Proxmox Assign IP to VM
I installed Proxmox yesterday and taking some time learning it to use for personal projects like Plex. I created a Windows VM, installed the Virtio drivers, and configured the Windows networking with a different ip than the host. I verified the gateway and subnet mask matched what the server provider gave me. The issue is the network adapter is connecting to "unknown network". Thanks in advance for helping me
Again, you're probably going to need to enable IP forwarding and use your local box as the gateway. That's what I remember from my time with NOCIX/WSI.
echo 1 > /proc/sys/net/ipv4/ip_forward
I got it sorted out. I accidentally clicked on the Vlan tag and it automatically entered a 1.
