Dedicated server with high RAM
skorupionskorupion Services Provider
I'm looking for the following:
2x some E5 (total multicore GB5 score of about 8K and above)
256 GB RAM (Can be DDR3)
1 TB of SSD space
8 TB of HDD space
Whatever bandwidth @ at least 500 Mb/s with the ability to BYOIP or BGP
In Europe (doesn't really matter where)
Price: 150 $ p/m (can pay quarterly or every half a year)
  • DoDeca Core E5 2680 V3-12
    256 GB RAM
    1TB SSD + 10TB HDD
    1Gbps Ports on 5TB BW
    Indian Data Center
    Price: 364 USD/month
    STROMONIC.COM - Web Hosting, Reseller, Managed WP, VPS, GPU & Dedicated Servers!
    Data Centers: India, Finland, Canada, Bulgaria, United States
    Custom Quotation: hello@stromonic.com
    256 GB RAM
    1TB SSD + 10TB HDD
    Indian Data Center
    Think you're way over budget.
    Thanked by (1)Havy
    Yeah plus I'm looking for EU, but still thanks for trying to help
    Thanked by (1)Havy
  • Maybe @HostSlick or @AlexBarakov could do something in this budget?
    Yeah, maybe lets see
  • In OGF there are quite great deals from both of them with 128G RAM and dual E5, worth to check :)
    If you're willing to consider outside of Europe, I can make an intro to ColoCrossing (yes, I know... but they are the only ones I know who can meet your prices)
    Already work with Readydedis, so I can get those. Thanks for trying to help anyways!
  • It looks like you can fit that out at Hetzner pretty easily: https://www.hetzner.com/sb?ram_from=256 and add storage.
  • AdvinAdvin Hosting Provider
    edited October 2022
    Heymman Servers does some high RAM servers, I would maybe reach out to them.
    https://www.heymman.com/servers.html
    Never have anything available in Europe
  • LowHostingLowHosting Hosting Provider
    I think we can provide something similar (but not exactly the same config) @skorupion
    LowHosting.com - LowHosting.org
    Either DM the config to me or post it publicly, and let's see it!
  • Hetzner Auction Server + tunnel to BYOIP VPS provider.
  • dfroedfroe Services Provider
    @willie said:
    It looks like you can fit that out at Hetzner pretty easily.
    I don't think Hetzner SB is an option here. Even the most expensive servers don't have Dual CPU and I doubt you can add a second CPU socket.
    Worldstream does have some Dual CPU servers in NL and AFAIK they do BYOIP but requested configurations end far beyond given budget, same applies for Clouvider.
  • williewillie OG
    edited October 2022
    @dfroe said: I don't think Hetzner SB is an option here. Even the most expensive servers don't have Dual CPU and I doubt you can add a second CPU socket.
    I don't know what GB5 benchmark is, but they have some fairly modern 1 socket servers that are probably as fast as older dual socket ones, so I thought maybe that could work for you. I was more doubtful about BYOIP. Idk if they support that, even for colo servers. I was amazed at how inexpensive high-ram servers have gotten. on SB. There are also lots of 128GB options if you can live with that.
    You could also look here: https://www.scaleway.com/en/pricing/?tags=baremetal,available
    In the end, I'll most likely go with https://active-servers.com/
    Thank you all of the help!
  • CalinCalin Hosting Provider
    edited October 2022
    Hello @skorupion it s possible give you
    2x e5-2680 v2
    256 GB Ram ddr3
    12 TB HDD
    1 GBps port @ 40 TB Bw
    For 95 eur/month
    Please contact me on PM for this offerts
    Regards,
    Calin
    2x e5-2680 v2
    256 GB Ram ddr3
    12 TB HDD
    For 95 eur/month
    Regards,
    Calin
    DM'd
  • @skorupion said:
    DM'd
    The end is nigh.
    Thanked by (3)yoursunny krlynze Falzo
    @stevewatson301 said:
    The end is nigh.
    Nah I'm making sure he finally colocated his servers in a professional datacenter
    Hello @skorupion i m own data center , we recently moved into a fairly decent new facility
    Regards,
    Calin
    Thanked by (1)skorupion
    Regards,
    Calin
    No more wooden racks?
    @fluttershy no :) it s metal racks
    Woah fancy! Still in your home or did you move to an actual facility?
    It s real facility and please no off topic :)
    Could you please share more information about it? Where it is located?
    Thanked by (2)fluttershy pikachu
    @TeYroX Hello , facility it s situated on Romania Country , Hunedoara County , Orastie City , Transilvania Region
    Regards,
    Calin
    edited October 2022
    From Calin
  • @skorupion said: From Calin
    Which datacenter is it, exactly? Because his metal racks could be in his home, located in Orastie.
