root@1117:~# ip -6 neigh
fe80::b0ab:3bff:fe28:611a dev eth0 lladdr b2:ab:3b:28:61:1a STALE
2a05:4140:3::474 dev eth0 lladdr b2:ab:3b:28:61:1a STALE
2a05:4140:3::1 dev eth0 FAILED
This suggests you have link-local addresses enabled.
Your container may transmit Neighbor Solicitation for the gateway's address, using link-local address as the source address.
If ebtables blocks link-local addresses, the Neighbor Solicitation cannot go out, and you see FAILED.
Even that, sometimes the provider's router doesn't respond to Neighbor Solicitation quickly.
Since the router replacement rarely happens, I can statically save a Neighbor entry too.
; /etc/systemd/system/ip6neigh-router.service
[Unit]
Description=Set ip neigh entry for IPv6 router
After=network-online.target
Wants=network-online.target
[Service]
Type=oneshot
ExecStart=ip neigh replace 2001:db8:0:100::1 lladdr 00:19:a9:5e:2c:00 nud noarp dev uplink
[Install]
WantedBy=multi-user.target
After all these, if it still doesn't work, there's nothing more you can fix, and it must be provider's fault.
@ehab said: @yoursunny change your profile pic to what you look like now..... i am tired of this kid pic..... and it makes me feel like your grandpapa.
However, this outfit is falling apart after 12 years of abuse (including bushwhacking and rolling in the mud), so this practice may not continue for long.
may you have long youth... and health... and lots of sex.
We're moving finally. After 3 weeks of going back and forth they found and issue, internal router is acting up. For now they are able to "restart" IPv6 connectivity, it work for some short time... and then just die.
Although we established in this thread that it's not issue on my side and he confimed it with "internal router issue", I refuse to log into vps before I won't be sure that IPv6 work properly. Right now it's down on the both servers (ping.pe and uptimemonitor check).
Damn frustrating, but at least he won't blame me for broke it some time I hope... This can be really annoying. Especially with newly re-installed vps I didn't even touch yet.
root@pushups:~# ping6 ipv6.google.com
PING ipv6.google.com(mil04s43-in-x0e.1e100.net (2a00:1450:4002:402::200e)) 56 data bytes
From xxx: icmp_seq=1 Destination unreachable: Address unreachable
it resolves dns but does not route ? what can be the problem ... gateway is set statically. What can be the problem?
interface ip6 is up
root@pushups:~# ping6 -c 1 ::1
PING ::1(::1) 56 data bytes
64 bytes from ::1: icmp_seq=1 ttl=64 time=0.042 ms
--- ::1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.042/0.042/0.042/0.000 ms
but does not route outside?
@stevewatson301 maybe same network works, i will pm you ip6 of the vps to check if same network works.
Some of Google's CDN servers don't respond to ping/ping6.
I can't ping ipv6.google.com (mil04s51-in-x0e.1e100.net) from one of my servers, but everything works fine.
hilarious find .... this guy is funny even with all the stereo types he portrays. Already saw some 20min of worst hotel and all the time i was thinking of hostsolutions in romain if you recall marius ....
if I reboot VPS (via control panel, I won't log in until this get fixed) sometimes IPv6 come back on the reboot, sometimes don't. Quick reboot don't kill it always.
if I power down VPS and after some minute or less power it up IPv6 mostly don't come back. It stays dead.
if I don't do anything IPv6 die by itself after some time, after few hours of downtime come back for few minutes (or they started it manually? - I don't know what's the reason for IPv6 coming back around the same time for both VPSes), and then die again.
That's how it looks like:
(I was sleeping those last 8 hours, no reboots from me, it was dying by itself)
I am not very optimistic about them able to fix issue and they of course don't want to hear anything about parting ways and refund. I have two yearly VPSes with them, one paid full price and the other discounted (from LES offer). Situation is identical on the both.
I decided to give them some more time (not because I am eager to stay with them as I lost all the confidence about their competence, but because I don't like nasty endings), but if they won't be able o fix it in the next few days I will most likely open case with paypal anyway. Soon it will be month over since this started. That's some impressive long time for a "datacenter" to deal with issue like that without being able to fix it.
@ralf said:
I find it very strange that a hosting provider with their own datacentre who's been running their business since 2008 seems to only have the sysadmin skills of someone who started a few months ago...
Crowdfund this outfit to be repaired, it should continue
Yes, but he can't get into the datacenter if all his clothes are in the wardrobe aswell. Please don't be so unreasonable.
This tank top looks almost identical.
Are you gonna send me one?
Well, it sucks, because I can imagine how helpless this guy feel. He need service he paid for in a timely manner within industry standards, not in some unspecific distant future.
My issue isn't resolved yet however it seems like it will be in the next two days hopefully.
After going back and forth for another two weeks, Luca finally respondend with deadline and promised refund if things won't be resolved until 4.10.2022. I see this deadline as progress, because finally I have more than just permanent "we're working at it, it will be fixed soon".
So lets wait and see if he will keep his word.
They have a 90 days waiting period .. check that other forum for more details
hostEONS.com - Premium Ryzen VPS, Budget SSD KVM and OpenVZ7 VPS in LA, NY, Jacksonville - Florida, Las Vegas, Dalla, Direct Admin LiteSpeed SSD Web Hosting, etc.. Free Blesta License, Direct Admin License, Windows 2019 License and more
@Mumbly said: promised refund if things won't be resolved until 4.10.2022. I see this deadline as progress
More like ticket closed as resolved
Quick update on 4.10.2022 deadline (as that's right thing to do).
I was curious how will things play out today without much faith in them, but miraculously after one month and one week IPv6 started to work.
ping.pe (with slow 20s interval) show some little packetloss (approx 3 - 4%, not enough to disconnect Irssi, I parked solely for uptime check), but generally looking IPv6 finally work. They also adjusted VPSes expiration date for one month as this last month both VPSes served solely for IPv6 troubleshooting.
Again big thanks to @ehab and @stevewatson301 for answering my call for help as things started to move into the right direction from there on. This issue seems resolved now and I hope it stay that way.
Thanks @Mumbly for your cooperation. I apologize for the problem you encountered.
C1V Hosting is a leading data center, cloud, hosting, and connectivity provider based in Italy. Our state-of-the-art datacenter is located in Pomezia (Rome) and offers a range of services including VPS, dedicated servers, colocation, and connectivity solutions.
i didn't know @c1vhosting is here.
kindly fix ipv6 or refund Mumbly if he has the right for a claim.
Normally I use fully static configuration:
The profile picture is part of one's online identify.
You shouldn't change it ever.
https://medium.com/@rrhoover/why-i-never-change-my-profile-pic-72de0daa2785
On certain anniversaries of my profile picture, I re-create it:
This.
Quick update.
The hosting business is like hostel business. Clients want hot water, the landlord shuts it down, etc.
@ehab Check out this channel:
https://m.youtube.com/c/PPPeter1/videos
test with:
curl ipv6.google.com
or traceroute.
keep those finds coming Thank you
Thanks to your recommendation, I've just wasted 2 hours!
Quick update (if someone's curious)
Since yesterday my findings are next:
@ehab @ralf
Check out his Africa series playlist:
https://www.youtube.com/watch?v=JiPKnOyG5zI&list=PLPtu9cNe7fCmbpKMLw2vbm8VMaQUJLJdv
Including the episode when he got malaria.
How dare you come up with those accusations!
Just watched the first few, including the running one. Kind of stupid thing I'd do, except I'd be using my Garmin watch to log the route.
Chris on https://hostingforums.net/
(click picture to see product page)
Pick a proper one not made from plastic bottles and I'll order it for you.
All the gym bros and outdoor hikers know not to wear cotton.
It's either polyester or (very expensive) merino wool.
You might enjoy this thread... https://lowendtalk.com/discussion/181676/c1vhosting-is-scam#latest
I came here to post this.
Powerful Core i9 VPS (aff)| List of all VirMach VPS (aff)
