Graphics card for 5120x1440 monitor
Probably not the best place to ask... But YouTube is full of gamers when it comes to monitors with this kind of resolution.
I have a Dell super ultra wide for productivity reasons. I don't game. The current GPU (RX550 maybe?) does drive the monitor to its native resolution but sometimes I get blank terminals or browser windows (I run Manjaro as desktop) so I think there may be a bug somewhere in the driver or the GPU itself.
Anyone has a similar setup as I do and what GPU do you use?
AMD RX 6800 can run a max res of 7680x4320 per display IIRC, you may have more luck with a more recent AMD GPU
Edit: What cable & port are you using? Higher resolutions like that might struggle not using DP or HDMI 2.1
ytdl.pro - Free to use Youtube-DL Cloud Downloader
DP
Hmm, it's possible that might be pushing the RX 550 (especially if its a 2G version) a bit over the edge to drive that resolution. Generally AMD drivers on linux are pretty solid, especially a few generations older card.
Then again could be fine and just an aging GPU starting to have some bugs/errors.
NVMe VPS | Ryzen 5950X VPS | Dedicated Servers -- Crunchbits.com
How would I know if I have a 2G?
Try this
glxinfo | grep -E -i 'device|memory|video'
Owh 2G = 2 Gigs of RAM lol
I thought it meant "2nd generation", my bad.
Yeah I have a 2GB version. Grrr.
May just be a little weak at driving that resolution. It's really hard to say for sure, but I assume it worked fine with previous monitor/resolution?
Yeah it was fine then.
Yeah, your RX 550 is very low-end while your resolution is pretty high-end. I think you'd want at least a modern low-end or oldish mid-range card with more RAM.
I'm running a low-end GTX 1050 (non-Ti) on my 2560x1440 monitor fine at 75Hz, but then it's 70% faster than your RX 550 and running half the resolution.
I haven't tested any Nvidia cards on Linux.
Currently, I'm happy with RX 6800 (Sapphire Nitro+ AMD card series are high quality, but bad idea if you don't get a reasonable price).
But for text and watching videos (without editing them), AMD RX 6600 (with "only" 8 GB of VRAM) should work fine.
Asus TUF or, better if you find a reasonable price, Sapphire Nitro+ (good cooling, so less noise).
Yeah I know it's pretty low end but I figured I am not playing games with it so I let it slide.
With the prices of GPUs these days I don't really want to shell out that kind of money to get a high end GPU for my high end monitor (I am cheap, therefore I am here on LES).
Looks like RAM is the bottleneck here.
RX 6600 (the non-XT version) is the least expensive I would dare to recommend.
You could "risk" with a used RX 6500 and if it doesn't work well, sell it on (won't lose much money if you buy used).
I haven't given nVidia a swing on linux (desktop) in awhile either, but I hear it has significantly improved. Still running AMD+Linux for my personal machine.
Given the complete collapse of the GPU mining ecosystem, prices have really come down. 2xxx and 3xxx series nvidia are extremely affordable now, and I'm sure 6xxx AMD as well. The benefit of jumping up to a 3050/3060/3070 range is that for ~$200-300 you should be able to pretty heavily future-proof yourself (and game, if ever wanted).
I'd argue that, with computer hardware, "future proofing" makes very little sense in terms of finances.
Buy what you need for the job.
Note that making some performance "headroom" as in not using 100% of available RAM or storage to prevent things from not working properly is not what I think of when saying "future proofing."
Fair enough, that is how I was using the future proofing analogy. Well, and if he were to upgrade monitors again in 2-3 years a better-than-bare-minimum-specs-today card should handle that without issue as well. You are right that there is no such thing though, but an oversaturated 3060/3070 sellers' market means pretty favorable price-to-performance that will last quite a long time.
For not gaming (or video editing & streaming for that matter) - AMD gives more bang for the buck IMO.
Basically, at the cost of sounding old-fashioned, I'd look for an AMD graphics card with an AMD CPU, and Nvidia for an Intel CPU, generally.
However, with Linux, I'm not 100% sure about Nvidia (maybe it works great - I'm just not sure).
Damn near anything can run high res these days. The tricky bit comes only if you want a >60hz refresh or need gaming performance. The little bit of 3d accel needed for Compositing window manager simply doesn't need recent gear.
I'd look at 2nd hand market here and quite an old generation. Buying like a 3*** series is buying a bunch of expensive silicone that is literally just gonna be idle if not gaming.
I'd probably use the steam hardware surveys as guidance. Whatever is popular there is gonna get support
https://store.steampowered.com/hwsurvey/videocard/
The last time I changed monitors was around 7-8 years ago 😂
Did try this today and here is the output:
now it doesn't seem like RAM is an issue...
It's probably DNS.
Joking aside i'm no Manjaro user but when I googled the kernal version you're on
5.15.81-1-MANJARO
I see a lot of results about display issues I don't know if this is normal search results for Manjaro or specifically that kernal? could potentially be an OS issue and not the GPU / Drivers themselves.You could try dual booting another OS like Windows or something for a bit & see if you still have the same issues.
Interesting observation!
found the issue,
seriously - do not use Manjaro, they really like to fuck up all kinds of stuff(including GPU drivers)
it also may be caused by DE you are running, XFCE does not like this resolution be default, neither does KDE Plasma.
lol. I upgraded to kernel 6.1 and my problems seems to be fixed. We'll see.
And for the record I use neither KDE plasma Nor XFCE.
I have idling 3090.. Wanted the best at that time. Not a mining card. Not gaming as much as before. No ideas what to do with it![:) :)](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
You could donate it to me![:) :)](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
