openvpn script
Hello, i buy a server with preinstall openvpn
but after install this script how access to config? i just have SSH and xrdp remote desktop
  • edited October 2022
    You need to either downfload cert file (via sftp) either copy/paste cert files content and save it to your computer (and then import it to your OpenVPN client).
    Second part isn't that ideal as some blank spaces or something may cause issue, so the download is the way to go.
    For SFTP use some free client as Filezilla and enter same IP/port/password as for SSH. Depend from what script you used, your certs may be in one configuraton file with .ovpn extension.
    Don't forget to install OpenVPN client on your local computer and import cert / .ovpn file to the vpn client.
    Thanked by (1)moh3en
    thank you for info but after install how access this config? where is it in ubuntu?
  • TheDPTheDP OG
    edited October 2022
    Take a look in /etc/openvpn maybe?
    I don't know where your script saved it. Did you check in root directory? ls -all
    Try command: find . -name *.ovpn as a root
  • @moh3en said: thank you for info but after install how access this config? where is it in ubuntu?
    You should ask your provider or read theirs Knowledge database/FAQ/e-mails. Preinstalled OpenVPN is not something happening by default so the image you installed was probably created/adjusted by your provider and they have all the info somewhere on theirs website, welcome e-mails etc.
  • He's not most clear about all this, so it's more or less just guessing. He's talking about preinstalled openvpn and then about some script install, so I assume that it's something like Nyr's openvpn-install.sh script which put .ovpn file in root dir.
    yes. i have access , and see some folder
    https://prnt.sc/ep5_oXtIY70w
    i install xrdp for remote desktop and goto this folder
    /etc/openvpn/ and see some other folder
    easy-rsa , server , client. but not found .ovpn
    Look in the client folder then for OpenVPN client configuration file(s).
    The server.conf would be OpenVPN's configuration file.
  • @moh3en said: i install xrdp for remote desktop and goto this folder
    Then do what I said.
    ssh to your server
    cd /
    find . -name *.ovpn
    (under the assumption that you're running some sort of linux)
    client folder is empty , no file or subfolder/
    also server folder empty
    how sure Openvpn is ready for use?? maybe not installl correct?
    ssh to your server
    cd /
    find . -name *.ovpn
    root@wiry-cakes:~# find . -name *.ovpn
    ./client.ovpn
    client.ovpn
    This is it. In your root dir just as assumed.
    Try find / -name *.ovpn as root.
    If you don't see any *.ovpn files, then it's safe to say that no client files were created - only the installation of OVPN exists.
  • @Mumbly said:
    client.ovpn
    where save it? and how see info this file for transfer to client
  • He found it :p
    Read my first post above!
    1. download client.ovpn to your computer
    2. import it to your OpenVPN client installed on your computer
  • I think we need to go from the beginning.
    1. Use some free sftp program like Filezilla or WinSCP and log in as root (same IP, port and root password as SSH) and simply download client.ovpn to your computer
    2. Install on your computer OpenVPN client (google for: OpenVPN Connect v3)
    3. Run OpenVPN client on your computer and click left on the top "Import profile" then "File" and browse/load previously downloaded client.ovpn
  • You can use @Nyr's automated script for installing OpenVPN.
    https://github.com/Nyr/openvpn-install
