@bliss said:
Very slow disk, I've seen this before in @natvps_uk . But being cheap is more important than speed or performance.
I wonder if there's some explanation behind this, I think apt installation are working by downloading pkg from repository then writing them into the system storage. what i don't get is, why this slowness only affect apt (well, for now), but my wget / curl download capability along with transmission can gain 10MB/s easily
Hello, for now we no longer plan to provide VPS-uri NAT, unfortunately maintenance to these VPS-uri is overworking and we encounter a lot of problems with them
Thanks for all , for interest, and excuse the long response time here
Regards,
Calin
Are existing NAT LowEndSeedbox plans still renewable?
Or shall I start looking for money to be able to afford the €36 next year?
Then disk performance is not the culprit. You need to ask Google to seek similar conditions.
I've encountered a slow system update, which turned out to be a netplan problem, causing system freezes about 30 seconds. And the solution is simple, just remove netplan and config network with systemd-networkd.
@Encoders said:
i heckin' love waiting for half an hour just to install mc
hahah I feel you. But after all of that painful slowness and 1 week provisioning time, the price is unbeatable for me to sail the seven seas. I hope we can renew this for upcoming years 😂
Hello LES , becauseI like to offer people cheap prices and a decent quality I plan to offer these plans with SSD instead of HDD, yes you heard well SSD, exactly the same price and exactly the same specs just as with SSD, thing to purchase a large batch of enterprise SSDs at a low price, stay on phase
Regards,
Calin
Regards,
Calin
Can you just offer more ports per server instead ? 5 is too low. Or IPV6.
Regards,
Calin
Okay, you've peaked my interest. Will you still increase the RAM?
my vps has been inaccessible for a few days, ports 6356-6360
Hi, still unable to connect and may need to be reinstalled
hello,my nat vps port 6361-6365 can't connect,and 512m ram no upgrade +380m ram
i need cheap vps year payment .
Hello, the service has been offline for a week
Have recovered
Do you have any plan on restock? @Calin
Has been out of stock for several days.
MicroLXC is lovable.
Thank you.
cloudflare?
mc
Maybe @Calin 's silence equals there will be no more restock.
So I will just walk away and seek another provider.
apt
(well, for now), but my wget / curl download capability along with transmission can gain 10MB/s easilyFuck this 24/7 internet spew of trivia and celebrity bullshit.
Regards,
Calin
Hello , yes it s renewal
as long as you keep the VPS with us we will offer you the same support and the same prices , i m don t have on plan for remove actualy NAT VPS
Regards,
Calin
netplan
problem, causing system freezes about 30 seconds. And the solution is simple, just removenetplan
and config network withsystemd-networkd
.MicroLXC is lovable.
what about io speed?
Regards,
Calin
A huge wave of customers are approaching.
Why?
Looking forward to seeing new offers. Even cheap SATAs would be a good compromise.
Hello , it s same deal , same specifications only from HDD converted on full SSD
Regards,
Calin
I m work for add IPv6 @jmaxwell
These servers are advertised to have IPv6.
Calin gave me a KVM that I can hand out IPv6 from.
If you need IPv6:
I will make a tunnel to your WireGuard server.
You would get /128 only due to limitation of the KVM that I received.
Much appreciate it as a temporary method, thank you.
OK, will you add stock any time soon ?
When can we expect that? Can't wait...
Does your panel down sir? @Calin
http://92.84.204.2:4083/ is not accessable now
Hello , give you on PM IP of panel
