iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
2456719
  • @Calin said:
    1 vCPU (25% cpu alocated) (please don t abuse cpu and don t usage cpu every time 100% , maximum 40 minutes per day)
    Since when has a day been 160 minutes?
  • Invoice #668
    Thanks for extra RAM.
    Thanked by (1)Ganonk
  • Hello @Calin,I have paid the bill, but it still shows unpaid, please check,Invoice #673, thank you
  • Anyone got the extra RAM yet?
    Why?
  • Invoice #671
    I can't even ssh.
  • @contactwajeeh said:
    Invoice #666
    🥳 congrats Sir
    Thanked by (1)contactwajeeh
  • @dosai said:
    I can't even ssh.
    you probably got wrong ssh port number in welcome e-mail like me. use lowest one from assigned range and you will be able to login
  • @dosai said:
    I can't even ssh.
    Same can't ssh, it says access denied, can't even reinstall
    That reminds me, do they not have a control panel option ?
    Why?
  • edited November 2022
    hi
    Invoice #674
  • Server goes unreachable while running GB5 test.
    Mon Nov  7 04:31:26 EST 2022
    Uptime     : 0 days, 13 hours, 24 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz
    CPU cores  : 1 @ 1200.000 MHz
    AES-NI     : � Enabled
    VM-x/AMD-V : � Enabled
    RAM        : 512.0 MiB
    Swap       : 0.0 KiB
    Disk       : 50.1 GiB
    Distro     : Ubuntu 20.04.5 LTS
    Kernel     : 5.4.0
    Read       | 954.00 KB/s    (238) | 7.74 MB/s      (121)
    Write      | 986.00 KB/s    (246) | 8.16 MB/s      (127)
    Total      | 1.94 MB/s      (484) | 15.90 MB/s     (248)
    Read       | 6.38 MB/s       (12) | 6.92 MB/s        (6)
    Write      | 7.14 MB/s       (13) | 7.34 MB/s        (7)
    Total      | 13.52 MB/s      (25) | 14.26 MB/s      (13)
    Clouvider       | London, UK (10G)          | 34.1 Mbits/sec  | 480 Mbits/sec
    Online.net      | Paris, FR (10G)           | 498 Mbits/sec   | 800 Mbits/sec
    Hybula          | The Netherlands (40G)     | 526 Mbits/sec   | 867 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 456 Mbits/sec   | 365 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 393 Mbits/sec   | 317 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 343 Mbits/sec   | 154 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 257 Mbits/sec   | 183 Mbits/sec
    Why?
  • CalinCalin Hosting Provider
    Hello , regarding the extra ram, after all the vps will be delivered I will check the thread again and add the extra ram memory to everyone. If you have problems with the ssh port, please open a ticket on the site
    @jmaxwell retry now please
    And about control panel only opened ticket on website and it s possible give , for this type of VPS i m usage Virtualizor
    Regards,
    Calin
    Exactly this, it is working now.
    Hello Everyone
    I am facing issues with ports
    I tried to run qbittorrent-nox using command qbittorrent-nox --webui-port=xxx (where xxx is the port(s) assigned to me)
    and none of ports are open. Its saying
    "Web UI: Unable to bind to IP: *, port: xxx. Reason: The address is protected"
    Am I doing something wrong?
    I do not have any experience with NAT VPS. So... please guide me.
    Thank you :)
    @adwsislife said:
    Hello Everyone
    Thank you :)
    If the port is less than 1000 you will need to use sudo or root privilege
    Thanked by (2)adwsislife jmaxwell
  • @Calin can you check GCA-065112 , can't login into ssh it says access denied even when copy pasting the password from email
    Damm. Its working now.
    My ports are 3 digit numbers.
    Thank you :)
    @codelock done , now all good
    Thanked by (1)codelock
    Thanks
    Regards,
    Calin
    Ok thanks for the response. I don’t care about yabs but will open a ticket for control panel access for things like reinstalling OS etc.
    Why?
    Thank you :)
    Could you please share how you installed qbittorrent-nox?
    My setup is not the best but its working fine
    Commands are as below
    1. sudo apt install screen qbittorrent-nox -y
    2. screen -S qbittorrent
    3. qbittorrent-nox --webui-port=xxx (where xxx is the port via which you want to access qbit in browser)
    Note:- As mentioned by @codelock , If your port is less than 1000, you need to use sudo or root privilege with command no. 3
    Once you connect to qbit in browser, go to settings and change download locations as per your needs.
    You can change some other settings as well
    Hope it helps :)
    FYI:- I had referred to below post (server part). Instead of systemd service, I went with screen.
    https://www.linuxbabe.com/ubuntu/install-qbittorrent-ubuntu-18-04-desktop-server
    Thanked by (1)dosai
  • still pending
  • @Calin I don't seem to have ipv6 on my VPS.
    Is this still in the pipeline for these new services or should I open a ticket?
    Thanks!
  • dosaidosai OG
    Hope it helps :)
    Thanks for sharing. For some reason it is not working for me, when I open ip:123 nothing loads.
    sudo qbittorrent-nox --webui-port=123
    ******** Information ********
    To control qBittorrent, access the Web UI at http://localhost:123
    The Web UI administrator username is: admin
    The Web UI administrator password is still the default one: adminadmin
    This is a security risk, please consider changing your password from program preferences.
    Edit: looks like it is listening to ipv6 (which is not available) and this is the problem.
    lsof -i:123
    COMMAND     PID USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
    qbittorre 21990 root   28u  IPv6 6957269      0t0  TCP *:shell (LISTEN)
    Could you please share you ~/.config/qBittorrent/qBittorrent.conf settings?
    You can also use authbind if you don't want to run it as root.
    https://duck.com (aff)
    https://ecosia.org (aff) Plant trees from home.
  • Which one is worse?
    • Clueless provider assigns privileged port to NAT container.
    • Clueless customer runs complex network application as root.
  • @yoursunny said:
    Which one is worse?
    I would say that even worse is other Romanian never ending Clueless™ provider who run BF promo for NAT VPS... and later cancelled all these services :D
    Hello i m finish delivery all vps , and I gave extra ram memory to everyone who left the invoice number
    Thanked by (1)ehab
