Post some YABS bench here
1717274767799
    @lapua said:
    how much traffic does one yabs produce?
    is 119 GB possible?
    12:20 418.13 GB of 20 TB Used
    12:23 537.45 GB of 20 TB Used
    on 10G yes
  • @cybertech said:
    is 119 GB possible?
    on 10G yes
    WOW!
  • vyasvyas OGRetired
    is 119 GB possible?
    -r this option reduces the number of iperf locations (Online.net/Clouvider LON+NYC) to lessen bandwidth usage
    Thanked by (1)lapua
  • MasonMason AdministratorOG
    @cybertech said:
    is 119 GB possible?
    on 10G yes
    Can confirm, definitely possible. And because I was curious, here's some back of the napkin math:
    7 IPv4 locations + 7 IPv6 locations = 14 servers
    2 tests (send and recv) per server * 14 servers = 28 tests
    10 seconds per test * 28 tests = 280 seconds
    280 seconds * 10 Gbit per second = 2800 gigabits
    2800 gigabits / 8 bits per byte = 350GB of data
    So the theoretical maximum amount of traffic you could use is 350GB if you are using machine with a 10Gbit link and have a "perfect" 10Gbit connection to every server over IPv4 and v6 (assuming every iperf server is also 10Gbit).
    In reality, you're more likely to average ~1Gbit connections to all the servers even with a 10Gbit link. So I'd expect typical usage to be maybe 1/10th the theoretical max.
    edited October 2022
    @Mason said:
    @cybertech said:
    is 119 GB possible?
    on 10G yes
    was temporarily suspended for exhausting almost all of my 750G bandwidth within less than an hour after running a few times. thats how i know 🤣
    Thanked by (3)Mason lapua hana
    edited October 2022
    @cybertech said:
    @Mason said:
    @cybertech said:
    is 119 GB possible?
    on 10G yes
    It's a wonder that there isn't an effort from providers to boycott YABS yet ;)
    @Mason said:
    @cybertech said:
    @Mason said:
    @cybertech said:
    is 119 GB possible?
    on 10G yes
    then you will see me shaming them like how yoursunny does.
  • @cybertech said:
    @Mason said:
    @cybertech said:
    is 119 GB possible?
    on 10G yes
    freak!
  • Why not make -r the default, and pick servers based on location?
  • @vyas said:
    is 119 GB possible?
    oh! only error with r option!
     curl -sL yabs.sh | bash -r
    Di 11. Okt 21:33:47 CEST 2022
    bash: Zeile 28: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    Warning: locale 'C' not detected. Test outputs may not be parsed correctly.
    bash: Zeile 84: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    bash: Zeile 85: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    bash: Zeile 88: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    bash: Zeile 92: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    bash: Zeile 93: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    Warning: Both IPv4 AND IPv6 connectivity were not detected. Check for DNS issues...
    Uptime     : 0 days, 23 hours, 46 minutes
    Processor  : AMD Ryzen Threadripper 3970X 32-Core Processor
    CPU cores  : 1 @ 3699.944 MHz
    RAM        : 1,9 GiB
    Swap       : 0,0 KiB
    bash: Zeile 234: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    Disk       :
    Kernel     : 5.10.0-18-amd64
    bash: Zeile 256: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
    You do not have write permission in this directory. Switch to an owned directory and re-run the script.
    Exiting...
  • @henix said:
    Limitless host $6/y vps
    Mon 10 Oct 2022 10:20:14 PM EDT
    Uptime     : 39 days, 9 hours, 32 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2643 v2 @ 3.50GHz
    CPU cores  : 1 @ 3499.998 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 987.3 MiB
    Swap       : 512.0 MiB
    Disk       : 9.3 GiB
    Distro     : Debian GNU/Linux 10 (buster)
    Kernel     : 4.19.0-5-amd64
    Read       | 20.18 MB/s    (5.0k) | 222.49 MB/s   (3.4k)
    Write      | 20.20 MB/s    (5.0k) | 223.66 MB/s   (3.4k)
    Total      | 40.38 MB/s   (10.0k) | 446.15 MB/s   (6.9k)
    Read       | 326.18 MB/s    (637) | 358.96 MB/s    (350)
    Write      | 343.51 MB/s    (670) | 382.86 MB/s    (373)
    Total      | 669.69 MB/s   (1.3k) | 741.82 MB/s    (723)
    Clouvider       | London, UK (10G)          | 367 Mbits/sec   | 544 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 754 Mbits/sec
    Hybula          | The Netherlands (40G)     | 493 Mbits/sec   | 718 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 292 Mbits/sec   | 706 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 782 Mbits/sec   | 723 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 812 Mbits/sec   | 740 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 665 Mbits/sec   | 675 Mbits/sec
    Clouvider       | London, UK (10G)          | 553 Mbits/sec   | 777 Mbits/sec
    Online.net      | Paris, FR (10G)           | 519 Mbits/sec   | 738 Mbits/sec
    Hybula          | The Netherlands (40G)     | 565 Mbits/sec   | 703 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 376 Mbits/sec   | 663 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 795 Mbits/sec   | 629 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 791 Mbits/sec   | 806 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 528 Mbits/sec   | 773 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 658
    Multi Core      | 659
    Full Test       | https://browser.geekbench.com/v5/cpu/17872660
    Is this offer still available, i haven't been able to locate
    RTFM :tongue:
    Thanked by (1)lapua
    @lapua said:
    @vyas said:
    is 119 GB possible?
    RAM        : 1,9 GiB
    Swap       : 0,0 KiB
    Disk       :
    Exiting...
    use the command as mentioned in the github page. Best regds
  • @SLMob said:
    RAM        : 987.3 MiB
    Swap       : 512.0 MiB
    Disk       : 9.3 GiB
    Single Core     | 658
    Multi Core      | 659
    no longer available. it was part of their anniversary deal. sold out really quick.
    Thanked by (1)SLMob
  • Re-run of three latest machines now that GB5 is working.
    Link to previous attempt.
    GreenCloudVPS 9999 Birthday RO Bucharest $99 every 3 years
    Wed Oct 12 13:14:08 UTC 2022
    Uptime     : 0 days, 0 hours, 3 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
    CPU cores  : 9 @ 2199.984 MHz
    RAM        : 8.7 GiB
    Swap       : 512.0 MiB
    Disk       : 98.9 GiB
    Kernel     : 5.18.0-0.deb11.4-amd64
    Read       | 111.81 MB/s  (27.9k) | 1.31 GB/s    (20.4k)
    Write      | 112.10 MB/s  (28.0k) | 1.31 GB/s    (20.5k)
    Total      | 223.92 MB/s  (55.9k) | 2.62 GB/s    (41.0k)
    Read       | 1.42 GB/s     (2.7k) | 1.40 GB/s     (1.3k)
    Write      | 1.50 GB/s     (2.9k) | 1.50 GB/s     (1.4k)
    Total      | 2.93 GB/s     (5.7k) | 2.90 GB/s     (2.8k)
    Clouvider       | London, UK (10G)          | 3.12 Gbits/sec  | 3.21 Gbits/sec
    Online.net      | Paris, FR (10G)           | 2.50 Gbits/sec  | 3.92 Gbits/sec
    Hybula          | The Netherlands (40G)     | 4.57 Gbits/sec  | 4.67 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.84 Gbits/sec  | 1.39 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.66 Gbits/sec  | 1.70 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.16 Gbits/sec  | 1.12 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.03 Gbits/sec  | 1.05 Gbits/sec
    Clouvider       | London, UK (10G)          | 4.80 Gbits/sec  | 4.01 Gbits/sec
    Online.net      | Paris, FR (10G)           | 5.87 Gbits/sec  | 4.57 Gbits/sec
    Hybula          | The Netherlands (40G)     | 5.44 Gbits/sec  | 5.28 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.98 Gbits/sec  | 1.36 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.58 Gbits/sec  | 1.66 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.19 Gbits/sec  | 1.19 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 954 Mbits/sec   | 999 Mbits/sec
    Single Core     | 508
    Multi Core      | 3010
    Full Test       | https://browser.geekbench.com/v5/cpu/17903883
    View your YABS here https://yabsdb.com/yabs/zH7VLS9
    GreenCloudVPS 9999 Birthday IL Chicago $99 every 3 years
    Wed Oct 12 13:20:48 UTC 2022
    Uptime     : 0 days, 0 hours, 31 minutes
    CPU cores  : 9 @ 2199.996 MHz
    RAM        : 8.7 GiB
    Swap       : 512.0 MiB
    Disk       : 98.9 GiB
    Read       | 98.81 MB/s   (24.7k) | 1.20 GB/s    (18.7k)
    Write      | 99.07 MB/s   (24.7k) | 1.20 GB/s    (18.8k)
    Total      | 197.89 MB/s  (49.4k) | 2.40 GB/s    (37.5k)
    Read       | 1.77 GB/s     (3.4k) | 1.72 GB/s     (1.6k)
    Write      | 1.86 GB/s     (3.6k) | 1.84 GB/s     (1.8k)
    Total      | 3.64 GB/s     (7.1k) | 3.57 GB/s     (3.4k)
    Clouvider       | London, UK (10G)          | 2.04 Gbits/sec  | 1.62 Gbits/sec
    Online.net      | Paris, FR (10G)           | 2.19 Gbits/sec  | 1.99 Gbits/sec
    Hybula          | The Netherlands (40G)     | 1.91 Gbits/sec  | 1.92 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.05 Gbits/sec  | 951 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 6.39 Gbits/sec  | 4.45 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 3.47 Gbits/sec  | 3.06 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.83 Gbits/sec  | 1.59 Gbits/sec
    Clouvider       | London, UK (10G)          | 2.08 Gbits/sec  | 551 Mbits/sec
    Online.net      | Paris, FR (10G)           | 2.26 Gbits/sec  | 679 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.87 Gbits/sec  | 1.79 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.08 Gbits/sec  | 781 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 4.16 Gbits/sec  | 1.89 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 3.91 Gbits/sec  | 6.15 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 4.04 Gbits/sec  | 3.76 Gbits/sec
    Single Core     | 702
    Multi Core      | 5706
    Full Test       | https://browser.geekbench.com/v5/cpu/17903991
    View your YABS here https://yabsdb.com/yabs/sKyntQy9
    VirMach NVMe2G Phoenix, $0 every month, IPv6 via Route48 Las Vegas
    Wed Oct 12 13:27:37 UTC 2022
    Uptime     : 1 days, 12 hours, 42 minutes
    CPU cores  : 2 @ 3493.434 MHz
    RAM        : 1.9 GiB
    Swap       : 1.5 GiB
    Disk       : 50.0 GiB
    Read       | 135.74 MB/s  (33.9k) | 172.73 MB/s   (2.6k)
    Write      | 136.10 MB/s  (34.0k) | 173.64 MB/s   (2.7k)
    Total      | 271.84 MB/s  (67.9k) | 346.37 MB/s   (5.4k)
    Read       | 1.11 GB/s     (2.1k) | 1.29 GB/s     (1.2k)
    Write      | 1.17 GB/s     (2.2k) | 1.37 GB/s     (1.3k)
    Total      | 2.29 GB/s     (4.4k) | 2.66 GB/s     (2.6k)
    Clouvider       | London, UK (10G)          | 615 Mbits/sec   | 145 Mbits/sec
    Online.net      | Paris, FR (10G)           | 722 Mbits/sec   | busy
    Hybula          | The Netherlands (40G)     | 619 Mbits/sec   | 516 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 627 Mbits/sec   | 179 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 829 Mbits/sec   | 425 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 889 Mbits/sec   | 817 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 904 Mbits/sec   | 891 Mbits/sec
    Clouvider       | London, UK (10G)          | 634 Mbits/sec   | 213 Mbits/sec
    Online.net      | Paris, FR (10G)           | 664 Mbits/sec   | 89.5 Mbits/sec
    Hybula          | The Netherlands (40G)     | 679 Mbits/sec   | 528 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 195 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 785 Mbits/sec   | 176 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 794 Mbits/sec   | 383 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 819 Mbits/sec   | 503 Mbits/sec
    Single Core     | 1024
    Multi Core      | 2013
    Full Test       | https://browser.geekbench.com/v5/cpu/17904129
    View your YABS here https://yabsdb.com/yabs/I5vn6eJ9
    Thanked by (2)SLMob nick_
    RAM        : 8.7 GiB
    Swap       : 512.0 MiB
    Disk       : 98.9 GiB
    Single Core     | 508
    Multi Core      | 3010
    RAM        : 8.7 GiB
    Swap       : 512.0 MiB
    Disk       : 98.9 GiB
    Single Core     | 702
    Multi Core      | 5706
    RAM        : 1.9 GiB
    Swap       : 1.5 GiB
    Disk       : 50.0 GiB
    Single Core     | 1024
    Multi Core      | 2013
    Man, how were you able to get 3 of them?
    Wed Oct 12 06:04:59 PM BST 2022
    Uptime     : 1 days, 14 hours, 3 minutes
    Processor  : AMD EPYC 7543P 32-Core Processor
    CPU cores  : 5 @ 2794.748 MHz
    RAM        : 8.7 GiB
    Swap       : 1024.0 MiB
    Disk       : 96.5 GiB
    Distro     : Ubuntu 22.04.1 LTS
    Kernel     : 5.15.0-50-generic
    Read       | 385.84 MB/s  (96.4k) | 4.63 GB/s    (72.4k)
    Write      | 386.86 MB/s  (96.7k) | 4.66 GB/s    (72.8k)
    Total      | 772.71 MB/s (193.1k) | 9.30 GB/s   (145.3k)
    Read       | 13.89 GB/s   (27.1k) | 16.77 GB/s   (16.3k)
    Write      | 14.63 GB/s   (28.5k) | 17.89 GB/s   (17.4k)
    Total      | 28.53 GB/s   (55.7k) | 34.66 GB/s   (33.8k)
    Clouvider       | London, UK (10G)          | 1.29 Gbits/sec  | 1.84 Gbits/sec
    Online.net      | Paris, FR (10G)           | busy            | busy
    Hybula          | The Netherlands (40G)     | 1.62 Gbits/sec  | 1.71 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 944 Mbits/sec   | 922 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 3.93 Gbits/sec  | 6.48 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 3.44 Gbits/sec  | 9.09 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.05 Gbits/sec  | 4.18 Gbits/sec
    Clouvider       | London, UK (10G)          | 1.30 Gbits/sec  | 1.84 Gbits/sec
    Hybula          | The Netherlands (40G)     | 1.50 Gbits/sec  | 1.65 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.04 Gbits/sec  | 934 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 4.94 Gbits/sec  | 6.03 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 8.16 Gbits/sec  | 8.46 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 3.71 Gbits/sec  | 4.28 Gbits/sec
    Single Core     | 1158
    Multi Core      | 5556
    Full Test       | https://browser.geekbench.com/v5/cpu/17908134
    Thanked by (1)cybertech
  • MaxKVM ADX-2 Singapore ($13)
    Thu Oct 13 10:34:39 AM UTC 2022
    Uptime     : 0 days, 4 hours, 48 minutes
    Processor  : AMD EPYC 7702P 64-Core Processor
    CPU cores  : 1 @ 1999.999 MHz                                                    AES-NI     : ✔ Enabled
    RAM        : 1.9 GiB
    Swap       : 1024.0 MiB
    Disk       : 58.0 GiB
    Read       | 249.36 MB/s  (62.3k) | 1.61 GB/s    (25.2k)
    Write      | 250.01 MB/s  (62.5k) | 1.62 GB/s    (25.3k)
    Total      | 499.38 MB/s (124.8k) | 3.24 GB/s    (50.6k)                                    |                      |
    Read       | 1.92 GB/s     (3.7k) | 2.10 GB/s     (2.0k)
    Write      | 2.02 GB/s     (3.9k) | 2.24 GB/s     (2.1k)
    Total      | 3.94 GB/s     (7.6k) | 4.34 GB/s     (4.2k)
    Clouvider       | London, UK (10G)          | 908 Mbits/sec   | 1.13 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.19 Gbits/sec  | 1.13 Gbits/sec   Hybula          | The Netherlands (40G)     | 932 Mbits/sec   | 989 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 564 Mbits/sec   | 940 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 209 Mbits/sec   | 766 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 241 Mbits/sec   | 837 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 262 Mbits/sec   | 956 Mbits/sec
    Clouvider       | London, UK (10G)          | 693 Mbits/sec   | 730 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 1.04 Gbits/sec
    Hybula          | The Netherlands (40G)     | 634 Mbits/sec   | 670 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.05 Gbits/sec  | 961 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 648 Mbits/sec   | 649 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 715 Mbits/sec   | 826 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 903 Mbits/sec   | 1.03 Gbits/sec
    Single Core     | 934
    Multi Core      | 925
    Full Test       | https://browser.geekbench.com/v5/cpu/17923244
  • My GreenCloud Chicago 2GB Ryzen VPS always gets null-routed during yabs. I'm surprised yoursunny could yabs it.
    App Devtools - Free Online Developer Tools | mp4tomp3.net - MP4 to MP3 Converter
    Virmach AMS with 2 x 1gbps LACP
    BF2021 Special
    12.95 knives / year
    root@AMS-3C3G35GB:~# curl -sL yabs.sh | bash -s -- -4
    Thu 13 Oct 2022 09:51:01 PM EDT
    Uptime     : 0 days, 1 hours, 12 minutes
    CPU cores  : 3 @ 3499.996 MHz
    RAM        : 3.0 GiB
    Swap       : 256.0 MiB
    Disk       : 34.1 GiB
    Kernel     : 5.19.0-2-amd64
    Read       | 443.25 MB/s (110.8k) | 3.93 GB/s    (61.5k)
    Write      | 444.42 MB/s (111.1k) | 3.95 GB/s    (61.8k)
    Total      | 887.68 MB/s (221.9k) | 7.89 GB/s   (123.4k)
    Read       | 4.48 GB/s     (8.7k) | 4.21 GB/s     (4.1k)
    Write      | 4.71 GB/s     (9.2k) | 4.50 GB/s     (4.3k)
    Total      | 9.19 GB/s    (17.9k) | 8.71 GB/s     (8.5k)
    Clouvider       | London, UK (10G)          | 1.87 Gbits/sec  | 933 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.87 Gbits/sec  | 1.61 Gbits/sec
    Hybula          | The Netherlands (40G)     | 1.88 Gbits/sec  | 939 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.72 Gbits/sec  | 431 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.71 Gbits/sec  | 336 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.37 Gbits/sec  | 162 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.16 Gbits/sec  | 399 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 5223
    Multi Core      | 12914
    Full Test       | https://browser.geekbench.com/v4/cpu/16641694
    Thanked by (2)chimichurri lapua
  • Inception Hosting Phoenix Black Friday 2021
    2 GB RAM 2 CPU 50 GB NVMe
    30 euros a year
    I'm considering if I should renew this VPS. Everything has been great but the disk speed isn't as fast as NVMe.
    Fri 14 Oct 2022 01:59:33 AM UTC
    Uptime     : 163 days, 23 hours, 43 minutes
    Processor  : Intel(R) Xeon(R) E-2286G CPU @ 4.00GHz
    CPU cores  : 2 @ 4008.000 MHz
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 48.9 GiB
    Kernel     : 5.10.0-14-amd64
    Read       | 56.83 MB/s   (14.2k) | 246.36 MB/s   (3.8k)
    Write      | 56.92 MB/s   (14.2k) | 247.66 MB/s   (3.8k)
    Total      | 113.75 MB/s  (28.4k) | 494.02 MB/s   (7.7k)
    Read       | 212.88 MB/s    (415) | 259.70 MB/s    (253)
    Write      | 224.20 MB/s    (437) | 276.99 MB/s    (270)
    Total      | 437.08 MB/s    (852) | 536.69 MB/s    (523)
    Clouvider       | London, UK (10G)          | 1.14 Gbits/sec  | 1.10 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.62 Gbits/sec  | busy
    Hybula          | The Netherlands (40G)     | 1.18 Gbits/sec  | 1.20 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 467 Mbits/sec   | 762 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.79 Gbits/sec  | 2.75 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 4.12 Gbits/sec  | 5.42 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.07 Gbits/sec  | 1.29 Gbits/sec
    Clouvider       | London, UK (10G)          | 449 Mbits/sec   | 403 Mbits/sec
    Online.net      | Paris, FR (10G)           | 620 Mbits/sec   | 317 Mbits/sec
    Hybula          | The Netherlands (40G)     | 734 Mbits/sec   | 580 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 500 Mbits/sec   | 411 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 741 Mbits/sec   | 438 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 904 Mbits/sec   | 592 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 756 Mbits/sec   | 394 Mbits/sec
    Single Core     | 864
    Multi Core      | 1248
    Full Test       | https://browser.geekbench.com/v5/cpu/17938000
    Thanked by (2)cybertech chimichurri
  • Vultr Singapore, 2048 MB Intel High Frequency, $12/m
    Sat Oct 15 06:20:47 AM UTC 2022
    Processor  : Intel Core Processor (Skylake, IBRS)
    CPU cores  : 2 @ 3407.998 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 74.9 GiB
    Read       | 372.66 MB/s  (93.1k) | 839.34 MB/s  (13.1k)
    Write      | 373.65 MB/s  (93.4k) | 843.76 MB/s  (13.1k)
    Total      | 746.31 MB/s (186.5k) | 1.68 GB/s    (26.2k)
    Read       | 941.41 MB/s   (1.8k) | 940.48 MB/s    (918)
    Write      | 991.43 MB/s   (1.9k) | 1.00 GB/s      (979)
    Total      | 1.93 GB/s     (3.7k) | 1.94 GB/s     (1.8k)
    Clouvider       | London, UK (10G)          | 834 Mbits/sec   | 1.07 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.11 Gbits/sec  | 1.33 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 527 Mbits/sec   | 894 Mbits/sec
    Single Core     | 1170
    Multi Core      | 2276
    Full Test       | https://browser.geekbench.com/v5/cpu/17962949
    Thanked by (2)chimichurri cybertech
  • Vultr Amsterdam, 2048 MB AMD High Performance, $12/m.
    (Not sure what happened here or why someone would choose these over the Intel ones, see YABS above).
    Sat Oct 15 01:05:21 PM UTC 2022
    Uptime     : 0 days, 0 hours, 18 minutes
    Processor  : AMD EPYC-Rome Processor
    CPU cores  : 1 @ 1996.249 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 46.8 GiB
    Read       | 220.20 MB/s  (55.0k) | 1.31 GB/s    (20.4k)
    Write      | 220.78 MB/s  (55.1k) | 1.31 GB/s    (20.5k)
    Total      | 440.99 MB/s (110.2k) | 2.62 GB/s    (41.0k)
    Read       | 1.58 GB/s     (3.1k) | 554.22 MB/s    (541)
    Write      | 1.67 GB/s     (3.2k) | 591.13 MB/s    (577)
    Total      | 3.25 GB/s     (6.3k) | 1.14 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 228 Mbits/sec   | 2.73 Gbits/sec
    Online.net      | Paris, FR (10G)           | 158 Mbits/sec   | 2.61 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 423 Mbits/sec   | 2.16 Gbits/sec
    Single Core     | 820
    Multi Core      | 810
    Full Test       | https://browser.geekbench.com/v5/cpu/17970026
  • AMD EPYC VDS from Server-Factory
    Sat Oct 15 22:34:08 WIB 2022
    Uptime     : 0 days, 0 hours, 36 minutes
    CPU cores  : 2 @ 1999.999 MHz
    RAM        : 7.6 GiB
    Swap       : 8.0 GiB
    Disk       : 100.0 GiB
    Distro     : AlmaLinux 8.6 (Sky Tiger)
    Kernel     : 4.18.0-372.19.1.el8_6.x86_64
    Read       | 292.30 MB/s  (73.0k) | 3.50 GB/s    (54.7k)
    Write      | 293.07 MB/s  (73.2k) | 3.52 GB/s    (55.0k)
    Total      | 585.38 MB/s (146.3k) | 7.02 GB/s   (109.7k)
    Read       | 4.81 GB/s     (9.4k) | 9.26 GB/s     (9.0k)
    Write      | 5.07 GB/s     (9.9k) | 9.88 GB/s     (9.6k)
    Total      | 9.89 GB/s    (19.3k) | 19.15 GB/s   (18.7k)
    Clouvider       | London, UK (10G)          | 994 Mbits/sec   | 982 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.02 Gbits/sec  | 987 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.04 Gbits/sec  | 990 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 470 Mbits/sec   | 789 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 469 Mbits/sec   | 925 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 216 Mbits/sec   | 592 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 288 Mbits/sec   | 888 Mbits/sec
    Clouvider       | London, UK (10G)          | 1.03 Gbits/sec  | 974 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.03 Gbits/sec  | 972 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.04 Gbits/sec  | 974 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 518 Mbits/sec   | 783 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 412 Mbits/sec   | 916 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 221 Mbits/sec   | 375 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 283 Mbits/sec   | 855 Mbits/sec
  • GreenCloudVPS 9999 birthday special: 9 cores, 9 GB RAM, 99 GB SSD RAID-10, 9 TB monthly transfer, $99 every 3 months, sold out.
    Sat 15 Oct 2022 10:06:12 PM PDT
    Uptime     : 0 days, 1 hours, 54 minutes
    RAM        : 8.7 GiB
    Swap       : 975.0 MiB
    Disk       : 95.9 GiB
    Read       | 123.64 MB/s  (30.9k) | 995.07 MB/s  (15.5k)
    Write      | 123.96 MB/s  (30.9k) | 1.00 GB/s    (15.6k)
    Total      | 247.61 MB/s  (61.9k) | 1.99 GB/s    (31.1k)
    Read       | 1.45 GB/s     (2.8k) | 1.45 GB/s     (1.4k)
    Write      | 1.53 GB/s     (2.9k) | 1.54 GB/s     (1.5k)
    Total      | 2.99 GB/s     (5.8k) | 3.00 GB/s     (2.9k)
    Clouvider       | London, UK (10G)          | 798 Mbits/sec   | 1.32 Gbits/sec
    Online.net      | Paris, FR (10G)           | 754 Mbits/sec   | 1.31 Gbits/sec
    Hybula          | The Netherlands (40G)     | 922 Mbits/sec   | 1.23 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 540 Mbits/sec   | 726 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.53 Gbits/sec  | 3.07 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 3.32 Gbits/sec  | 5.55 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 3.24 Gbits/sec  | 4.05 Gbits/sec
    Clouvider       | London, UK (10G)          | 1.09 Gbits/sec  | 1.19 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.03 Gbits/sec  | 1.26 Gbits/sec
    Hybula          | The Netherlands (40G)     | 1.00 Gbits/sec  | 1.23 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 844 Mbits/sec   | 628 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.44 Gbits/sec  | 3.01 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 5.52 Gbits/sec  | 5.57 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 8.49 Gbits/sec  | 4.61 Gbits/sec
    Single Core     | 710
    Multi Core      | 5597
    Full Test       | https://browser.geekbench.com/v5/cpu/17984735
  • Green Daddy's 9th BIRTHDAY PARTY
    Roughly $7.9/m ($95 - 1 year plan)
    Mon 17 Oct 2022 01:46:11 AM BST
    Uptime     : 4 days, 17 hours, 21 minutes
    Processor  : AMD EPYC 7643 48-Core Processor
    CPU cores  : 4 @ 2299.998 MHz
    RAM        : 5.8 GiB
    Swap       : 3.0 GiB
    Disk       : 2.0 TiB
    Distro     : Ubuntu 20.04.5 LTS
    Kernel     : 5.4.0-28-generic
    Read       | 20.92 MB/s    (5.2k) | 272.35 MB/s   (4.2k)
    Write      | 20.93 MB/s    (5.2k) | 273.78 MB/s   (4.2k)
    Total      | 41.85 MB/s   (10.4k) | 546.13 MB/s   (8.5k)
    Read       | 1.42 GB/s     (2.7k) | 1.61 GB/s     (1.5k)
    Write      | 1.50 GB/s     (2.9k) | 1.72 GB/s     (1.6k)
    Total      | 2.92 GB/s     (5.7k) | 3.34 GB/s     (3.2k)
    Clouvider       | London, UK (10G)          | 991 Mbits/sec   | 1.07 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.24 Gbits/sec  | 1.16 Gbits/sec
    Hybula          | The Netherlands (40G)     | 993 Mbits/sec   | 1.02 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.05 Gbits/sec  | 971 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 705 Mbits/sec   | 743 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 808 Mbits/sec   | 863 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.00 Gbits/sec  | 1.07 Gbits/sec
    Clouvider       | London, UK (10G)          | 1.01 Gbits/sec  | 1.04 Gbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 706 Mbits/sec
    Hybula          | The Netherlands (40G)     | busy            | 684 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.05 Gbits/sec  | 957 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 751 Mbits/sec   | 804 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 813 Mbits/sec   | 780 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 997 Mbits/sec   | 1.07 Gbits/sec
    Single Core     | 1079
    Multi Core      | 3901
    Full Test       | https://browser.geekbench.com/v5/cpu/18003042
  • edited October 2022
    buyvm SLICE 1024 LU
    impressive. not that much suckers in here with such a Single Core value.
    Sun 16 Oct 2022 09:35:06 PM PDT
    Uptime     : 0 days, 0 hours, 0 minutes
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 1 @ 3693.060 MHz
    RAM        : 976.4 MiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Kernel     : 5.10.0-11-amd64
    Read       | 457.09 MB/s (114.2k) | 1.76 GB/s    (27.5k)
    Write      | 458.29 MB/s (114.5k) | 1.77 GB/s    (27.7k)
    Total      | 915.38 MB/s (228.8k) | 3.53 GB/s    (55.2k)
    Read       | 2.05 GB/s     (4.0k) | 2.04 GB/s     (1.9k)
    Write      | 2.16 GB/s     (4.2k) | 2.17 GB/s     (2.1k)
    Total      | 4.22 GB/s     (8.2k) | 4.21 GB/s     (4.1k)
    Clouvider       | London, UK (10G)          | 2.94 Gbits/sec  | 2.61 Gbits/sec
    Online.net      | Paris, FR (10G)           | 3.74 Gbits/sec  | 2.12 Gbits/sec
    Hybula          | The Netherlands (40G)     | 9.28 Gbits/sec  | 5.95 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 2.34 Gbits/sec  | 1.84 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.50 Gbits/sec  | 1.44 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.11 Gbits/sec  | 1.02 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 977 Mbits/sec   | 1.04 Gbits/sec
    Single Core     | 1702
    Multi Core      | 1675
    Speedypage VPS - Singapore - Custom 20g ram
    Mon Oct 17 17:25:00 UTC 2022
    Uptime     : 0 days, 0 hours, 20 minutes
    CPU cores  : 9 @ 3393.624 MHz
    RAM        : 19.5 GiB
    Swap       : 0.0 KiB
    Disk       : 290.7 GiB
    Read       | 459.59 MB/s (114.8k) | 3.14 GB/s    (49.0k)
    Write      | 460.81 MB/s (115.2k) | 3.15 GB/s    (49.3k)
    Total      | 920.40 MB/s (230.1k) | 6.29 GB/s    (98.4k)
    Read       | 3.42 GB/s     (6.6k) | 3.37 GB/s     (3.2k)
    Write      | 3.60 GB/s     (7.0k) | 3.60 GB/s     (3.5k)
    Total      | 7.03 GB/s    (13.7k) | 6.97 GB/s     (6.8k)
    Clouvider       | London, UK (10G)          | 1.02 Gbits/sec  | 241 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.27 Gbits/sec  | busy
    Hybula          | The Netherlands (40G)     | 984 Mbits/sec   | 1.02 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.65 Gbits/sec  | 586 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 592 Mbits/sec   | 625 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 591 Mbits/sec   | 629 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 655 Mbits/sec   | 497 Mbits/sec
    Single Core     | 1519
    Multi Core      | 9626
    Full Test       | https://browser.geekbench.com/v5/cpu/18017831
    BuyVM Luxembourg Ryzen 5900X 1GB and Slab 256GB
    IPv4 and IPv6 Non-premier account
    Tue 18 Oct 2022 12:49:50 AM UTC
    Uptime     : 0 days, 6 hours, 1 minutes
    RAM        : 976.6 MiB
    Swap       : 1024.0 MiB
    Disk       : 270.4 GiB
    Read       | 501.52 MB/s (125.3k) | 1.76 GB/s    (27.5k)
    Write      | 502.85 MB/s (125.7k) | 1.77 GB/s    (27.6k)
    Total      | 1.00 GB/s   (251.0k) | 3.53 GB/s    (55.2k)
    Read       | 2.05 GB/s     (4.0k) | 2.05 GB/s     (2.0k)
    Write      | 2.16 GB/s     (4.2k) | 2.18 GB/s     (2.1k)
    Total      | 4.21 GB/s     (8.2k) | 4.23 GB/s     (4.1k)
    Clouvider       | London, UK (10G)          | 1.11 Gbits/sec  | 967 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.11 Gbits/sec  | 972 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.12 Gbits/sec  | 974 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.05 Gbits/sec  | 482 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.05 Gbits/sec  | 441 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.02 Gbits/sec  | 109 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 844 Mbits/sec   | 304 Mbits/sec
    Clouvider       | London, UK (10G)          | 1.12 Gbits/sec  | 952 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.12 Gbits/sec  | 962 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.12 Gbits/sec  | 962 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.06 Gbits/sec  | 594 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.06 Gbits/sec  | 151 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.01 Gbits/sec  | 129 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.00 Gbits/sec  | 308 Mbits/sec
    Single Core     | 1570
    Multi Core      | 1547
    Full Test       | https://browser.geekbench.com/v5/cpu/18023441
    Thanked by (2)cybertech lapua
  • Speedypage VPS - Singapore - Custom 20g ram
    Added IPv6
    Tue Oct 18 14:23:44 +08 2022
    RAM        : 19.5 GiB
    Swap       : 0.0 KiB
    Disk       : 290.7 GiB
    Read       | 486.72 MB/s (121.6k) | 3.20 GB/s    (50.0k)
    Write      | 488.01 MB/s (122.0k) | 3.21 GB/s    (50.3k)
    Total      | 974.73 MB/s (243.6k) | 6.42 GB/s   (100.3k)
    Read       | 3.17 GB/s     (6.1k) | 3.25 GB/s     (3.1k)
    Write      | 3.34 GB/s     (6.5k) | 3.47 GB/s     (3.3k)
    Total      | 6.51 GB/s    (12.7k) | 6.73 GB/s     (6.5k)
    Clouvider       | London, UK (10G)          | 1.09 Gbits/sec  | 343 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.27 Gbits/sec  | 467 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.01 Gbits/sec  | 1.02 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 212 Kbits/sec
    Clouvider       | NYC, NY, US (10G)         | 588 Mbits/sec   | 593 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 614 Mbits/sec   | 396 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 648 Mbits/sec   | 401 Mbits/sec
    Clouvider       | London, UK (10G)          | 715 Mbits/sec   | 701 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.35 Gbits/sec  | 1.09 Gbits/sec
    Hybula          | The Netherlands (40G)     | 628 Mbits/sec   | 581 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.07 Gbits/sec  | 868 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 676 Mbits/sec   | 391 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 786 Mbits/sec   | 629 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 983 Mbits/sec   | 614 Mbits/sec
    Single Core     | 1518
    Multi Core      | 9607
    Full Test       | https://browser.geekbench.com/v5/cpu/18027499
    Thanked by (2)nick_ cybertech
