Adguard - DNS Amplification Issues - HELP ( SOS )
2»
  • Am I reading this right that you can set up wireguard to filter all DNS queries from adguardhome? I know you can use wireguard to browse and whatever using adguard recursively with argo tunnel. If it is possible to point adguard at a wiregaurd network, I would love to know how. Many thanks!
    1. install wireguard, use Nyr/wireguard-install, write down your host IP (like 10.7.0.1)
    2. install adguard, make sure to listen at there -> 10.7.0.1
    3. change your wireguard conf file to use DNS at 10.7.0.1
    your config file will looks like this
    [Interface]
    Address = 10.7.0.X/24
    DNS = 10.7.0.1
    PrivateKey = key
    [Peer]
    PublicKey = pubkey
    PresharedKey = key
    AllowedIPs = 0.0.0.0/0, ::/0
    Endpoint = {Server IP}:{Listening port}
    PersistentKeepalive = 25
    this way, as long as wireguard is connected, it'll tell the connection to send dns request to 10.7.0.1, or where your adguard installation at
  • speaking of amplification this just hapens to me recently
    surprised this doesn't mentioned in first page
    https://github.com/AdguardTeam/AdGuardHome/wiki/Configuration
    Anti-DNS amplification features
    ratelimit — DDoS protection, specifies in how many packets per second a client should receive. Anything above that is silently dropped. To disable set 0, default is 20. Safe to disable if DNS server is not available from internet.
    ratelimit_whitelist — If you want exclude some IP addresses from ratelimiting but keep ratelimiting on for others, put them here.
  • edited October 2022
    Perfect! I already had wireguard installed and I checked that it is indeed with the script from Nyr. So it looks like a simple matter of changing the config file to the proper dns IP. And I guess making wireguard run as a service?
    Also I have it set up recursive, so adguard is pointing to 127.0.0.1 currently.
    127.0.0.1:5335 127.0.0.1:5053 127.0.0.1:8053
    The wg0.conf interface address is already 10.7.0.1/24. So I also add the interface DNS address as 10.7.0.1? Here is my current config. I may need to redo. Just let me know.
    `# Do not alter the commented lines
    They are used by wireguard-install
    ENDPOINT - WAN-IP
    [Interface]
    Address = 10.7.0.1/24
    PrivateKey = Private Key
    ListenPort = Port
    BEGIN_PEER
    [Peer]
    PublicKey = Public Key
    PresharedKey = Preshared Key
    AllowedIPs = 10.7.0.2/32
    END_PEER`
    Lastly - Would using cloudflared with this hinder/help? I have a guide that I used to get recursive DNS going with adguardhome/unbound/stubby with cloudflared. The wireguard install was also part of the guide, but did not (to my knowledge) include having queries sent through it.
  • ran out of time to edit and fix the large font - apologies
  • @dankkster said: So it looks like a simple matter of changing the config file to the proper dns IP. And I guess making wireguard run as a service?
    iirc by using the install script, your wireguard server is run as service by default
    @dankkster said: The wg0.conf interface address is already 10.7.0.1/24. So I also add the interface DNS address as 10.7.0.1?
    yeah like that. inside AdGuardHome.yaml you'll see the bind_host config, make sure your 10.7.0.1 is at there so AdGuard will also listen into DNS traffic at there
    dns:
      bind_hosts:
        - 10.7.0.1
        - some other IP
    @dankkster said: Here is my current config. I may need to redo. Just let me know.
    You don't change the wireguard server config at all. in fact, don't change it lol. what you need to modify is the installer script itself
    In this line wireguard-install.sh#L102
    Change that to "AdGuard Self-Host" or something
    then in this line wireguard-install.sh#L134
    change
    dns="94.140.14.14, 94.140.15.15"
    to
    dns="10.7.0.1"
    so the next time you re-run to add the new client, you'll automatically get DNS with 10.7.0.1 by using option 6 that you just modify
    Thanked by (1)lemoncube
  • awesome. I will do that asap!
    in your opinion, would using cloudflared with this hinder/help? I have a guide that I used to get recursive DNS going with adguardhome/unbound/stubby with cloudflared. The wireguard install was also part of the guide, but did not (to my knowledge) include having queries sent through it.
    Just want to know if I need to nix the CF tunnel since I will basically be using... a tunnel lol
    cloudflared probably only useful to manage the web access. IIRC from the documentation cloudflare only proxy traffic that comes to port 80 or 443, never heard / read documentation about it where they also accept DNS/port53 traffic
    Ok, thanks. I have removed the tunnel for now and will try the wireguard option again. It did not work last try.
