Looking for a 300GB storage VPS in FL or TX.
I need to store some backups using rsync.
Around 300GB.
1 vCPU
1GB RAM
2TB BW
FL or TX, US. Or something near.
Around 300GB.
1 vCPU
1GB RAM
2TB BW
Ask @SMARTHOST they maybe can fit you in a custom storage plan. You didn't specify a price but if you need a low-budget outside US @natvps_uk can be one of the best storage choices ever. Despite that these storage instances are located in France, have well-optimized network, lowest ping ever: 189ms, compared to 220+ms on some US cities. I'm located in South America.
I get 36ms ping to WalkerServers in Leaseweb. Is this now the lowest ping ever?
I meant, the lowest ping from my end, at least on Europe, others cities there show 300+ms.
Do you live with @imok?
No, I've shared ping just for reference.
Do you live in the same country as @imok?
Hopefully they can do it.
