Changes to NatVPS
13468911
  • @natvps_uk said:
    It’s not in a DC but it is located in a secure unit. Definitely not in Calins basement 😂
    Plot twist: it's in @skorupion basement.
    edited January 2023
    @natvps_uk said:
    Looks like a routing issue to git.io. Try this
    wget https://raw.githubusercontent.com/Nyr/openvpn-install/master/openvpn-install.sh -O openvpn-install.sh && bash openvpn-install.sh
    Will try later, thanks. On UK Instance this worked fine, so might be routing with NL.
  • natvps_uknatvps_uk Hosting Provider
    I can confirm that no basements have been used in the hosting of this node.
    Just what you would say if you were hosting out of Calin's basement.
    Thanked by (3)Ympker chimichurri Calin
    If it was hosted in Calins basement it would have already been DDos'd 6 times and have 70% uptime. - Sorry Calin, I know you're working on this :#
    Thanked by (3)fluttershy sh97 Calin
    Numbers can be fudged. I am watching you. 🤪
    Thanked by (2)Ympker Calin
    @sh97 said:
    @natvps_uk Any plans for an Asian location soon?
    Korea will be back in stock soon, Singapore is possibly coming although it’s likely a few months away.
    Thanked by (2)yoursunny sh97
    @yoursunny said: I recall @skorupion requested 64MB KVM last year, not sure how it would work.
    Worked out as well as a free unrequested refund from Advin Servers> @yoursunny said:
    Sadly not, but I can rent a huge garage for like 75 bucks p/m
  • edited January 2023
    Woohoo, Calin is back on line. ;)
    Edit: Okay, forget what I've said.
    More off than online. 40% loss.
    That’s cheap! Garages here are like £100 per month and they hardly fit a single car! I’d snap your hands off for a garage for that price in the UK. My car collection is currently spread across a few locations 😰
    edited January 2023
    Its the size of a big van with the ability to walk all around it, and as high as 2 stories. Not sure if I can still rent them from the city (depends if tenants are paying their rent)
    @Ympker said:
    Okay, that's fair enough. Just wanted to make sure 😂
    Hmm, when running @Nyr scripts (ovpn/wg) on NL vps it gets stuck at this (connectivity issue? worked fine on UK)
    This is now resolved, it was a routing issue which is now resolved.
    For anyone else seeing generally strange networking behaviour on this node the issues should be resolved. Please let me know if you continue to see issues, whilst this is a bonus location we still want it to be as usable and stable as possible!
    Announcement:
    We have disabled vswap for instances users on the UK nodes, this was being heavily abused by people creating 64MB instances and forcing everything into swap. As this node is on HDDs it was impacting the limited disk performance fairly substantially.
    Along with this change we will be looking at provisioning a new UK node on SSDs, we will not be forcing a migration although VPS users can request to migrate to this node (whilst stocks last) and instance users can simply deploy a new instance on this node.
    We do not yet have a date for the provisioning of the SSD UK node although we will announce it here.
    We're sorry for any inconvenience this may cause, in the meantime we will be offering additional RAM to instance users that were previously relying on vswap, simply open a ticket and we will allocate the memory you require - you will not need to re-provision your instance. Please note that this offer will not apply to newly created instances - Instances should be provisioned with the amount of resources that you require and not intentionally underspec'd.
    We never advertised or sold the fact that these services came with vswap, we simply added it to help with lower specification instances and we will continue to do so on SSD nodes.
  • edited February 2023
    Didn't want to make a ticket, but FYI the tun/tap button for Romania doesn't seem to be working (doesn't reboot the vps, tried manually rebooting after and still wasnt turned on). The server is/was up at the time I tried (ssh'ed into it) and the button works fine for other locations. Rebooting from the control panel also works fine, just the tun/tap that isn't working.
    Edit: Guess it doesn't matter now because @Calin's servers seem to be getting DDoS'ed again right now lol...
  • My 256m UK instance is extremely slow. I mean computing speed wise. Network speed is good but even apt update takes 3mins.
    Its possible that you are being throttled. We do have automated throttling in place for users that are hammering the disks. Open a ticket and we can investigate. I just timed a apt-update on that node and it is not even close to that slow on a 256mb instance.
    root@test:~# time apt update
    Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
    Get:2 http://ftp.debian.org/debian buster InRelease [122 kB]
    Get:3 http://ftp.debian.org/debian buster-updates InRelease [56.6 kB]
    Get:4 http://security.debian.org buster/updates/main amd64 Packages [430 kB]
    Get:5 http://security.debian.org buster/updates/main Translation-en [234 kB]
    Get:6 http://security.debian.org buster/updates/non-free amd64 Packages [556 B]
    Get:7 http://security.debian.org buster/updates/non-free Translation-en [344 B]
    Get:8 http://ftp.debian.org/debian buster/main amd64 Packages [7909 kB]
    Get:9 http://ftp.debian.org/debian buster/main Translation-en [5969 kB]
    Get:10 http://ftp.debian.org/debian buster/contrib amd64 Packages [50.1 kB]
    Get:11 http://ftp.debian.org/debian buster/contrib Translation-en [44.2 kB]
    Get:12 http://ftp.debian.org/debian buster/non-free amd64 Packages [87.8 kB]
    Get:13 http://ftp.debian.org/debian buster/non-free Translation-en [88.9 kB]
    Get:14 http://ftp.debian.org/debian buster-updates/main amd64 Packages [8788 B]
    Get:15 http://ftp.debian.org/debian buster-updates/main Translation-en [6915 B]
    Fetched 15.0 MB in 4s (3524 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    5 packages can be upgraded. Run 'apt list --upgradable' to see them.
    real    0m7.071s
    user    0m4.490s
    sys     0m0.611s
    root@test:~#
    I'll take a look once the nodes are back online
    real    0m7.071s
    user    0m4.490s
    sys     0m0.611s
    root@test:~#
    Mines pretty slow too, and my server just idles.
    root@micronode-UK-NAT:~# time apt update
    Hit:1 http://security.debian.org buster/updates InRelease
    Hit:2 http://ftp.debian.org/debian buster InRelease
    Fetched 56.6 kB in 1s (50.3 kB/s)
    Reading state information... Done
    All packages are up to date.
    real 0m14.025s
    user 0m1.530s
    sys 0m0.444s
    That seems about right considering the node is on HDDs. We will be getting a UK node on SSDs fairly soon.
    real    0m7.071s
    user    0m4.490s
    sys     0m0.611s
    root@test:~#
    This is mine;
    root@microuk:~# time apt update
    Get:2 http://deb.debian.org/debian buster-backports InRelease [51.4 kB]
    Hit:3 http://ftp.debian.org/debian buster InRelease
    Get:4 http://ftp.debian.org/debian buster-updates InRelease [56.6 kB]
    Get:5 https://download.docker.com/linux/debian buster InRelease [54.0 kB]
    Get:6 http://security.debian.org buster/updates/main amd64 Packages [430 kB]
    Get:7 http://security.debian.org buster/updates/main Translation-en [234 kB]
    Fetched 861 kB in 38s (22.8 kB/s)
    real    8m41.450s
    user    0m2.296s
    sys     0m1.330s
    edit: I just created a ticket :)
    @edip said:
    This is mine;
    real 8m41.450s
    user 0m2.296s
    sys 0m1.330s
    Almost certainly being throttled, DM me your micronode username and I'll take a look
    I've lifted the IO throttle, please try again now
    Thanks! It's definitely faster now;
    real 0m6.157s
    user 0m1.589s
    sys 0m0.895s
    After first provision, I couldn't enable tun/tap so I just reinstalled OS several times, hoping I'll fix it. But it got fixed only after a ticket :). I think that's the cause for throttling.
    Thanked by (1)ehab
    NL can ping your other locations fine, but can't ssh your UK host or CA or SK
    ssh: connect to host xxx…. port xx21: Connection timed out
    ssh: connect to host yyy… port xx21: Connection timed out
    ssh: connect to host aaa… port xx21: Connection timed out
    Can't ping an IPV6 address
    PING government.nl(bbbb::::)) 56 data bytes
    From cccc::::(dddd::::): icmp_seq=1 Destination unreachable: No route
    Please do the needful :smile:
    Please remove our node IPs from this post.
    Never share node IPs publicly!
    We’ll look into the issue
    Thanked by (1)ruets
    If this is a policy, it needs to be added to the ToS.
    Otherwise, it's merely a suggestion.
    "Share publicly" needs to be defined too.
    For example, if a customer installs Asterisk telephony server and creates an SRV record pointing to the IPv4+port, the DNS record technically reveals the node IP.
    Yeah I’m going to add it, I mean a records are fine. Sharing the IPs on a public forum not so much.
