@mee2 said:
Is there a tutorial to setup torrents on nat vps? Appreciate any help on this..
install qbittorrent-nox from repo, enable the service if applicable
configure it following docs, set webui listen port to one of the 5 ports assigned to your vm (you can save a port by assign a different one when you use reverse proxy for all your http/s services)
click gear icon in webui, set port to another assigned port under connection tab
add a torrent and start downloading
on the lower right towards the middle of webui, if you see a yellow plug icon turning into a green globe then you're good to go
I found default webui is not very mobile friendly. So after a bit of searching I found this which is very good on mobile. https://github.com/WDaan/VueTorrent
I prefer using an app, qBitController for android for example. IMHO, the default webui is irreplaceable in terms of functionality.
Current DISK READ: 746.68 K/s | Current DISK WRITE: 0.00 B/s load average: 2.95, 2.06, 1.26 %Cpu(s): 2.0 us, 8.6 sy, 0.0 ni, 89.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
I guess I'll have to disable all alerts for it.
Do you make your ToS available anywhere?
Hello @rockinmusicgv , our ToS it's > https://ihostart.com/termeni-si-conditii/index.html
we generally everything is possible on our servers besides child pornography, ddos attacks and drug websites
Regards,
Calin
I summarized the ToS in this thread:
7-day wooden rack strong small plate chicken DMCA ignored
@Calin Can you please activate the service, invoice (#911) has been paid a while back. Thanks.
oh my sides. real LES experience
the end is nigh
Down again since 7+ hours. is it dead finally ?
Why?
Is the server dead again?
which website is this?
Wow, will it be an end even before I get a hand to it?
This is so insanely cringy... How is that possible. Calins master is cociu?
Hi ,
mouse eaten wood , rack collapsed , very sorry .
in next day service restoration
hetrixtools
This is all Calin's fault.
⚠ SEEDING REMINDER: YOU HAVE 2 TORRENTS THAT NEED SEEDING! ⚠
You currently have 2 HnR torrents.
Hello all working again
Regards,
Calin
You are breaking yoursunny’s heart by all these downtimes. Please give him BGP as compensation
Why?
io is too slow
Private tracker?
Another 40 min downtime
Also, sky is blue
Why?
Hello all working
Not even 1 hour > @Calin said:
It’s down again since an hour. Can you take a look?
Why?
Someone is Vacuuming at odd hours
Why?
@Calin any other payment method than PAYPAL?
Hello it s possible crypto payment , only opened ticket on website
Regards,
Calin
I have sent the ticket
If you are using private trackers why not pick a real provider ? Most of them are ok with that I believe.
Why?
