File sharing through browser
in Help
Hello,
I wanted something I could install on VPS where
- I would need to login to upload a file: nothing complicated, simple login then you can upload whatever; this needs to be accessible through a public URL
- once the file is uploaded, it needs to be able to provide links that can be shared with others; for downloading, no login should be required. Anyone with the link should be able to download.
Please suggest a simple solution. I have tried NextCloud in the past but I frequently run into problems with it, so I would prefer a simpler solution.
I think filebrowser suits your needs.
https://github.com/BobbyWibowo/lolisafe
https://github.com/chibisafe/chibisafe
https://github.com/andreimarcu/linx-server
https://github.com/timvisee/send
https://github.com/nokonoko/Uguu
https://github.com/pomf/pomf
Plenty of options to chose from
https://filerun.com/
+1 to filebrowser, this will do everything OP has asked for.
ytdl.pro - Free to use Youtube-DL Cloud Downloader
def filebrowser
Can take a look at this as well
https://github.com/droppyjs/droppy
Few more options
https://www.projectsend.org/
https://filegator.io/
https://github.com/Newlode/jirafeau
https://github.com/axeloz/filesharing
https://github.com/epoupon/fileshelter
How about image sharing like Advin have? the upload page should be inside admin panel, and the image url can be used everywhere.
Any recommendation?
