A new kind of vps, a proposal for the people of LES
13»
    @legendary said: I would gladly pay even more (~1.99/mo.) for the sake of good quality drama. Majority of us would do the same. When your are in a castle, you need clowns, otherwise it gets boring.
    Or you could just try to convince @Nekki to come out of retirement and put on a real show. He is the legend of Low End Entertainment.
    LES • AboutDonateRulesSupport
    Does this come with free datacenter access unannounced?
    Plus fridge access, in case I need a snack. If so, I will happly prepay 1 year.
    If I am at home yes, can give you coffee or tea and there's also very good takeaway pizza at the side of the house.
    Thanked by (2)skorupion CamoYoshi
    I'm wondering if OVH had pizzeria next to their DC
    Thanked by (3)skorupion imok typicalGta
    T
    There is a fire estinguisher ball to prevent fires.
    Reagrds
    Thanked by (3)ehab FrankZ Dazzle
    I try to stay away from providers that use wood racks, are you planning to upgrade this in the near future?
    Thanked by (1)ralf
    That's not a rack and it's not made of wood
    It's a premium pancake with honeycomb carton inside and laminate at the outside.
    Would you please tell me the reason why using this material worries you? I could send this complaint to RD so that our technicians can check better.
    Don't worry, they're not using wood racks, just wood shelf. Perfectly safe.
    Thanked by (3)FrankZ pikachu TrendyJack
    My worry is that these types of racks with use will sag over time. If you do not have any plans to upgrade your racks, any chance you might consider silicone injection for your current racks if they start sagging ?
  • @foxone said: 5 high quality ports
    Indulge me, what is HIGH QUALITY port?
    It’s a port of HIGH QUALITY as opposed to low quality, what was it about the statement that wasn’t clear to you?
  • @Nekki said: It’s a port of HIGH QUALITY as opposed to low quality, what was it about the statement that wasn’t clear to you?
    Alright chad, I am enlightened.
    All 65535 ports are equal, but some ports are more equal than others I presume.
    @Flying_Chinaman what is your thinking of the meaning when you call people "chad" ?
    Down London way, it's also known as the 'gooch'.
    Posh & alpha dude I suppose. Learned from 4chan long ago
