[FYI] How to backup/move your media from Degoo
YmpkerYmpker OGContent Writer
Recently, Degoo changed free tier storage from 100GB to 20GB. I only used 5GB so far, so don't have any issues but I noticed others do have issues retrieving their files.
Found this tool on Reddit which lets you transfer files/photos from one cloud to another. Free plan includes 2 simultaneous downloads: https://www.airexplorer.net/en/
Good luck! :)
Fwiw, I didn't have anything important there but will likely also move out. Not stable enough.
  • can you put degoo with rclone?
    or maybe something like multcloud
    edited January 2023
    I don't think it supports rclone. It didn't even have a desktop client last time I checked. Just Browser and Android app. Multcloud could work, but Airexplorer has an android app which I can just silently let copy everything over to another cloud.
  • @Ympker said:
    Not stable enough.
    I just use it for Backups of Backups but never had any issues, even less than i expected considering the price. Whats not stable?
    @someTom said:
    @Ympker said:
    Not stable enough.
    I'd consider their plans to be instable, given that they chose to just change the free limit, not grandfather old 100GB users and changed lifetime user limits. What's next?
  • @Ympker said:
    @someTom said:
    @Ympker said:
    Not stable enough.
    Mine has been purged. 😅
  • vyasvyas OGRetired
    edited January 2023
    Degoo taking a dump?
    where I come from "Goo" literally means sh!t coloquially.
    @Fritz said:
    @Ympker said:
    @someTom said:
    @Ympker said:
    Not stable enough.
    Damn, no backup archive or smth provided?
  • @Ympker said:
    @Fritz said:
    @Ympker said:
    @someTom said:
    @Ympker said:
    Not stable enough.
    I have moved all files and dumped them. 😁
    @Fritz said:
    @Ympker said:
    @Fritz said:
    @Ympker said:
    @someTom said:
    @Ympker said:
    Not stable enough.
    Ah, fair enough :D
  • Huh, if I didn't read about it here, I wouldn't have known. Seems like I'm using ~19 GB, though ...
    Close enough :P
