@natvps_uk said:
SSH Key support has been released for instance customers. This will eventually be available for VPS' as well, hopefully in the next release.
SSH Keys must be in the ssh-rsa format, ssh-dss keys are not supported.
It should be fairly self explanatory but documentation will follow.
When creating a new instance and providing SSH Key, will there be an option to have pw auth disabled by default? I believe this was the case with e.g. Lunanode.
Not currently:
It is still down to the client to disable password based login, the way this works currently is a 100 character randomly generated password is set for root - this is never stored and is generated on the node therefore it is never passed in transit either.
Its unlikely that password based login will be removed due to the possibility of community templates using different SSH clients making this fairly tricky although its still very secure using this method.
@natvps_uk said: Announcement:
We have disabled vswap for instances users on the UK nodes, this was being heavily abused by people creating 64MB instances and forcing everything into swap. As this node is on HDDs it was impacting the limited disk performance fairly substantially.
Along with this change we will be looking at provisioning a new UK node on SSDs, we will not be forcing a migration although VPS users can request to migrate to this node (whilst stocks last) and instance users can simply deploy a new instance on this node.
We do not yet have a date for the provisioning of the SSD UK node although we will announce it here.
We're sorry for any inconvenience this may cause, in the meantime we will be offering additional RAM to instance users that were previously relying on vswap, simply open a ticket and we will allocate the memory you require - you will not need to re-provision your instance. Please note that this offer will not apply to newly created instances - Instances should be provisioned with the amount of resources that you require and not intentionally underspec'd.
We never advertised or sold the fact that these services came with vswap, we simply added it to help with lower specification instances and we will continue to do so on SSD nodes.
I opened a ticket but still no reply since 6 days. May you please take a look? Ticket number is #LKX-040803. Thank you in advance.
I like your offer very much. Everthing is stable except the VMs which rely on vswap.
We will get back to you, there is a backlog on support at the moment and you are in a queue.
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Deutsche Telekom (Hamburg) [1.82 km]: 11.315 ms
Testing download speed........
Download: 1396.56 Mbit/s
Testing upload speed.............
Upload: 220.54 Mbit/s
Our South Korea location is now back in stock for Instance users with a few minor changes.
Korea is by far the most expensive node we have, we have just substantially upgraded this to allow stock in this location for the foreseeable future.
Down to the cost of bandwidth in this location and the amount of abuse on this node we have limited the bandwidth to 100GB per month per instance credit.
None of our instance users have used this much bandwidth in the last 4 months therefore we don't believe it will cause too much drama however this was a decision that we did not take lightly and it is the only way we can profitably sustain this location.
We will give all users that need more bandwidth the opportunity to purchase more at cost. We pay £0.01 per GB in this location and we would be happy to pass this cost on to any client that wishes to have more Bandwidth in this location.
We also have plans to implement a new Asian location with unlimited bandwidth fairly soon.
For anyone that does not currently have a KR instance enjoy the new stock!
Does 100GB count on egress only or sum of both directions?
What happens if the 100GB limit is reached?
Does the network connection get suspended, or does it have snail speed unmetered network?
Suppose an account has 2 credits, one expiring on Nov 15 and another expiring on Dec 01.
The account has one Korea container, whose RAM and storage do not exceed one credit.
In the month of November, how much bandwidth can be used, 100GB or 150GB or 200GB?
Both directions.
We get notified and contact the client to arrange a mutual agreement. If the client wants to pay for additional bandwidth they will have that option, failing that it would be service suspension.
200GB, the bandwidth limit starts in the 1st of the month and ends on the 1st of the following month.
WireGuard no.
Provider refuses to load the kernel module, despite that it's literally one line modprobe wireguard, at least for LXC based location such as Amsterdam.
WireGuard-go yes.
But it's buggy and slow userspace implementation instead of polished and fast kernel implementation.
WireGuard no.
WireGuard-go yes.
well that's a shame, i hope there's some explanation why they refused to do it. security concern maybe? but that's high unlikely.
I'll wait a bit until they respond i guess (for refusing to load the kernel module) otherwise-- meh userspace is good enough i guess
@natvps_uk said: Absolutely a security concern, I doubt the wireguard team support this and I’d be even more surprised if it was tested officially on OpenVZ.
If security is a high priority, then you should just stop that micro-node control panel and switch to other widely used ones.Because I don't your developing skills can match that widely used ones'.
Most providers here don't offer that control panel, actually as far as I know, none of the providers here use that.
On the other hand, wireguard has been absorbed into the kernel for more than 2 years.
If you really think wireguard might breach security holes, then compile and run a customized kernel.
@yoursunny said: Provider refuses to load the kernel module, despite that it's literally one line modprobe wireguard
We can’t just load kernel modules on a shared kernel without fully understanding the risks.
WireGuard kernel module is officially tested on LXC.
In fact, it's designed for such use cases: network namespaces.
Thus, you can safely load this module in Amsterdam location that uses LXC.
I’m happy to enable it in LXC locations, that’s really not an issue.
The issue here is the lack of support on OpenVZ and the fact that we have to compile the module with several patches and maintain it.
Ubuntu 22.04 apt update command crashes on 64MB without swap, even if I stopped everything.
I think it should be acceptable to use some swap during installation and upgrades, but not during normal operation.
I deleted UK instance and created Germany instances, which has swap.
There's no way to modify a loadbalancer, so I have to delete and re-create it too.
This causes downtime because TLS certificate isn't provisioned on the new loadbalancer right away.
In an attempt to reproduce the apt update failure, I created another UK instance but it has swap again.
Does this mean the UK SSD node has arrived?
Loadbalancer and instance editing is coming very soon, the work is almost complete we just need to write tests. It should be available as a beta by the end of the week - happy to add your account to the beta program.
This will allow you to add additional RAM to an instance for maintenance then remove it afterwards. It will also allow you to add and remove instances from an LB without any downtime although if the dns name isn’t changing the cert will likely not be regenerated - they remain cached for 24 hours.
Having the same problem. Not able to install security updates.
Createt a ticket a while ago... still no reply :-(
You almost always reply instantly to my posts lol
Gotcha, thanks
New Primary Location!
We have added a new permanent location to Micronode instances, Limburg, Germany 🇩🇪.
Node Specifications:
This is available immediately for instance customers. VPS customers will have to wait another few days before we get an offer out.
For anyone wanting to try this who doesn’t currently have instance credits they can be purchased here: https://clients.natvps.uk/index.php?rp=/store/micronode-instances/1-credit
YABS from an Instance:
i am happy to see Germany node.
congrats and i wish you good sales.
Still waiting for Finland loc.
Btw, some bugs when creating SSH Key.
If you press back, it will show false slider info like RAM and Storage.
https://microlxc.net/
My 96MB Germany instance running wireguard
Awesome! Happy to see Germany along with 10Gbps
Loving it:
@natvps_uk
Success! Your instance has bow been created!
Is it a typo or intended?
Typo, now fixed.
Both directions.
can you use wireguard / wireguard-go in this one?
WireGuard no.
modprobe wireguard
, at least for LXC based location such as Amsterdam.WireGuard-go yes.
Userspace is good enough.
Glad to hear that we think alike.
MicroLXC is lovable.
They don’t have access to it, it’s our in house panel.
We take security seriously, the panel is pentested regularly and we follow best practices.
On the other hand wireguard-go has been considered stable for years, it is used on the Windows application for example.
We can’t just add every kernel module someone asks for, that’s not how we work.
This! @natvps_uk 's business, @natvps_uk 's rules!
Ubuntu 22.04
apt update
command crashes on 64MB without swap, even if I stopped everything.I think it should be acceptable to use some swap during installation and upgrades, but not during normal operation.
apt update
failure, I created another UK instance but it has swap again.Does this mean the UK SSD node has arrived?
