[LES] Route IPv6 to VPN client
Hi,
I got several cheap VZ7 NAT VPS from Inception hosting and I'm running Wireguard-go on them.
Given that I don't have a static IP @home, I want to tunnel one/multiple of the public IPv6 addresses of my Inceptionhosting IPv6 subnet to my Clients@home.
Since I don't have a full /64 I wonder if that's even possible?
I'd have to use ndppd, since its also not routed, but can I use it with a smaller than /64 subnet?
Thanks!
You could get a /48 from HE and ndppd it, but as I am aware, ndppd and/or radvd wont work with less then /64.
But you can tunnel each IPv6 by itself without ndppd.
Like I did here on Proxmox:
https://wiki.x8e.net/doku.php?id=proxmox_ipv6
You can do IPv6 NAT with iptables. Use a private subnet and route that to one of your public IPv6.
While incredibly useful, I liken this to most actually-knowledgeable auto bits on YouTube. "Hole in the block? Just drop the engine and replace it."
P.S. If there's a hole in the block, unless it's really new and cheap, it's time to just let it go.
Personally, I run a 6in4 via OpenWRT. Sucks that HE gets blocked semi-often for stuff, but it lets me work well enough that I can, well, work.
Is it possible to avoid NAT and directly route the public v6 to the client and configure it on the client?
https://v6node.com
ip -6 route add 2001:db8::1/128 via (your wireguard tunnel endpoint)
It's possible.
Thanks!
Is there any configuration on the client needed?
Additional routes or configuring the IP?
https://v6node.com
On the other side of the tunnel, you'll need to point default route toward the tunnel or else two way communication won't work.
