iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
13468919
  • CalinCalin Hosting Provider
    @hotsnow said:
    @Calin may I ask when the IPv6 can working? thanks
    Hello , don t know exactly i m have same problems :( IPv6 don t working , it s possible try yourself for create IPv6 tunnel?
    Regards,
    Calin
  • edited November 2022
    What's the problem?
    Other providers that have Virtualizor may be able to help.
    It would not be DMCA ignored.
    Unless, you give me a free KVM NAT box?
    Then I can make tunnel there and let all the neighbors use it.
    Thanked by (1)hotsnow
    Regards,
    Calin
    maybe you could propose some compensation for not working IPv6 (i.e. +20GB hard disk space), and it would cut number of complaints by 90% :)
    Thanked by (1)jmaxwell
  • natvps_uknatvps_uk Hosting Provider
    @Calin I can help you solve your ipv6 issues. Happy to help, send me a message.
    Amen. To hell with IPv6
    Why?
    Hello, the issue with IPv6 is as follows
    For the VPS Storage NAT 2 and VPS KVM NAT64 offers we do not use routers, we actually have 1 GBps fiber with FTTH port and we connect that fiber directly to the dedicated server, it is a very good achievement for us and we have much higher performances like this, on in addition to this, we also cut the costs of a router that has an SFP port output
    For VPS KVM NAT64 we use proxmox, and IPv6 is assigned automatically (we want to mention that we have our own dedicated VLAN and our own dedicated ODB just for us, so the configuration is done at our ISP basically we have IPv6 already allocated in our ISP Core
    VPS Storage NAT 2 instead usage Virtualizor with Virtuozzo OS we don't see them, we tried to allocate them through nmtui, with the Manual or Automatic option, even Automatic-DHCP (screenshot about obtions IPv6
    We have the following problems
    In automatic, we don't see anything in ifconfig, even after a reboot
    In Manual, IPv6 is allocated but has no ping and in Automatic (DHCP Only) the connection starts to be lost.
    As I said, it's a very strange problem, if someone has a solution I'm looking forward to it, I want to point out that proxmox allocates IPv6 automatically, I tried this this morning, because of that there was a downtime of about 50 minutes at the VPS Storage NAT 2 according to uptime.ihostart.com
    Regards,
    Calin
    @yoursunny said: It would not be DMCA ignored.
    Hello , yes it s ok , please opened ticket on website and give you
    Regards,
    Calin
    Regards,
    Calin
    do not forget to update your TOS and mention about volunteer network traffic security inspector (before customers start asking about MITM) :D
    and if you need to draw an updated company network diagram you could start from here:
    Thanked by (2)yoursunny chris
    Hello @Andrews I most likely expressed myself wrongly , I don't mean others, I mean to configure it for him and let him use it only he
    Regards,
    Calin
    Does this connection provide on-link IPv6 or routed IPv6?
    If you have routed IPv6 (possibly delivered via IPv6-PD), you may not need a bridge interface (br0) on the WAN side.
    Instead, the bridge interface should be on the LAN side, connected with the containers.
    A limitation of OpenVZ is that, each address must be configured before starting the container.
    It is not possible to run DHCPv6 client inside an OpenVZ container.
    Thats not entirely true, an address can be added after the container has been started however it must be done on the host using the:
    vzctl set <id> --ip <address>
    Or using the equivalent prctl command.
    You do not need to restart the container for this to take effect.
    Regards,
    Calin
    Can I use it aswell, I want yoursunny to see the nudes I'm sending to my wife.
    Saves him renewing the onlyfans subscription!
  • Invoice #696
    thanks!
  • mmmh, node offline?
  • @TrendyJack said:
    mmmh, node offline?
    Container went offline when I'm streaming Young Sheldon, mid episode.
    This is a terrible, horrible, no good, very bad time, because I'm eager to know the outcome.
    Spoiler
    Everybody dies.
    Spoiler
    Well, nobody dies on Young Sheldon.
    Thanked by (1)TrendyJack
  • Sorry guys, i hosted too much "art"
  • @Calin
    Invoice #713
    Thank you.
  • node offline =)
  • The end is nigh.
    Hello everyone , yes little downtime on LV0 (NAT Storage VPS) ISP Problems about ddos attack , in next two hours problems fixed.
    Regards,
    Calin
    Hello again , fixed problems , all working good
    Regards,
    Calin
  • Invoice #722
    Please mark as paid and increase RAM.
    Thanks
  • Is ipv6 available?
  • @TerryX said:
    Is ipv6 available?
    currently not, maybe soon we hope
  • Invoice #727
    Recommended hosts:
    Letbox, Data ideas, Hetzner, DediPath
  • invoice 728 paid 384 MB RAM FREE sir ,thank you very much.
  • I'm waiting for activation, Paypal done, here's mine:
    Invoice #729
  • Invoice #738 awaiting activation
    I upgrade the node to a dedicated network of 10 GBps so today whoever buys this offer has unlimited internet bandwidth (Unlimited internet bandwidth is available now and for those who already have this type of VPS)How is it possible at 50
    cents per month to have the possibility to have a port of 1 GBps unlimited? Simple, because our data center is located in a very small town we invested our own money for upgrades to some dedicated ODB and dedicated backbone/vlan's only for us so now I benefit from very cheap fibers both internally and externally, all VPS's are limited to 1 GBps , after several tests performed you should catch around 300-400 mbit on very busy days and 700 to 800 mbit on non-crowded days
    Regards,
    Calin
    @Calin said: I upgrade the node to a dedicated network of 10 GBps so today whoever buys this offer has unlimited internet bandwidth
    How about ones with 25 eur/year offer? Do we also enjoy the new networking setup?
