There is a bug with upgrading from Ubuntu 20.04 to 22.04 due to bad packaging form Ubuntu
Do you have a reference for this bug? What is the "bad packaging" that is at issue?
Based on these data, it seems that the name "libzip5" in 20.04 is the exception (an error?), and the return to "libzip4" in 22.04 was to correct this exception (or error)
So Libzip5 conflicts in 22.04 and it should install Libzip4 instead
Basically, Hestia should do the following check:
If Ubuntu, then: if 20.04, then need libzip5; else need libzip4
aapanel.
fastpanel
That's strange. From https://www.hestiacp.com
Meanwhile we do. If I remeber correctly for quite some time now...
keyhelp works perfect on ubuntu 22. Good luck!
Cyberpanel
Yeah, I think I misread it somehow.
HestiaCP Supports 22.04
https://github.com/hestiacp/hestiacp/blob/main/CHANGELOG.md#160---major-release-feature--quality-update
Even since 1.6.0
There is a bug with upgrading from Ubuntu 20.04 to 22.04 due to bad packaging form Ubuntu![:) :)](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
(We do not support 22.10 ( 23.04/23.10) but only the LTS releases. ...
Missed libzip.so.5![:) :)](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
It's included in Ubuntu 20.04 , but Ubuntu 22.04 has only libzip4
I think that he solved issue already
According to eris on the other forum they knew this and libzip4 should have worked. Works on my debian 11 system under libzip4 no problems at all.
Setting Hestia aside, the issue of libzip4 vs libzip5 in Ubuntu is rather puzzling:
I just checked and you're correct.
Like @angstrom said, 1.7.3-1 in my Debian 11 / Hestiacp installation.
libzip4:amd64 1.7.3-1 amd64
Yeah it's weird but this is not the first, nor probably last were Ubuntu does something just plain odd.
That is what I mean with > @angstrom said:
We need to modify the dependencies in:
https://github.com/hestiacp/hestiacp/blob/e3ad465726f97c1d640f532c7cee3038784e2bba/src/deb/php/control#L9
naughty naughty hestia cp
For the new install this works fine. It is hard to detect when a user upgrades to a new OS (20.04 to 22.04 in this case)
We should create separate control files for each OS.
