Too many red flags.
Your BGP peer list contains many familiar BGP players (probably peered through freetransit)
Get a proper, physical BGP connection please, if you are serious about this business.
@NVMeNetworks said:
AI can tell you personally and not something that should be publicly shared, but we are close to being positive on our income/outgoings and plan to keep growing our services for a decent time to come.
You realise that you've just publicly shared this on the internet, right?
test ips?
im curious how performant your little tunnel is. you wisely chose to go with an ix VM from ifog which is peered with hetzner directly, so traffic flows through a "direct" fabric though the same cannot be said about freetransit
For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars! Looking for cost-effective Managed/Anycast/DDoS-Protected/Geo DNS Services? Try ClouDNS (aff).
@kjartann said:
test ips?
OOS?
Too many red flags.
is available to mount custom iSO?
Thanks but I'll wait for cpunetworks to come this summer
We prefer to be addressed by the pronoun LESbians.
Yes
miss it, so sad
Out of Stock
restocking another 10
The promotion code entered has already been used
test ips?
It's a giveaway.
Givers need to set limits because takers rarely do
193.25.207.3
fixed the promocode to use more
agreed
VPS providers to check out: Dedipath (aff)
Getting
connection timed out
while trying to ssh to serverTeehee!
is there any biger ram special offer in byos?
@NVMeNetworks Is the vps offline?
Yes sorry was announced we are upgrading to 10gbit
Not currently but maybe soon
The byos/special-offer seems OOS? when will restock? thanks
After bandwidth "upgrade", traffic becomes 75G
same issue here, and the speed limitation changed from 14MBps to 13.8 MBps
seems not "upgrade", but "downgrade"
We would love to be able to give more, but we have upgraded to 10gbit so we have to limit shamefully but it's upgradable at a cheap price
it seems no 10G "upgrade"? the speed limitation show as in panel changed from 14MBps to 13.8 MBps
How to upgrade? No option found in order page
