Looking for help to find python shell script examples. Maybe some sort of templates. I'am best at learning by example, so need massive amounts of different examples how people write python scripts for shell.
I know you're most probably looking for some kind of code bundle to download & experiment with but yeah, StackOverflow is the best place to learn from snippets and scripts since in-depth discussions are usually included within the threads.
You could try Copilot. It doesn’t produce perfect code, but it’s excellent for guiding you with the process of getting started with a language, or when exploring an unfamiliar topic.
On a slightly unrelated note, check out Xonsh, it's a shell where you can directly do Python in. I've used it a few times, didn't really kick off but the experience was pleasant.
Worth taking a look if you're planning to do significant amount of work on shell scripts since it can get verbose without shell-isms (e.g. reading stdout after spawning a process is already a few lines).
That's very cool. It's not python, but there's a shell I've been interested in called elvish:
Guys, I know that there is python guru's out here. Please help, because I'am in a corner:
#!/usr/bin/env python3
from pwd import getpwnam
import subprocess as sp
import shlex
import argparse
import json
from configparser import ConfigParser
from pathlib import Path
import random
import string
import tomli
import os
argument1 = f'setquota -q {username} {self.options.get("q")}M {self.options.get("q")}M {self.options.get("i")} {self.options.get("i")} /'.split(' ')
set_user_quota = sp.run(argument1, capture_output=True, text=True)
Here I receive this error:
Traceback (most recent call last):
File "/root/scripts/./aa.py", line 189, in <module>
instance.set_folders_and_quota(instance.options["username"])
File "/root/scripts/./aa.py", line 121, in set_folders_and_quota
File "/usr/lib/python3.9/subprocess.py", line 505, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib/python3.9/subprocess.py", line 951, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib/python3.9/subprocess.py", line 1823, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'setquota'
What the hell?! Why there is that cryptic error:
I print argument1 and it is nicely formatted string as er subprocess module req:
subprocess.run will just spawn a shell for that command, skimming the manual. TL;DR is that if you can run on your command line, subprocess should pick it up. If it's not in your path for some reason, you should be able to specify the full pathname and have it run happily.
@ahnlak said:
Ahh, I saw popen in the callstack and naively assumed that Python would just call the actual OS popen instead of doing something weird :-)
It's just the name of the main class used in the subprocess module, it's all Python at the top (at least for subprocess.run, emulating execvpe PATH search semantics) then fork-exec at the bottom.
Guys, I need some thoughts how to achieve desired functionality.
Class has X methods, methods run like this:
if __name__ == "__main__":
pid = str(os.getpid())
pidfile = "/tmp/create.pid"
if os.path.isfile(pidfile):
print('{} already exists, exiting'.format(pidfile))
sys.exit()
with open(pidfile, "w") as file:
file.write(pid)
try:
instance = Base()
instance.set_options()
if instance.check_if_site_exists() == True \
or instance.create_user() == False \
or instance.set_folders_and_quota() == False \
or instance.set_db() == False \
or instance.get_info():
log_action("options", 0, 0, json.dumps(Base.options))
print(instance.send_info())
exit(1)
else:
exit(0)
finally:
os.unlink(pidfile)
I need to track each method status. This achieved with true/false.
If method fails, I need to rollback current executed method and all previous methods.
My question: IS there any method in python class which ALWAYS run when method in class is executed? Does init always run or just on class instantiation?
@legendary said: Does init always run or just on class instantiation?
init the constructor only runs once on class instantiation.
@legendary said: IS there any method in python class which ALWAYS run when method in class is executed?
You can do something similar using decorators.
class SomeClass:
def __init__(self):
print("In constructor")
def always_run(func):
def wrapper(*args, **kwargs):
# Do whatever you want to run before calling the method
print("About to call", func.__code__.co_name)
func(*args, **kwargs)
# Do whatever you want to run after returning from the call
print("Returing after call to", func.__code__.co_name)
return wrapper
@always_run
def method1(self):
"""Decorated Method"""
print("In method1")
def method2(self):
"""Not a decorated Method"""
print("In method2")
sc = SomeClass()
sc.method1()
sc.method2()
Output
In constructor
About to call method1
In method1
Returing after call to method1
In method2
Any function decorated with @always_run will always go through the wrapper function first. You can write your logic in the wrapper.
Web Development & SysAdmin services
Here's a command line hook from a package I made for work:
https://github.com/mwt/crowdmark-labeler/blob/master/clabeler/command_line.py
https://elv.sh/
It also fits into this space between a shell and a traditional programming language.
['setquota', '-u', 'hvkugpalhw', '2048M', '2048M', '20000', '20000', '/']
That's not very cryptic; it's telling you it can't find the 'setquota' command you're asking it to run.
Yes! This is it. But it is so strange. I thought that subprocess looking for file or directory with such name. Thank you my beautiful man.
subprocess.run
will just spawn a shell for that command, skimming the manual. TL;DR is that if you can run on your command line, subprocess should pick it up. If it's not in your path for some reason, you should be able to specify the full pathname and have it run happily.That's as verbose as you can get, I have no idea how to make that error message better.
Hint:
subprocess.run
doesn't use $PATH (apparently it does, since it uses anexecvpe
-like implementation underneath), also RTFMAhh, I saw
popen
in the callstack and naively assumed that Python would just call the actual OSpopen
instead of doing something weird :-)It's just the name of the main class used in the subprocess module, it's all Python at the top (at least for
subprocess.run
, emulatingexecvpe
PATH search semantics) then fork-exec at the bottom.Guys, I need some thoughts how to achieve desired functionality.
init
the constructor only runs once on class instantiation.You can do something similar using decorators.
Output
@always_run
will always go through the wrapper function first. You can write your logic in the wrapper.The keyword you're looking for is Aspects/Aspect Oriented Programming. Python probably had a pythonic equivalent that I don't know about.
But aspects are generally for auxiliary tasks (instrumentation, logging, metrics) not critical functionality.
Seeing you're relatively new to this I implore you to explain in more detail what you're trying to achieve so people can suggest better alternatives.
Only on class instantiation.
