Virmach now allows running hentai@home? I remember it was discussed earlier in this thread, and it was causing some problems on Tokyo storage.
the main problem is, it will abuse the disk io. Virmach asked will it improve if add SSD cache(Tokyo storage is HDD)
But I am using NVME to run it(Ryzen Special 2536), because in my "tech stack", the local disk is for the cache, my actual file is encrypted and stored at another place.
@taizi said: But I am using NVME to run it(Ryzen Special 2536), because in my "tech stack", the local disk is for the cache, my actual file is encrypted and stored at another place.
This is interesting, I see Ryzen Special 2536 only has 50gb of storage, how much is your h@h cache size?
521 static ranges assigned(hitrate 57.9 / min)
actual size:67G
my cache size:9.5G
approximate cache hit:50%-75%
my client quality is bad, but it works.
That hitrate is impressive, my client has ~600gb cache and 3200 static ranges, but only has 72.8 / min hitrate.
I bet your client isn't in Asia, only Asia has so much traffic.
I used to have a client host in pulsedmedia,5000 ranges but only 60 hitrate, because it is in Europe, so the hitrate is low.
@FrankZ said: P.S. That is one sweet box in Frankfurt. I had almost bought one, but really did not want another VM in Atlanta and was not sure that I could migrate it. Brave souls reap rewards
Yes I knew I was taking a risk - I am in the UK and Atlanta was a bit laggy (not the server) so after sleeping on the idea I decided to ask what LES thought. The extra IP was a bonus so if lost it was no biggie.
So I now have FFME007 running Proxmox for $24
So lets hope the old virmach stability comes back and stays.
You ran Proxmox on a KVM? how is the performance?
I thought it is supposed to be on bare metal only.
I run nested KVM on some bigger KVM to isolate some stuff that needs to run on older O/S that I don't want exposed to the world.
Runs almost as fast as the base KVM if you set it up correctly.
I really thought H@H was against VirMach's TOS. Now I am going to have to go and double check.
I would guess if it did not set off the abuse scripts you could get away with it on NVMe, but I expect you are living dangerously.
I'll be back in ~ an hour after reading the whole TOS again.
I honestly doubt you'll get any 30TB bandwidth VPS cheap in Japan, even if you migrate the specs will be modified to match the market price.
actually, I can't use so much bandwidth, but the problem is, I can't estimate the usage of my hentai@home service in the future.
If there is a strict rate limitation to network port instead of suspending after bandwidth runs out, I can only need 4T full-speed bandwidth(to be honest,20M network is enough for 99% of my work), but unfortunately virmach does not provide this option atm...
if your service like hentai@home doesnt support bandwidth limitations, then you could limit your server bandwidth with wondershaper or similar
@VirMach Now which areas cannot be turned on immediately, Or which areas can be turned on immediately after buying?
Always pending status, which hinders my purchase
it support, I just don't want to limit it and serve more request
@FrankZ said: I really thought H@H was against VirMach's TOS. Now I am going to have to go and double check.
some critical issue
i. infringes on any third party’s intellectual property or publicity/privacy rights;
e-hentai is a user-shared gallery but it obeys copyright laws and DMCA
E-Hentai Galleries complies with applicable copyright law. Unfortunately, due to sheer volume it is impossible for us to verify the copyright status of every single gallery uploaded to our site, nor are we legally complied to do so. If you find that your copyright has been infringed by one of our members, please report this using the DMCA Report Form found by clicking the Report Gallery button on the gallery in question, or by emailing a list of links to the galleries in question to reports (a) e-hentai period org.
and I didn't hear any user receive any copyright strike because of running this so far.
(even some Chinese guy host their own h@h client in China mainland, wtf?? I afraid it will make Winnie the Pooh's naughty list longer)
xi. involves mass public file storage of any kind (image hosting site, video hosting site, torrents, etc);
not for the public, only works for e-hentai. but since e-hentai is a public website, it is walk on the edge...
High I/O: Customer’s Service cannot average more than 80 IOPS within any two (2) hour period, cannot burst above 300MB/s disk write average for more than ten (10) minutes, cannot average more than 300 write operations per second for more than 1 hour, and cannot be above 20% average utilization within any six (6) hour period.
@lemoncube said:
I wasn't really sure if I should click checkout, but the hostname...
don't know if it will be provisioned.
I checked out 2 of them for 0.5 bucks. Lol another great find to match with the rest of the idlers.
oh,looks nice! but why mine was still pending?it is my first get in virmach,as is its low price. how about their reputation and service?good boy or bad girl?
actual size:67G
my cache size:9.5G
@VirMach
For some unpleasant reasons, my virmach tracking channel will be closed after this flash sale.
I would like to consult your opinion, should it be kept or destroyed?
your channel helpful for me,thanks your work
Is that you I know?
I like your work on the rating. I doubt virmach would even care, though.
some critical issue
I use NVME not HDD.currently the IO usage is low.
Ya knew e-hentai servers are at Romania for a reason
Screw T&S, Flying Chinaman runs TOR, game server, torrent and whatever pentest script in a 7x24h manner
no,it host at Moldova now
I wish I can utilize such a beast.
MJJ rating 60% worthy, ya'd butter pass
Crazy deals Jan 1 at 12:01am
YEAH
What have I seen...
"Humanity is f*cked up" - Jay
Oh my holy tits
its one way of saying to @risturiz - u wish -
this is good for those looking for US location
Won't bite the bait unless more than 95% worthy (75% for Tokyo)
Damn... I jinxed myself![:# :#](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/grimace.png)
$21 deal has been pending for more than 18 hours.
