14/08/2022 12:40 PM Reboot
14/08/2022 12:39 PM Change Network Card
14/08/2022 12:38 PM Reboot
14/08/2022 12:38 PM Change Network Card
14/08/2022 12:37 PM Reboot
14/08/2022 12:37 PM Change Network Card
06/07/2022 11:11 AM KVM Change Root Password
30/09/2022 11:34 PM Boot
30/09/2022 05:22 AM Reboot
30/09/2022 01:59 AM Reinstall OS
27/09/2022 12:06 AM Reinstall OS
27/09/2022 12:05 AM Reboot
27/09/2022 12:05 AM Change Boot Order
27/09/2022 12:05 AM Unmounted CDROM
27/09/2022 12:04 AM Reboot
27/09/2022 12:04 AM Change Boot Order
27/09/2022 12:04 AM Mounted CDROM
27/09/2022 12:03 AM Reboot
24/09/2022 10:28 PM Reinstall OS
12/09/2022 11:57 PM Reinstall OS
07/09/2022 1:09 AM Reinstall OS
03/09/2022 10:28 PM Reboot
03/09/2022 5:01 AM Reboot
01/09/2022 8:00 AM KVM reconfigure
01/09/2022 7:40 AM Reinstall OS
01/09/2022 7:28 AM Reinstall OS
01/09/2022 7:24 AM Disable rescue mode
01/09/2022 7:24 AM Reboot
01/09/2022 7:20 AM Enable rescue mode
01/09/2022 7:20 AM Reboot
01/09/2022 7:15 AM Reboot
01/09/2022 7:15 AM Unmounted CDROM
01/09/2022 7:15 AM Change Boot Order
01/09/2022 7:13 AM Reboot
01/09/2022 7:13 AM Change Boot Order
01/09/2022 7:13 AM Mounted CDROM
01/09/2022 7:09 AM Reinstall OS
27/08/2022 01:17 AM Disable rescue mode
27/08/2022 01:17 AM Reboot
27/08/2022 01:12 AM Enable rescue mode
27/08/2022 01:12 AM Reboot
26/08/2022 03:50 AM Boot
25/08/2022 07:02 PM Disable rescue mode
25/08/2022 07:02 PM Reboot
25/08/2022 06:59 PM Enable rescue mode
25/08/2022 06:59 PM Reboot
23/08/2022 09:58 PM Reinstall OS
23/08/2022 01:36 AM Disable rescue mode
23/08/2022 01:36 AM Reboot
23/08/2022 01:33 AM Enable rescue mode
23/08/2022 01:33 AM Reboot
21/08/2022 11:05 PM Disable rescue mode
21/08/2022 11:05 PM Reboot
21/08/2022 10:48 PM Enable rescue mode
21/08/2022 10:48 PM Reboot
21/08/2022 04:26 AM Disable rescue mode
21/08/2022 04:26 AM Reboot
21/08/2022 04:16 AM Enable rescue mode
21/08/2022 04:16 AM Reboot
21/08/2022 04:13 AM Reboot
20/08/2022 11:53 PM KVM reconfigure
20/08/2022 11:42 PM Boot
20/08/2022 04:35 AM Reinstall OS
20/08/2022 04:32 AM Reinstall OS
20/08/2022 04:31 AM Reboot
20/08/2022 04:31 AM Unmounted CDROM
20/08/2022 04:30 AM Reboot
20/08/2022 04:30 AM Mounted CDROM
20/08/2022 04:30 AM Unmounted CDROM
20/08/2022 04:30 AM Change Boot Order
20/08/2022 04:29 AM Reboot
20/08/2022 04:29 AM Change Boot Order
20/08/2022 04:28 AM Reboot
20/08/2022 04:28 AM Mounted CDROM
20/08/2022 04:26 AM Boot
19/08/2022 11:20 PM Reinstall OS
19/08/2022 08:28 PM Reinstall OS
19/08/2022 08:28 PM Disable rescue mode
19/08/2022 08:28 PM Reboot
19/08/2022 08:24 PM Enable rescue mode
19/08/2022 08:24 PM Reboot
19/08/2022 07:39 PM Reinstall OS
19/08/2022 07:39 PM Change Boot Order
19/08/2022 07:35 PM Boot
19/08/2022 07:35 PM Reboot
19/08/2022 07:35 PM Change Boot Order
19/08/2022 07:35 PM Mounted CDROM
19/08/2022 07:34 PM Reinstall OS
19/08/2022 05:37 AM Reinstall OS
19/08/2022 05:36 AM KVM reconfigure
19/08/2022 05:34 AM Reinstall OS
19/08/2022 05:33 AM Unmounted CDROM
19/08/2022 05:33 AM Change Boot Order
19/08/2022 05:33 AM Boot
19/08/2022 05:31 AM Reboot
19/08/2022 05:31 AM Change Boot Order
19/08/2022 05:31 AM Mounted CDROM
19/08/2022 05:30 AM Boot
19/08/2022 05:27 AM Reinstall OS
19/08/2022 05:14 AM Reinstall OS
19/08/2022 05:12 AM Reboot
19/08/2022 05:11 AM Reboot
19/08/2022 05:11 AM Changed Clock Settings
19/08/2022 05:09 AM Boot
29/09/2022 12:59 AM Reinstall OS
25/09/2022 05:29 AM Reinstall OS
02/09/2022 6:09 PM Reboot
02/09/2022 6:08 PM Disable rescue mode
02/09/2022 6:08 PM Reboot
02/09/2022 6:06 PM Reboot
02/09/2022 6:06 PM Enable rescue mode
19/08/2022 06:04 PM Disable rescue mode
19/08/2022 06:04 PM Reboot
19/08/2022 06:02 PM Enable rescue mode
19/08/2022 06:02 PM Reboot
18/08/2022 11:29 PM Reboot
14/08/2022 07:16 PM Reboot
14/08/2022 07:15 PM Disable rescue mode
14/08/2022 07:15 PM Reboot
14/08/2022 07:13 PM Reboot
14/08/2022 07:12 PM Enable rescue mode
14/08/2022 07:12 PM Reboot
10/08/2022 7:44 PM Reinstall OS
08/08/2022 12:45 AM Boot
08/08/2022 12:45 AM Reinstall OS
08/08/2022 12:40 AM KVM reconfigure
08/08/2022 12:39 AM Reinstall OS
06/08/2022 7:12 PM Reboot
06/08/2022 6:56 AM Reinstall OS
06/08/2022 6:55 AM Reboot
06/08/2022 6:55 AM KVM reconfigure
06/08/2022 6:54 AM KVM reconfigure
06/08/2022 6:54 AM Disable rescue mode
06/08/2022 6:54 AM Reboot
06/08/2022 6:52 AM Enable rescue mode
06/08/2022 6:52 AM Reboot
04/08/2022 9:58 AM Disable rescue mode
04/08/2022 9:58 AM Reboot
04/08/2022 9:55 AM Enable rescue mode
04/08/2022 9:55 AM Reboot
04/08/2022 9:53 AM Boot
04/08/2022 9:53 AM Disable rescue mode
04/08/2022 9:53 AM Reboot
04/08/2022 9:51 AM Reinstall OS
04/08/2022 9:50 AM Enable rescue mode
04/08/2022 9:50 AM Reboot
03/08/2022 6:27 PM Reboot
02/08/2022 8:14 AM Reinstall OS
02/08/2022 8:08 AM Reboot
01/08/2022 4:54 PM Boot
01/08/2022 4:53 PM KVM reconfigure
01/08/2022 4:48 PM Reboot
01/08/2022 4:47 PM Reboot
24/09/2022 05:47 AM Reinstall OS
27/08/2022 08:16 AM Boot
27/08/2022 08:16 AM Shutdown
27/08/2022 08:15 AM Reinstall OS
27/08/2022 08:15 AM Reboot
27/08/2022 08:14 AM Boot
30/09/2022 06:31 PM Reboot
28/09/2022 06:17 AM Reboot
26/09/2022 09:33 PM Reinstall OS
23/09/2022 05:29 AM Reboot
20/09/2022 04:03 PM Boot
19/09/2022 04:02 PM Boot
19/09/2022 04:00 PM Reinstall OS
15/09/2022 04:07 PM Reboot
12/09/2022 5:27 PM Reboot
09/09/2022 3:47 AM Reboot
09/09/2022 3:42 AM Reboot
04/09/2022 4:01 PM Reboot
01/09/2022 5:37 AM Reinstall OS
01/09/2022 5:37 AM Boot
31/08/2022 05:06 AM Reinstall OS
31/08/2022 05:06 AM Boot
29/08/2022 05:26 AM Reboot
29/08/2022 05:25 AM Hard Power Off
29/08/2022 05:25 AM Reboot
28/08/2022 04:56 AM Reboot
28/08/2022 04:56 AM Change Boot Order
28/08/2022 04:55 AM Reboot
28/08/2022 04:46 AM Reboot
28/08/2022 04:44 AM Reinstall OS
28/08/2022 04:43 AM Reboot
17/08/2022 05:01 AM Boot
17/08/2022 04:15 AM Reinstall OS
14/08/2022 08:17 PM KVM reconfigure
14/08/2022 08:16 PM Reboot
06/08/2022 11:07 PM Reboot
04/08/2022 7:41 PM Reinstall OS
03/08/2022 6:23 AM Reboot
03/08/2022 4:22 AM Reinstall OS
02/08/2022 10:14 PM Reboot
02/08/2022 10:10 PM Reboot
02/08/2022 10:09 PM Hard Power Off
02/08/2022 10:09 PM Reboot
02/08/2022 4:54 PM Reboot
02/08/2022 4:52 PM Reinstall OS
02/08/2022 7:17 AM Reboot
02/08/2022 7:17 AM Hard Power Off
01/08/2022 7:49 PM Reinstall OS
01/08/2022 7:48 PM Reboot
01/08/2022 5:55 PM Reboot
06/07/2022 5:49 PM Reinstall OS
05/07/2022 12:08 AM Reinstall OS
28/09/2022 03:46 PM Disable rescue mode
28/09/2022 03:46 PM Reboot
28/09/2022 03:45 PM KVM reconfigure
28/09/2022 03:43 PM KVM reconfigure
28/09/2022 03:42 PM Enable rescue mode
28/09/2022 03:42 PM Reboot
28/09/2022 03:41 PM Reinstall OS
19/09/2022 09:40 AM Boot
19/09/2022 09:40 AM Shutdown
19/09/2022 09:39 AM KVM reconfigure
19/09/2022 09:29 AM Reinstall OS
15/09/2022 01:38 PM Reinstall OS
06/09/2022 2:02 PM Reinstall OS
28/08/2022 01:12 AM Reinstall OS
18/08/2022 03:55 PM Reinstall OS
11/08/2022 12:14 AM Reinstall OS
06/08/2022 3:57 PM KVM reconfigure
06/08/2022 3:56 PM KVM reconfigure
06/08/2022 3:54 PM Reinstall OS
06/08/2022 3:53 PM Reboot
04/08/2022 8:08 AM Reinstall OS
04/08/2022 6:26 AM Reinstall OS
01/08/2022 3:38 PM Reinstall OS
08/07/2022 2:17 PM Reinstall OS
27/08/2022 10:42 PM Reboot
24/08/2022 05:42 AM Reinstall OS
20/08/2022 06:39 PM Reinstall OS
20/08/2022 06:51 AM Reboot
20/08/2022 06:50 AM Reboot
20/08/2022 06:49 AM Reinstall OS
20/08/2022 06:27 AM Reinstall OS
02/08/2022 1:13 AM Reboot
08/07/2022 6:46 PM Reinstall OS
30/09/2022 01:46 AM Reinstall OS
27/09/2022 08:17 AM Reinstall OS
20/09/2022 06:10 PM Reinstall OS
08/09/2022 5:50 AM Reboot
08/09/2022 5:49 AM Reinstall OS
08/09/2022 5:49 AM Boot
04/09/2022 11:40 AM Boot
04/09/2022 11:40 AM Hard Power Off
04/09/2022 11:40 AM Reboot
04/09/2022 11:39 AM Change Boot Order
04/09/2022 11:39 AM Boot
04/09/2022 11:39 AM Reboot
04/09/2022 11:39 AM Change Disk Driver
04/09/2022 11:38 AM Reboot
04/09/2022 11:38 AM Change Disk Driver
04/09/2022 11:38 AM Reinstall OS
04/09/2022 11:21 AM KVM reconfigure
04/09/2022 11:21 AM Reinstall OS
04/09/2022 11:20 AM Disable rescue mode
04/09/2022 11:20 AM Reboot
04/09/2022 11:17 AM Enable rescue mode
04/09/2022 11:17 AM Reboot
02/09/2022 5:23 AM Disable rescue mode
02/09/2022 5:23 AM Reboot
01/09/2022 5:47 AM Enable rescue mode
01/09/2022 5:47 AM Reboot
01/09/2022 5:43 AM Reinstall OS
01/09/2022 5:39 AM KVM reconfigure
01/09/2022 5:38 AM Reinstall OS
30/08/2022 08:40 PM Reinstall OS
29/08/2022 09:58 PM KVM reconfigure
29/08/2022 09:57 PM Reinstall OS
29/08/2022 03:32 AM Reinstall OS
24/08/2022 09:40 PM Reboot
24/08/2022 09:38 PM Reinstall OS
17/08/2022 10:11 AM KVM reconfigure
26/07/2022 08:06 AM Reinstall OS
24/07/2022 07:55 AM Reinstall OS
24/07/2022 07:29 AM Reinstall OS
24/07/2022 07:19 AM Reinstall OS
24/07/2022 06:53 AM Reinstall OS
03/07/2022 6:59 AM Reinstall OS
03/07/2022 6:52 AM Reinstall OS
19/09/2022 10:52 PM Reinstall OS
08/08/2022 9:30 PM Reinstall OS
04/08/2022 9:12 PM Unmounted CDROM
04/08/2022 9:11 PM Boot
04/08/2022 9:11 PM Mounted CDROM
02/08/2022 11:26 PM Reinstall OS
02/08/2022 2:50 AM Reinstall OS
02/08/2022 2:31 AM Boot
02/08/2022 2:30 AM Reboot
26/08/2022 11:48 PM Reinstall OS
08/09/2022 11:42 PM Reinstall OS
19/08/2022 11:48 PM Reinstall OS
19/08/2022 11:40 PM Reboot
19/08/2022 11:40 PM Unmounted CDROM
19/08/2022 11:40 PM Mounted CDROM
15/08/2022 05:54 AM Reboot
02/08/2022 11:02 AM Boot
06/07/2022 6:53 PM KVM reconfigure
21/09/2022 05:45 PM Reinstall OS
25/08/2022 11:15 PM Reinstall OS
21/08/2022 11:05 AM Reinstall OS
17/08/2022 01:56 AM Reinstall OS
28/07/2022 08:00 PM Reinstall OS
20/09/2022 06:53 PM Reinstall OS
19/09/2022 01:07 AM Reinstall OS
11/09/2022 6:18 PM Reboot
01/09/2022 4:25 AM Reinstall OS
28/08/2022 06:25 PM Boot
28/08/2022 06:24 PM Hard Power Off
28/08/2022 06:24 PM Shutdown
28/08/2022 06:14 PM Reinstall OS
28/08/2022 06:13 PM Boot
21/08/2022 07:38 PM Boot
21/08/2022 07:37 PM Unmounted CDROM
21/08/2022 07:37 PM Change Boot Order
14/08/2022 10:10 PM Reboot
14/08/2022 09:50 PM Reinstall OS
14/08/2022 09:49 PM Reboot
14/08/2022 09:43 PM Reinstall OS
14/08/2022 09:42 PM Boot
14/08/2022 09:41 PM Reinstall OS
14/08/2022 09:41 PM Shutdown
14/08/2022 09:41 PM Unmounted CDROM
14/08/2022 09:41 PM Change Boot Order
14/08/2022 09:40 PM Hard Power Off
14/08/2022 09:38 PM Reinstall OS
@VirMach said:
Honestly I'm just waiting for someone to quote it and ask an unrelated question.
Let me be first (without quoting)
It's long monthly log and I know it's just 40% as you said, but seriously, does five reinstalls, four reboots and some unmounting or changing boot order (not by a single client, but all together) in a whole day kill server performance? :P
Ok, some days are more busy, some less, but that's expected as those servers are provisioned for most clients in the same period.
TBH, If I'm trying something out, I've seen me doing multi-installs within an hour. Sometimes I need to boot into rescue to fix stuff too. I can envisage a problem if folks are doing the same thing, all at the same time, otherwise...
Ok, some days are more busy, some less, but that's expected as those servers are provisioned for most clients at the same day.
A re-install while the disk is away causes the LVM to get deleted and not re-created per SolusVM coding. Even if the disk is functional there are times where several commands in a row cause it to glitch out completely.
In other regions, this would usually not be a problem because the first solution to I/O errors usually isn't spamming an average of like 30 buttons. I'm just surprised 40% of the people on the node actually did that, especially since this was one of the first nodes on Japan and we already had to go through one round of recreations as a result. And I'm surprised I didn't catch on quicker. Maybe it was on the back of my mind but I guess I refused to believe 40% of the people on the node would participate in the frantic button clicking and re-installs as the default solution.
I mean at the same time it can be a good thing, it means if the disk was actually lost, almost no one would care since it's probably just running a VPN and not important data. I just wouldn't have guessed 40% of the people on the node would have done it. And it's not even that 40% did it, it's more like 95% of the people that were on the disk that dropped off and then of course a portion of that were from Ryzen migrates back and forth. We definitely need to stop it from being a possibility though.
@VirMach said:
Okay, TYOC040 LVMs have been regenerated. Feel free to resume spam re-installs.
no permanent solution?
Since the original maintenance (not the original original but the most recent one before this round) it's already been stable again. And anyone who didn't re-install would have returned online since then. There's a few other cases where it could have happened as well but I'd say almost everyone who was offline was basically offline this whole time because they re-installed sometime around August 12th and 22nd maybe. Could be some other time, but around there.
I guess only re-install when necessary and not as a solution to your problems, if you know you previously had a functional OS, especially don't do it to fix I/O issues, and we'll probably work on preventing people from doing it if the node is facing potential disk anomalies (until they edit the disabled button and do it anyway.)
As for on SolusVM directly I don't think there's much we can do.
@foitin said: I'm shocked that you allow copyright stuffs from Japan hosted on domestic severs. real bold move
Even doujinshi (fanmade) adult manga/douga is the object of investigation (CP regulation and copyright infringements)
Someone reports to the police and your upstream will cut your connection even your contract.
one keyword for you: manga-mura (漫画村) which I believe is not even 100% hentai
no,h@h only works for e-hentai,it handles DMCA and cp.
edit:to load pictures from a h@h server,you need to open e-hentai,then e-hentai assign a h@h node that has this picture,and you get the url,url is long,and the hostname will change(maybe after reboot),so i don't think it is a "public" service
edit2:so owner will just send DMCA to ehentai,not to a random h@h server
@VirMach said: ait so does it work with a big disk and then a smaller disk as cache? Because that would make sense and how people should be setting these up. It's like if
yes,i think it will has some "trending" file,maybe we can put it into cache(even ramdisk...)
can anyone recommend a cache software that can mount(like rclone)
and,i am storing all my H@H files in my google drive,but team drive only allow to save 500000 files.anyone know what software can put bunch small files into a block?(for example,many files put into a 4MB block file)
My DALZ005 changed ip in control panel but as I installed ubuntu 20.04 server from iso, it looks like IP refused to change nor primaty not 2nd one work, reconfigure network did not help
I tried VNC but for some reason turboVNC shot corrupted screen (you can see ubuntu boot but then it get corrupted) i need too see how to fix that first
I never have an issue with HTML VNC in the SolusVM control panel. Occasionally I use SSVNC/Remmina (Linux, of course) - primarily for copy/paste and screen resolution reasons.
I mostly use ISO installs and manual network configuration, so don't have the expectation that SolusVM will correctly reconfigure the IP addresses.
Yeah I seen it, maybe network IPs are not yet "online"
VNC worked fine for me for system reinstall but looks like the ubuntu 20.04 server I installed have some issue with VNC, I tried few clients all show black screen and color garbage in top of screen
I'm facing issues both on TYOC002S and TYOC026.
On TYOC002S, my server was suspended on 9/26. However, I don't think I could use up 20TB traffic. The statistics on SolusVM also shows that I didn't use much traffic after the initial setup process.
On TYOC026, suddenly ssh requires password for me, and I tried to reboot in SolusVM. Then the boot disk has gone. I'm not sure if TYOC026 is in maintenance now.
@VirMach said: if you know you previously had a functional OS, especially don't do it to fix I/O issues, and we'll probably work on preventing people from doing it if the node is facing potential disk anomalies (until they edit the disabled button and do it anyway.)
That is like counter-intuitive to me. I know I had working system, but one of the disk failed, you fixed that (networkstatus), I don't really need old files - I will just reinstall. I would really expect that this mythical LVM you talking about that and I have no idea what it is (I just press buttons in panel, duh) was fixed along the disk and reinstall would just work.
Especially when support is overwhelmed and take weeks to answer - reinstalling system seems like 'safe & correct' way to go before engaging Support - it should place me on other disk or on this fixed one or somethingsomething. No one knows SolusVM is 10+ years old piece of crap that takes years to make sense.
You can't really be mad a people for trying to reinstall. You can be mad for people spamming reinstall every minute ;')
14/08/2022 09:13 PM Reboot
14/08/2022 10:33 AM Reboot
14/08/2022 10:31 AM Reboot
14/08/2022 10:25 AM Reboot
14/08/2022 10:20 AM Boot
14/08/2022 10:20 AM Hard Power Off
14/08/2022 10:19 AM Shutdown
24/09/2022 05:48 PM Disable rescue mode
24/09/2022 05:48 PM Reboot
24/09/2022 05:31 PM Enable rescue mode
24/09/2022 05:31 PM Reboot
24/09/2022 05:30 PM Hard Power Off
24/09/2022 05:28 PM KVM reconfigure
24/09/2022 05:27 PM Reinstall OS
24/09/2022 05:26 PM Reboot
24/09/2022 05:24 PM Boot
24/09/2022 05:23 PM Change Boot Order
24/09/2022 05:21 PM Reinstall OS
14/09/2022 01:48 AM Reinstall OS
06/09/2022 6:02 PM Disable rescue mode
06/09/2022 6:02 PM Reboot
26/08/2022 04:29 PM Enable rescue mode
26/08/2022 04:29 PM Reboot
19/08/2022 06:50 AM Boot
19/08/2022 06:50 AM KVM reconfigure
18/08/2022 03:13 AM Reinstall OS
16/08/2022 05:09 AM Disable rescue mode
16/08/2022 05:09 AM Reboot
16/08/2022 05:07 AM Enable rescue mode
16/08/2022 05:07 AM Reboot
16/08/2022 05:05 AM Boot
16/08/2022 05:04 AM Reboot
16/08/2022 05:01 AM Reinstall OS
16/08/2022 04:14 AM Boot
16/08/2022 04:11 AM Reinstall OS
16/08/2022 04:10 AM Reboot
16/08/2022 04:09 AM Change Disk Driver
16/08/2022 04:09 AM Change Boot Order
09/09/2022 12:43 PM Reinstall OS
11/08/2022 6:52 AM Reinstall OS
11/08/2022 6:49 AM Disable rescue mode
11/08/2022 6:49 AM Reboot
11/08/2022 6:45 AM Enable rescue mode
11/08/2022 6:45 AM Reboot
07/08/2022 9:11 AM Reinstall OS
03/08/2022 5:41 AM Reinstall OS
02/08/2022 2:16 AM Reinstall OS
02/08/2022 2:13 AM Boot
02/08/2022 2:08 AM Reinstall OS
01/08/2022 7:03 PM Reinstall OS
01/08/2022 6:30 AM Reinstall OS
25/09/2022 11:11 AM Reinstall OS
02/08/2022 9:02 AM Reinstall OS
08/07/2022 11:22 AM KVM Change Root Password
08/07/2022 11:21 AM Shutdown
08/07/2022 10:19 AM Reinstall OS
08/07/2022 4:47 AM Reinstall OS
08/07/2022 4:44 AM Disable rescue mode
08/07/2022 4:44 AM Reboot
08/07/2022 4:21 AM Enable rescue mode
08/07/2022 4:21 AM Reboot
08/07/2022 4:16 AM Reinstall OS
08/07/2022 4:15 AM Shutdown
08/07/2022 4:13 AM KVM reconfigure
08/07/2022 4:10 AM Reinstall OS
07/07/2022 4:24 AM KVM Change Root Password
07/07/2022 4:12 AM KVM Change Root Password
30/09/2022 07:10 AM Reinstall OS
30/09/2022 03:03 AM Boot
29/09/2022 05:58 AM Reinstall OS
24/09/2022 11:02 PM Reinstall OS
22/09/2022 05:59 AM Reinstall OS
21/09/2022 05:56 AM Reinstall OS
20/09/2022 07:07 AM Boot
20/09/2022 07:04 AM Reinstall OS
19/09/2022 05:06 AM Boot
19/09/2022 05:04 AM Reinstall OS
09/09/2022 10:55 PM Reinstall OS
08/09/2022 6:51 AM Reinstall OS
30/08/2022 05:30 AM Reinstall OS
29/08/2022 05:13 AM Boot
28/08/2022 05:29 AM Boot
27/08/2022 08:58 PM Reinstall OS
26/08/2022 06:15 AM Boot
23/08/2022 06:16 AM Boot
22/08/2022 09:44 AM Boot
22/08/2022 09:40 AM Reinstall OS
22/08/2022 09:40 AM Disable rescue mode
22/08/2022 09:40 AM Reboot
22/08/2022 09:39 AM Boot
22/08/2022 09:36 AM Enable rescue mode
22/08/2022 09:36 AM Reboot
22/08/2022 09:30 AM Reinstall OS
21/08/2022 06:43 AM Reinstall OS
21/08/2022 06:38 AM Reinstall OS
21/08/2022 06:36 AM Boot
21/08/2022 06:33 AM Boot
17/08/2022 08:11 AM Boot
16/08/2022 05:22 AM Boot
15/08/2022 06:11 AM Reboot
15/08/2022 06:07 AM Boot
15/08/2022 06:04 AM Boot
02/08/2022 6:47 AM Reboot
02/08/2022 4:42 AM Boot
02/08/2022 12:01 AM Boot
01/08/2022 9:54 PM Boot
06/07/2022 5:28 AM Reboot
15/09/2022 06:29 AM Reboot
15/09/2022 06:24 AM Reinstall OS
15/09/2022 06:23 AM Boot
02/08/2022 1:35 AM Reinstall OS
02/08/2022 1:35 AM Boot
14/07/2022 11:32 PM Reinstall OS
26/09/2022 06:53 AM Reinstall OS
26/09/2022 06:52 AM Enable rescue mode
26/09/2022 06:52 AM Reboot
26/09/2022 06:51 AM Boot
20/09/2022 12:55 AM Boot
18/08/2022 01:16 AM Reinstall OS
18/08/2022 01:11 AM Boot
14/08/2022 08:29 PM Boot
14/08/2022 08:24 PM Reinstall OS
08/07/2022 7:13 AM Reinstall OS
24/08/2022 06:46 AM Reinstall OS
29/09/2022 07:08 PM Disable rescue mode
29/09/2022 07:08 PM Reboot
29/09/2022 07:06 PM Enable rescue mode
29/09/2022 07:06 PM Reboot
29/09/2022 06:06 AM Reboot
28/09/2022 05:07 PM Reinstall OS
28/09/2022 05:07 PM Change Boot Order
28/09/2022 05:07 PM Unmounted CDROM
28/09/2022 05:06 PM Reboot
28/09/2022 05:06 PM Change Boot Order
28/09/2022 08:28 AM Unmounted CDROM
28/09/2022 08:28 AM Change Boot Order
28/09/2022 08:27 AM Reboot
28/09/2022 08:26 AM Change Boot Order
28/09/2022 12:38 AM Reboot
24/09/2022 01:22 AM Reboot
20/09/2022 05:10 AM Unmounted CDROM
20/09/2022 05:09 AM Reboot
20/09/2022 05:09 AM Change Boot Order
20/09/2022 05:08 AM Reinstall OS
19/09/2022 04:07 AM Reboot
19/09/2022 04:07 AM Change Boot Order
19/09/2022 01:44 AM Change VNC Password
19/09/2022 01:43 AM Change VNC Password
19/09/2022 01:41 AM Disable rescue mode
19/09/2022 01:41 AM Reboot
19/09/2022 01:39 AM Enable rescue mode
19/09/2022 01:39 AM Reboot
19/09/2022 01:37 AM Change Boot Order
19/09/2022 01:35 AM Reboot
19/09/2022 01:35 AM Change Boot Order
19/09/2022 12:21 AM Reinstall OS
19/09/2022 12:21 AM Unmounted CDROM
19/09/2022 12:21 AM Change Boot Order
19/09/2022 12:19 AM Reboot
15/09/2022 11:48 PM Reboot
15/09/2022 04:49 AM Reboot
12/09/2022 6:32 PM Reboot
11/09/2022 5:38 PM Reboot
10/09/2022 11:13 PM Reboot
10/09/2022 5:33 PM Reboot
10/09/2022 7:32 AM Reboot
09/09/2022 5:39 PM Reboot
09/09/2022 8:18 AM Reboot
09/09/2022 1:36 AM Change Boot Order
09/09/2022 1:34 AM Reinstall OS
09/09/2022 1:34 AM Unmounted CDROM
09/09/2022 1:34 AM Change Boot Order
08/09/2022 6:25 PM Reboot
08/09/2022 4:01 AM Reboot
08/09/2022 12:13 AM Reboot
07/09/2022 11:12 PM Reboot
07/09/2022 7:18 PM Reboot
07/09/2022 5:36 PM Reboot
07/09/2022 8:32 AM Reboot
07/09/2022 4:54 AM Reboot
07/09/2022 1:05 AM Reboot
06/09/2022 11:51 PM Reboot
06/09/2022 11:50 PM Change Boot Order
06/09/2022 11:47 PM Reboot
05/09/2022 8:16 PM Reinstall OS
05/09/2022 8:15 PM Unmounted CDROM
05/09/2022 8:15 PM Change Boot Order
05/09/2022 7:28 PM KVM reconfigure
05/09/2022 7:17 PM Reboot
05/09/2022 5:35 PM Reboot
05/09/2022 6:49 AM Reboot
04/09/2022 11:48 PM Reboot
04/09/2022 7:54 PM Reboot
04/09/2022 6:16 PM Reboot
04/09/2022 6:16 PM Change Boot Order
04/09/2022 6:14 PM Reinstall OS
03/09/2022 11:47 PM Disable rescue mode
03/09/2022 11:47 PM Reboot
03/09/2022 11:43 PM Enable rescue mode
03/09/2022 11:43 PM Reboot
03/09/2022 11:41 PM Reinstall OS
03/09/2022 11:40 PM Unmounted CDROM
03/09/2022 11:40 PM Change Boot Order
03/09/2022 10:03 PM Reboot
03/09/2022 9:58 PM Reboot
03/09/2022 6:49 PM Reboot
03/09/2022 5:49 PM Reboot
03/09/2022 5:49 PM Mounted CDROM
03/09/2022 5:49 PM Change Boot Order
03/09/2022 5:47 PM Reboot
03/09/2022 5:46 PM Reinstall OS
03/09/2022 5:46 PM Unmounted CDROM
03/09/2022 5:46 PM Change Boot Order
03/09/2022 5:45 PM Reboot
03/09/2022 5:28 AM Reboot
03/09/2022 5:27 AM Reboot
03/09/2022 5:16 AM Disable rescue mode
03/09/2022 5:16 AM Reboot
03/09/2022 5:11 AM Enable rescue mode
03/09/2022 5:11 AM Reboot
03/09/2022 4:57 AM Change Boot Order
03/09/2022 4:57 AM Unmounted CDROM
03/09/2022 4:57 AM Mounted CDROM
03/09/2022 4:57 AM Reboot
03/09/2022 4:56 AM Unmounted CDROM
03/09/2022 4:56 AM Change Boot Order
03/09/2022 4:54 AM Reinstall OS
03/09/2022 4:52 AM Reboot
02/09/2022 11:26 PM Reboot
02/09/2022 9:39 PM Reboot
02/09/2022 5:44 PM Reboot
02/09/2022 6:48 AM Reboot
01/09/2022 9:50 PM Reboot
01/09/2022 7:37 PM Reboot
01/09/2022 5:49 PM Reboot
01/09/2022 4:44 AM Reboot
01/09/2022 3:27 AM Reboot
31/08/2022 06:12 PM Reboot
31/08/2022 05:35 AM Reboot
31/08/2022 02:52 AM Boot
30/08/2022 08:41 PM Reboot
30/08/2022 08:41 PM Change Boot Order
30/08/2022 08:41 PM Disable rescue mode
30/08/2022 08:38 PM Enable rescue mode
30/08/2022 08:38 PM Reboot
30/08/2022 08:38 PM Unmounted CDROM
30/08/2022 08:38 PM Mounted CDROM
30/08/2022 08:34 PM Disable rescue mode
30/08/2022 08:34 PM Reboot
30/08/2022 08:33 PM Boot
30/08/2022 08:32 PM Hard Power Off
30/08/2022 08:30 PM KVM reconfigure
30/08/2022 08:24 PM Enable rescue mode
30/08/2022 08:24 PM Reboot
30/08/2022 08:21 PM Disable rescue mode
30/08/2022 08:21 PM Reboot
30/08/2022 08:19 PM Enable rescue mode
30/08/2022 08:19 PM Reboot
30/08/2022 08:19 PM Unmounted CDROM
30/08/2022 08:19 PM Change Boot Order
30/08/2022 08:15 PM Reboot
30/08/2022 07:45 PM Disable rescue mode
30/08/2022 07:45 PM Reboot
30/08/2022 07:43 PM Enable rescue mode
30/08/2022 07:43 PM Reboot
30/08/2022 07:40 PM KVM reconfigure
30/08/2022 07:40 PM Reboot
30/08/2022 07:39 PM Disable rescue mode
30/08/2022 07:39 PM Reboot
30/08/2022 07:36 PM Enable rescue mode
30/08/2022 07:36 PM Reboot
30/08/2022 07:32 PM Reboot
30/08/2022 07:31 PM Unmounted CDROM
30/08/2022 07:30 PM Reboot
30/08/2022 07:29 PM Mounted CDROM
30/08/2022 07:29 PM Change Boot Order
30/08/2022 06:47 PM Reinstall OS
30/08/2022 06:44 PM Reinstall OS
30/08/2022 06:44 PM Unmounted CDROM
30/08/2022 06:44 PM Change Boot Order
30/08/2022 06:42 PM Reinstall OS
30/08/2022 06:36 PM Change Disk Driver
30/08/2022 06:35 PM Reboot
30/08/2022 06:35 PM Change Boot Order
30/08/2022 06:35 PM Change Disk Driver
30/08/2022 06:34 PM Change Network Card
30/08/2022 06:34 PM Reboot
30/08/2022 06:33 PM Reboot
30/08/2022 06:33 PM Change Network Card
30/08/2022 06:32 PM Disable rescue mode
30/08/2022 06:32 PM Reboot
30/08/2022 06:15 PM Boot
30/08/2022 06:15 PM Hard Power Off
30/08/2022 06:05 PM KVM reconfigure
30/08/2022 06:00 PM Enable rescue mode
30/08/2022 06:00 PM Reboot
30/08/2022 05:59 PM Change VNC Password
30/08/2022 05:58 PM Unmounted CDROM
30/08/2022 05:58 PM Change Boot Order
30/08/2022 05:46 PM Boot
30/08/2022 05:25 AM Reboot
30/08/2022 01:29 AM Reboot
29/08/2022 08:11 PM Reboot
28/08/2022 11:47 PM Boot
28/08/2022 07:57 PM Reboot
28/08/2022 07:23 PM Reboot
28/08/2022 07:13 PM Reboot
28/08/2022 07:13 PM Change Boot Order
28/08/2022 07:13 PM Disable rescue mode
28/08/2022 07:10 PM Reboot
28/08/2022 07:10 PM Change Boot Order
28/08/2022 07:10 PM Unmounted CDROM
28/08/2022 07:09 PM Enable rescue mode
28/08/2022 07:09 PM Reboot
28/08/2022 07:06 PM Reboot
28/08/2022 07:06 PM Change Boot Order
28/08/2022 07:00 PM Reboot
28/08/2022 06:57 PM Reboot
28/08/2022 06:57 PM Mounted CDROM
28/08/2022 06:57 PM Change Boot Order
28/08/2022 06:37 PM Reinstall OS
28/08/2022 06:22 PM Unmounted CDROM
28/08/2022 06:22 PM Change Boot Order
28/08/2022 06:22 PM Reinstall OS
28/08/2022 06:20 PM Boot
28/08/2022 06:19 PM Hard Power Off
28/08/2022 05:56 PM Boot
28/08/2022 05:56 PM Change Boot Order
28/08/2022 04:45 AM Unmounted CDROM
28/08/2022 04:45 AM Change Boot Order
28/08/2022 04:43 AM Boot
28/08/2022 04:42 AM Change Boot Order
28/08/2022 04:11 AM Disable rescue mode
28/08/2022 04:11 AM Reboot
28/08/2022 04:08 AM Enable rescue mode
28/08/2022 04:08 AM Reboot
28/08/2022 04:06 AM Unmounted CDROM
28/08/2022 04:06 AM Change Boot Order
28/08/2022 04:05 AM Reboot
28/08/2022 04:05 AM Changed Tablet Input Device Se
28/08/2022 04:04 AM Disable rescue mode
28/08/2022 04:04 AM Reboot
28/08/2022 04:02 AM Enable rescue mode
28/08/2022 04:02 AM Reboot
28/08/2022 04:00 AM Disable rescue mode
28/08/2022 04:00 AM Reboot
28/08/2022 03:58 AM Enable rescue mode
28/08/2022 03:58 AM Reboot
28/08/2022 03:57 AM KVM reconfigure
28/08/2022 03:54 AM Changed PAE Settings
28/08/2022 03:53 AM Reinstall OS
28/08/2022 03:52 AM KVM reconfigure
28/08/2022 03:52 AM Unmounted CDROM
28/08/2022 03:52 AM Change Boot Order
28/08/2022 03:52 AM Boot
28/08/2022 03:52 AM Changed Tablet Input Device Se
28/08/2022 03:52 AM Changed PAE Settings
28/08/2022 03:48 AM Boot
28/08/2022 03:48 AM Change Boot Order
28/08/2022 03:47 AM Reinstall OS
28/08/2022 03:46 AM Change Boot Order
28/08/2022 03:46 AM Unmounted CDROM
28/08/2022 03:45 AM Reboot
28/08/2022 03:43 AM Reboot
28/08/2022 03:43 AM Change Boot Order
27/08/2022 11:14 PM Reboot
27/08/2022 05:54 PM Changed Tablet Input Device Se
27/08/2022 05:53 PM Reboot
27/08/2022 05:52 PM Changed Tablet Input Device Se
27/08/2022 05:49 PM Reboot
27/08/2022 05:48 PM KVM reconfigure
27/08/2022 05:48 PM Change Boot Order
27/08/2022 05:48 PM Unmounted CDROM
27/08/2022 12:00 AM Reboot
26/08/2022 06:20 PM Reboot
25/08/2022 10:56 PM Reboot
25/08/2022 06:17 PM Boot
23/08/2022 11:20 PM Hard Power Off
23/08/2022 10:14 PM Reboot
23/08/2022 06:47 AM Reboot
23/08/2022 05:04 AM Boot
23/08/2022 02:00 AM Reboot
22/08/2022 11:50 PM Reboot
22/08/2022 08:29 PM Reboot
22/08/2022 06:12 AM Reboot
22/08/2022 01:03 AM Boot
22/08/2022 01:02 AM Reboot
21/08/2022 11:39 PM Reboot
21/08/2022 11:38 PM Change Boot Order
21/08/2022 11:38 PM Reboot
21/08/2022 11:35 PM Reboot
21/08/2022 11:35 PM Change Boot Order
21/08/2022 11:35 PM Disable rescue mode
21/08/2022 11:34 PM Boot
21/08/2022 11:31 PM Enable rescue mode
21/08/2022 11:31 PM Reboot
21/08/2022 11:31 PM Unmounted CDROM
21/08/2022 11:31 PM Change Boot Order
21/08/2022 11:31 PM Boot
21/08/2022 11:28 PM Reboot
21/08/2022 11:27 PM Reboot
21/08/2022 11:27 PM Change Boot Order
21/08/2022 05:57 PM KVM reconfigure
21/08/2022 05:49 PM Disable rescue mode
21/08/2022 05:49 PM Reboot
21/08/2022 05:49 PM Reinstall OS
21/08/2022 05:48 PM Boot
21/08/2022 05:47 PM Boot
21/08/2022 05:46 PM Enable rescue mode
21/08/2022 05:46 PM Reboot
21/08/2022 05:45 PM Hard Power Off
21/08/2022 05:43 PM Disable rescue mode
21/08/2022 05:43 PM Reboot
21/08/2022 05:40 PM Reboot
21/08/2022 05:40 PM Unmounted CDROM
21/08/2022 05:40 PM Change Boot Order
21/08/2022 05:39 PM Boot
21/08/2022 05:38 PM Hard Power Off
21/08/2022 05:36 PM Enable rescue mode
21/08/2022 05:36 PM Reboot
21/08/2022 07:10 AM Reinstall OS
21/08/2022 07:08 AM Reboot
21/08/2022 06:36 AM Reboot
21/08/2022 03:39 AM Reboot
21/08/2022 12:19 AM Reboot
21/08/2022 12:18 AM Reboot
21/08/2022 12:17 AM Change Boot Order
21/08/2022 12:17 AM Reboot
20/08/2022 06:52 PM Disable rescue mode
20/08/2022 06:41 PM Enable rescue mode
20/08/2022 06:41 PM Reboot
20/08/2022 06:11 PM Reinstall OS
19/08/2022 06:37 PM Reboot
19/08/2022 06:07 PM Disable rescue mode
19/08/2022 06:07 PM Reboot
19/08/2022 06:05 PM Enable rescue mode
19/08/2022 06:05 PM Reboot
19/08/2022 05:39 PM Reinstall OS
19/08/2022 05:35 PM Reboot
18/08/2022 11:21 PM Change Boot Order
18/08/2022 11:20 PM Reboot
18/08/2022 11:20 PM Change Boot Order
18/08/2022 07:39 PM Disable rescue mode
18/08/2022 07:39 PM Reboot
18/08/2022 07:36 PM Enable rescue mode
18/08/2022 07:36 PM Reboot
18/08/2022 06:02 PM Reinstall OS
17/08/2022 11:35 PM Boot
17/08/2022 08:41 PM Disable rescue mode
17/08/2022 08:41 PM Reboot
17/08/2022 08:38 PM Enable rescue mode
17/08/2022 08:38 PM Reboot
17/08/2022 08:38 PM Change Boot Order
17/08/2022 08:38 PM Unmounted CDROM
17/08/2022 08:35 PM Reboot
17/08/2022 08:34 PM Disable rescue mode
17/08/2022 08:34 PM Reboot
17/08/2022 08:31 PM Reboot
17/08/2022 08:30 PM Enable rescue mode
17/08/2022 08:30 PM Reboot
17/08/2022 08:30 PM Reinstall OS
17/08/2022 01:14 AM Change Boot Order
17/08/2022 01:13 AM Reboot
17/08/2022 01:13 AM Change Boot Order
16/08/2022 06:01 PM Reinstall OS
16/08/2022 01:51 AM Disable rescue mode
16/08/2022 01:51 AM Reboot
16/08/2022 01:49 AM Enable rescue mode
16/08/2022 01:49 AM Reboot
15/08/2022 05:44 PM Reinstall OS
15/08/2022 05:06 AM Disable rescue mode
15/08/2022 05:06 AM Reboot
15/08/2022 05:05 AM Unmounted CDROM
15/08/2022 05:05 AM Change Boot Order
15/08/2022 05:03 AM Reboot
15/08/2022 05:03 AM Change Boot Order
15/08/2022 05:03 AM Reinstall OS
15/08/2022 05:01 AM Enable rescue mode
15/08/2022 05:01 AM Reboot
15/08/2022 04:59 AM Reboot
15/08/2022 04:57 AM Disable rescue mode
15/08/2022 04:57 AM Reboot
15/08/2022 04:55 AM Reboot
15/08/2022 04:55 AM Change Boot Order
15/08/2022 04:55 AM KVM reconfigure
15/08/2022 04:54 AM KVM reconfigure
15/08/2022 04:54 AM Hard Power Off
15/08/2022 04:54 AM Reboot
15/08/2022 04:54 AM Change Boot Order
15/08/2022 04:47 AM Reinstall OS
15/08/2022 04:31 AM Enable rescue mode
15/08/2022 04:31 AM Reboot
14/08/2022 08:36 PM Boot
14/08/2022 08:34 PM Shutdown
14/08/2022 07:07 PM Change Boot Order
14/08/2022 07:06 PM Reboot
14/08/2022 07:06 PM Change Boot Order
14/08/2022 07:04 PM Reinstall OS
14/08/2022 07:03 PM Reinstall OS
14/08/2022 07:03 PM Disable rescue mode
14/08/2022 07:03 PM Reboot
14/08/2022 07:01 PM Enable rescue mode
14/08/2022 07:01 PM Reboot
13/08/2022 05:56 PM Reboot
12/08/2022 11:40 PM Reinstall OS
12/08/2022 5:42 PM Reboot
11/08/2022 6:15 PM Change Boot Order
11/08/2022 6:15 PM Unmounted CDROM
11/08/2022 6:14 PM Reboot
11/08/2022 6:14 PM Change Boot Order
11/08/2022 6:09 PM Boot
11/08/2022 6:09 PM Shutdown
11/08/2022 5:59 PM Reinstall OS
11/08/2022 5:59 PM Disable rescue mode
11/08/2022 5:59 PM Reboot
11/08/2022 5:59 PM Change Boot Order
11/08/2022 5:58 PM Boot
11/08/2022 5:58 PM Change Boot Order
11/08/2022 5:57 PM Enable rescue mode
11/08/2022 5:57 PM Reboot
11/08/2022 5:54 PM Reboot
11/08/2022 5:53 PM Reinstall OS
11/08/2022 5:52 PM Disable rescue mode
11/08/2022 5:52 PM Reboot
11/08/2022 5:50 PM KVM reconfigure
11/08/2022 5:44 PM Reboot
11/08/2022 5:44 PM Enable rescue mode
11/08/2022 5:16 PM Reboot
10/08/2022 11:27 PM Change Boot Order
10/08/2022 11:26 PM Change Boot Order
10/08/2022 11:25 PM KVM reconfigure
10/08/2022 11:25 PM Disable rescue mode
10/08/2022 11:25 PM Reboot
10/08/2022 11:22 PM Reboot
10/08/2022 11:22 PM Enable rescue mode
10/08/2022 11:21 PM Reinstall OS
10/08/2022 5:54 PM Reboot
09/08/2022 8:04 PM Changed Tablet Input Device Se
09/08/2022 8:04 PM Changed PAE Settings
09/08/2022 8:04 PM Reboot
09/08/2022 8:04 PM Disable rescue mode
09/08/2022 8:02 PM Boot
09/08/2022 8:01 PM Hard Power Off
09/08/2022 8:01 PM Boot
09/08/2022 8:00 PM Reboot
09/08/2022 8:00 PM Enable rescue mode
09/08/2022 7:57 PM Reinstall OS
09/08/2022 5:48 AM Reboot
08/08/2022 5:25 PM Reinstall OS
08/08/2022 5:25 PM Reboot
07/08/2022 11:08 PM Reboot
07/08/2022 11:08 PM Unmounted CDROM
07/08/2022 11:08 PM Change Boot Order
07/08/2022 11:05 PM Reinstall OS
07/08/2022 5:52 PM Reinstall OS
07/08/2022 5:51 PM Reboot
07/08/2022 1:21 AM Reboot
06/08/2022 5:33 PM Reinstall OS
06/08/2022 1:16 AM Reboot
06/08/2022 1:15 AM Change Boot Order
06/08/2022 1:14 AM Reboot
05/08/2022 11:49 PM Reboot
05/08/2022 5:41 PM Reinstall OS
05/08/2022 5:40 PM Reboot
04/08/2022 9:06 PM Reboot
04/08/2022 5:54 PM Reboot
04/08/2022 7:20 AM Reboot
03/08/2022 11:46 PM Reboot
03/08/2022 5:19 PM Reboot
03/08/2022 5:14 AM Reinstall OS
03/08/2022 5:10 AM Reboot
02/08/2022 11:38 PM Reboot
02/08/2022 8:51 PM Reboot
02/08/2022 6:08 PM Boot
02/08/2022 6:08 PM Shutdown
02/08/2022 5:11 PM Reboot
01/08/2022 5:38 PM Disable rescue mode
01/08/2022 5:38 PM Reboot
01/08/2022 5:35 PM Enable rescue mode
01/08/2022 5:35 PM Reboot
01/08/2022 5:35 PM Reinstall OS
01/08/2022 5:31 PM KVM reconfigure
01/08/2022 5:30 PM Unmounted CDROM
01/08/2022 5:30 PM Change Boot Order
01/08/2022 5:29 PM Reboot
01/08/2022 5:28 PM Change Boot Order
01/08/2022 5:27 PM Boot
26/07/2022 07:27 PM Reboot
26/07/2022 07:27 PM Change Boot Order
26/07/2022 07:27 PM Unmounted CDROM
26/07/2022 07:21 PM Reboot
26/07/2022 07:09 PM Reboot
26/07/2022 07:09 PM Change Boot Order
25/07/2022 11:55 PM Unmounted CDROM
25/07/2022 11:55 PM Change Boot Order
25/07/2022 11:51 PM Reboot
25/07/2022 11:51 PM Change Boot Order
19/07/2022 07:55 AM Reboot
19/07/2022 07:55 AM Change Boot Order
19/07/2022 07:54 AM Unmounted CDROM
19/07/2022 07:46 AM Reboot
19/07/2022 07:46 AM Change Boot Order
06/07/2022 7:07 AM Reboot
06/07/2022 7:07 AM Unmounted CDROM
06/07/2022 7:07 AM Change Boot Order
06/07/2022 6:55 AM Reboot
06/07/2022 6:43 AM Reboot
06/07/2022 6:43 AM Change Boot Order
06/07/2022 6:42 AM Reboot
06/07/2022 6:08 AM Reinstall OS
06/07/2022 6:08 AM Change Boot Order
06/07/2022 6:08 AM Unmounted CDROM
06/07/2022 6:04 AM Reinstall OS
06/07/2022 5:52 AM Reboot
06/07/2022 5:49 AM Reboot
06/07/2022 5:46 AM Reboot
06/07/2022 5:46 AM Change Boot Order
There's this thing called pastebin ;-)
Yeah and another thing called dramatic effect. Hey, I had to scroll through it fair and square so everyone else should too.
so conclusion option #4 nuke these MJJs buying accounts and unorthodox migrations.
and mine is still offline
@VirMach do you plan on starting a service in Nigeria?
Yes, I'm doing well, thank you for asking.
@localhost eejit!
@VirMach double eejit!
Had to resort to PgDn, as getting RSI from mouse wheel (actually trackball).
Do u mean the TYOC035 is the same as TYOC040?
Does anyone else remember when browsers didn't have a minimum size for the scrollbar autoscale or am I implanting false memories in my head?
@Virmach gimme a break! Go drink more coffee.
Ahh, the salient part.
You need a honeypot, you do. Instaban for those who dip their paw in.
@VirMach
Really man? Stop posting large log.
https://microlxc.net/
RTFM: https://billing.virmach.com/serverstatus.php
So, you may/may not get lucky. Do you feel lucky; well, do you?
Just tried pinging the new gateway on DALZ007 - not active yet, it seems.
I have some issues with Ubuntu as a server OS - Debian, thanks.
Time for 035
LVM
you talking about that and I have no idea what it is (I just press buttons in panel, duh) was fixed along the disk and reinstall would just work.Especially when support is overwhelmed and take weeks to answer - reinstalling system seems like 'safe & correct' way to go before engaging Support - it should place me on other disk or on this fixed one or somethingsomething. No one knows SolusVM is 10+ years old piece of crap that takes years to make sense.
