30% off Tokyo KVM VPS - NVMe, AntiDDoS
Hi all,
I am here to share a short discount (15 uses maximum) for VPS in Tokyo.
30% off recurring any Tokyo, Japan VPS:
LESTOKYO30
Order:
https://extravm.com/billing/store/kvm-nvme-vps-tokyo-japan-ddos-protected
This brings the 2GB RAM VPS to $7/m and 1GB RAM to $4.55/m.
$7/m
2GB DDR4 RAM
2 Cores E-2388G CPU
RAID NVMe SSD Space
10TB Bandwidth (Throttle after limit)
10Gbps ↓ 1Gbps ↑
1 IPv4, 1 IPv6
DDoS Protection
VirtFusion Control Panel
Included Backups
Tokyo, Japan
Plans range from 1GB RAM up to 32GB RAM.
Test IPv4 - 103.214.71.2
Test IPv6 - 2607:fdc0:301:4::1:a
Network - Teraswitch
You will have access to our Virtfusion control panel to manage your servers, check it out.
https://extravm.com/billing/knowledgebase/149/VPS-Manager-Screenshots.html
ExtraVM - High RAM Specials
Yours truly.
Thanked by (1)Ganonk
do you give disk space?
If you mean adding extra space to plans by itself no, the plans can't be customized.
Yours truly.
How to use the promo code? I didn't see the usual promo input in your checkout page.
Need US offer
lol
I just noticed I left out the space in the post 🤣
Yours truly.
Weird, I see that there is a problem. Someone used the code so I'm not sure what's wrong. I'm looking into it.
Yours truly.
@TYTY The promo field is there now, sorry
Yours truly.
It just says "The promotion code entered has already been used"
Oh, I'm late, the promo code is no longer valid, want more.
The bandwidth is soooo generous. I didn't know it was even unmetered before.
App Devtools - Free Online Developer Tools | mp4tomp3.net - MP4 to MP3 Converter
@MikeA
Disk space I suppose will be what it says on order form? (OP still does not mention the space for each plan)
2GB RAM Plan - 30GB NVMe SSD Space
1 GB RAM Plan - 12GB NVMe SSD Space
You might want to check the link: https://extravm.com/billing/knowledgebase/129/VPS-Bandwidth-Overage-or-Policy.html
MikeA can confirm whether it applies to BF offer or not.
VPS reviews and benchmarks |
Any promotions won't make any difference. It was unmetered for a while, but I've found offering unmetered in Asia region isn't possible solely due to the extremely huge about of abuse (in terms of wasting bandwidth through proxies/tunnels, people only ordering the smallest plan and expecting to push >1Gbps 24/7, terms of service abuse reasons, people complaining about not being able to get 10Gbps to china, etc.) Having the 5-20TB bandwidth limit will prevent all of the concerns for me.
But as it mentions there if there's a legitimate use case and you hit 90% of your bandwidth allocation just open a ticket and I'll add more if the use case if explained.
Yours truly.
