-Hatch Eggs
-Sing a Song to it
-Set up a countdown timer before you are required to log in
Sky is the limit . @ehab used to refer to something involving pants (rather, de-panting) but he has moved on from that phase. Maybe because winter is round the corner.
-Hatch Eggs
-Sing a Song to it
-Hatch Eggs
-Sing a Song to it
Countdown timer for ... what?
for how fast the person can read ... check the short youtube link above.
-Hatch Eggs
-Sing a Song to it
@Shot² said:
How does it work, btw? packet inspection?
Kinda, once you confirmed the domain is yours, all incoming DNS packages associated with your domain are forwarded to your VM.
The Feature is available on microLXC since a while.
The dnsProxy feature is now live.
Which means you can run your own DNS server behind NAT.
You just need to register your domain below DNSProxy on the Dashboard.
Afterwards, all DNS packages associated with your domain, will be forwarded to your VM.
so what can i do on it?
-Hatch Eggs
-Sing a Song to it
VPS reviews and benchmarks |
you can ask me anything.... never mind the weather or @vyas huge bald head.
https://youtube.com/shorts/8CxcI8soxYA?feature=share
quite humorous!
Maintenance announcement.
The VPS which the website runs on, needs to swap IP's.
Due to the nature of swapping ip's and dns propagation delays, this will cause some downtime.
This will be done on Friday at around 20:00 GMT this week, so you know when the website might not load.
Another maintenance announcement will follow regarding upgrading the PHP version.
This isn't reddit you dingdong
9772addb93453c5db47f738c14cb0a0a170329d0
Deployed
Sorry wrong thread
https://microlxc.net/
Would be anyone interested in porting the DNS proxy feature to NanoKVM?
So you can run your own dns server on Port 53 if you want.
That would be interesting.
Happy new year! @Neoon Nice offer, with some luck I'll qualify next year :-)
I added some stock to CDA Idaho, who wants can apply.
More will be added later.
Thanks to https://crunchbits.com/
7229fd54345f3b6499f4816249f235d3b6ee448e
study and various uses
EDIT: I think I was wrong to post here
"From the diamonds nothing is born, from the manure the flowers are born ..."
F. De Andrè --- Free NAT KVM
fc144a1a3b55b227d6b90e3452adac6d31287870
want to use it for dev environment for my php / python apps
Deployed.
Added the dnsproxy integration is done from microlxc.
Actually it comes with improvements I will backport to microlxc.
Should go live later today.
@Fritz @Shot²
Hi @Neoon
Thanks for this update. Two quick questions:
1. Is this applicable only to NanoKVM ?
2. What DNS ports are forwarded to VM?
microlxc has it since a while.
53, but technically they are not forwarded, they are proxied, same as with HAProxy.
Would be anyone interested in rdns support for IPv6?
yes please
73c8ce7fe337608f5b9653693f8b23f1d8d9f96f
Will be using this for private VPN+uptime Kuma+python experiments
Thanks!
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals on Telegram
Active and helpful on LES? Come grab a free VPS! - FreeVPS.org | How to Apply
You don't meet the 3 months req. yet.
