Finland! NAT VPS' available for paid beta testing now
natvps_uknatvps_uk Hosting Provider
edited November 2022 in Offers
So far the beta has been a success. Now that we've completed automated setup on the MicroNode panel we're going to offer a paid beta:
Micronode nat100m - Our popular NatVPS' come to micronode!
Micronode nat200m - Our popular NatVPS' come to micronode!
Terms:
This product is currently in Beta, in the unlikely event that we decide to not proceed with a launch you will be given a full refund and a UK NATVPS for 12 months.
As this is a beta product you may encounter issues, any downtime will be re-reimbursed as additional time until your next invoice period.
These products are automatically setup providing you pass the fraud check - PLEASE USE ACCURATE DETAILS.
We really appreciate anyone that participates in the Beta, all feedback is appreciated.
Thanked by (3)spiritlhl Ganonk cold
«13
  • @natvps_uk said: You must already be a client with NATVPS UK
    it means i need a natvpsuk account or i also need invoice history?
  • natvps_uknatvps_uk Hosting Provider
    There must have been an active service in the past, either via a purchase or a giveaway.
  • I would like to join, I currently hold a UK node and feel good.
    Thanked by (1)natvps_uk
  • I could do some testing
  • Managed to install NixOS, pretty standard OVZ experience so far.
    A few suggestions:
    1. Serial console in case you fuck something up™
    2. Considering bandwidth is metered, panel should indicate remaining (please double mine)
    Thanked by (3)ehab natvps_uk bdl
    A few suggestions:
    Bandwidth isn't metered - I need to change this.
    Serial console is something we may add if these prove popular, its a fair amount of dev work which we might never see a ROI on.
  • I can do it too, bought one uk instance.
  • edited November 2022
    Please check my account, the server I purchased earlier has disappeared in the background, but I am still able to connect via SSH.
    View Ticket #MJR-361450
  • ehabehab Content Writer
    A few suggestions:
    can you do a
    $ df -h
    mine looks like
    /dev/ploop21210p1 9.7G 379.0M 8.8G 4% /
  • @ehab said:
    can you do a
    $ df -h
    Anything for you @ehab
    Looks like your disk is a few bytes short, mine's:
    /dev/ploop21224p1   15G  1.3G   13G   9% /
    Thanked by (1)ehab
    They are all slightly different sizes, I'm testing ;)
    Thanked by (2)jmgcaguicla ehab
    @jmgcaguicla said:
    thanks a lot... i never used NixOS , why do you use it? your use cases?
  • atomiatomi OG
    package name/specs are wrong in panel since VPS is having 256mb ram
    Specifications:
    NatVPS 100MB
    100m RAM
    Thanked by (1)ehab
    Thats now fixed, if you re-provision you'll end up with 100m. I won't force you as it was my mistake.
    Declarative configuration mainly, so I can version control my infra. Like Ansible-ing your infra, but better.
    For example, to configure fail2ban I just need to add this:
    services.fail2ban = {
      enable = true;
      ignoreIP = [
        # whitelisted ips
        X.X.X.X
        Y.Y.Y.Y
        ZZZZ:ZZZZ:ZZZZ:ZZZZ::
    One great thing about this is all configuration is in one place so I only have to back up a handful of files (e.g. when doing backups and restores I don't have to remember that the config files should go to /etc/fail2ban).
    Thanked by (1)ehab
    naah, I'm fine with my 256mb :wink:
    Maybe if you would have AlpineLinux available since it has a small memory&resource usage
    i have a script here
    https://gist.github.com/ehab2012/304e11cccd1683099d899e28ab6c4941
    first make sure you do before running script
    apt-get install curl wget xz-utils apt-utils
  • Yea, I used some script in my Webhorizon's natvps. I would like to see AlpineLinux template in every provider who offers NAT VPS packages since its perfect for those
  • What's DC?
    @Mumbly said:
    What's DC?
    Finland : AS51765 Oy Crea Nova Hosting Solution Ltd
    Thanked by (1)Mumbly
    Ah, Creanova... Thanks!
    I had "VDS1-B" (small vps) with them in 2012. The thing which bothered me with Creanova 10 years ago was that IP wasn't geolocated to .FI but .RU or something like that and I wasn't able to use BNC connectivity to .fi ircnet servers while there wasn't any .ru ircnet server, so I cancelled.
    They have at least a decent looking website now :)
    I had "VDS1-B" (vps) with them in 2012. The thing which bothered me with Creanova 10 years ago was that IP wasn't geolocated to .FI but .RU or something like that and I wasn't able to use BNC connectivity to .fi ircnet servers while there wasn't any .ru ircnet server, so I cancelled.
    yeah, i recall years ago they had some offers in LET but wan't convinced its Finland.
    were you always Mumbly? did you have another nic back then?
  • I could do some testing.
    My UK nat invoice id is 300.
    It was Finland however IPs in RIPE database belonged to the RU LIR or something like that (they were subsidiary of russian company) hence services which required IP address from .FI ISPs didn't work.
    The other. I was away for like 5 years or so (I think) and when I came back it was just quickly/temporarily to find some replacements for few super stable but old and outdated 128/256MB VPSes (from securedragon, xenvzco.uk, weservit, prometeus...) and now I am stuck again :s :p
  • looking glass ?
    @cold said:
    looking glass ?
    i am working on a swarm based looking glass... so it might be available soon.
    maybe @natvps_uk if he doesn't have an official LG can provide ips.
    Thanked by (2)cold Janevski
    @cold said:
    looking glass ?
    I'll have one before launch.
    I wanted to see only a ipv4/ipv6
  • someone hammer it with YABS plox
