Portable Apps (Windows 10) you can recommend?
YmpkerYmpker OGContent Writer
edited January 2023 in General
Hello there!
Lately, I have found myself quite often using another computer (library, work, or a friend's computer) and decided to create a good, old PortableApps USB stick to carry with me. Are there any applications from PortableApps you or applications that generally have portable versions (PDFsam, Enpass portable, Veracrypt..) that you can recommend?
What's the best portable PDF Application in your opinion? I was hoping for a portable version of PDF24, but settled with PDFSam Basic in the end because PDF24 didn't have any.
For Video encoding I found TEncoder which seems to work without any dependencies, while Handbrake unfortunately needs NET Framework or some other dependency that requires admin rights.
For portable YouTubeDL I have settled with YoutubeDLG (gui) and Tartube. In case someone is interested in (portable) yt guis: https://old.reddit.com/r/youtubedl/wiki/info-guis
These are my selected tools so far:
