Convoy v3 • Open Source VPS Panel Using Proxmox • Open Beta • Free 512MB VPS (IPv6 Only)
What is Convoy?
Convoy is a VPS panel meant for hosting providers and regular consumers. It supports many of the essential functions of a virtualization panel, such as reinstallation, power management, IP management, ISO mounting, and way more. Convoy uses Proxmox VE as a backend, and can connect to any host node that runs the latest version of Proxmox VE. Convoy also has public source code, in which anyone can look at, audit, or modify under the Business Source License, which is a significant advantage over the competing VPS panels on the market.
Price
At the time of writing, Convoy is/will currently be $6/node/month for commercial usage (i.e. hosting businesses). Convoy will be free for non-commercial or personal use cases, meaning that it is also an ideal panel for those running home labs or other setups.
Information
- GitHub Repository: https://github.com/ConvoyPanel
- Panel Repository: https://github.com/ConvoyPanel/panel
- Discord Server: https://discord.gg/6nRkMZJJvf (Recommended)
- Developer: @ewang
Integrations
Convoy currently has a Blesta module, which can be found here (developed by Aleksa, costs £30 at time of writing).
Convoy currently has a WIP WHMCS module, which will be open source and free soon (developed by me).
Screenshots
Open Beta
I have decided to host a small open beta for Convoy. If you would like to check out Convoy, find bugs, issues, etc, you can sign up for a small 512MB VPS with 1 IPv6 address.
- Intel Xeon E5-1650 v2 (1 core)
- 512MB DDR4 ECC Memory
- 1 Gbps Shared Unmetered
- Single IPv6 Address
- No IPv4 Access (yet)
- Located in Falkenstein, DE
Order Here >> https://clients.wynservers.com/index.php?rp=/store/vps/convoy-512mb
Please make sure to read the plan terms and full details of the plan before ordering. If you do not have IPv6 access, I would recommend checking out Route48.
Order Requirements:
- You must have at least 25 non-spammy posts/comments on LowEndSpirit.
- You must have at least been a member of LowEndSpirit for 2 weeks.
- If you are a hosting provider, you can immediately skip these requirements.
- You will need to comment the order number. If you've lost it, then make a new order.
- Invoice numbers are not accepted at this time.
These order requirements will get more relaxed once the initial wave of open beta servers have been handed out. There may be some initial issues with the WHMCS integration, but they are being ironed out. If you run into an issue, bug, or have any feedback, you can open a ticket and it will either be forwarded to @ewang or it will be fixed by me (if it's an issue with WHMCS integration).
Open beta will last until May 14th, 2023. There is no SLA policy on these free plans (obviously). Feel free to run stuff such as uptime monitors, Discord bot's, or whatever you want. If we have to do anything to these plans, we will announce any changes 72 hours beforehand.
Hardware and WHMCS integration for Convoy Open Beta has been provided/managed/made by me, so any questions about that should be directed to me. The software itself has been made by @ewang, I am simply posting this thread on his behalf as he is new to LowEndSpirit and I support the Convoy project.
Your Order Number is: 3085657473
Looking forward to try this panel! Thanks.
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals on Telegram
Active and helpful on LES? Come grab a free VPS! - FreeVPS.org | How to Apply
Your Order Number is: 7148905464
Just like try new VPS panel.
3203491806
Thanks,
Great!
Looking forward to try this.
Order number : 4950634404
Question, is there any limitation on core number for personal usage?
https://microlxc.net/
Order number: 8163088892
Thank you!
No strict CPU limitations (if that's what you mean), but I might cap it if it becomes a problem (or deprioritize it). It's basically just a normal VPS. The CPU is not very strong and it's a bit of an older model because that's all I could find in time, but I might switch to a different CPU soon enough
Order Number is: 8059962913
thanks
Your Order Number is: 8171848441
Thx
VPS reviews and benchmarks |
Sorry if I made it not very clear. For the personal license (self hosted), do you apply limitation for number of CPU?
Order Number is: 5824108229
Happy to participate in testing
The FroCDN project is also used and it is quite convenient.
from google translate
Oh, no, there are currently no limits for self-hosted (at least that I'm aware of).
Any plans on adding LXC support?
Your Order Number is: 2714149170
Will love to try this new panel
512MB RAM but no storage? how am i supposed to use it?
hmm
Order Number: 6335534816
The order number is: 3507267689
Thank you.
MicroLXC is lovable.
I haven't used ConvoyPanel before and I'd like to give it a try. Is there a detailed installation guide available? I'd like to try installing it on my VPS.
Order Number: 3128998477
Order Number: 1763766395
Thank you
what can 512 GB ram do?
Start a summer host.
Order
7720644692
Thanks.
Your Order Number is: 2523882219
Thank you, muchas gracias.
Use RAM for storage ! Lovely use case.
The Panel screenshots show 10 GB disk if you see carefully.
Store a lot of P0rn for super fast acccess. Not quite HD quality though.
Yes, a guide is available on our website: https://docs.convoypanel.com/
Founder, Lead Developer, Lead Designer, Marketing Lead, Sales Lead, Janitorial Staff, Plumber, Support Lead, Legal Team, I.T., Accountant, Electrician, System Administrator for Performave and ConvoyPanel
Sure, I would have to do some rewriting. This might be until the summer because I have been really busy.
Your Order Number is: 6033163333
Your Order Number is: 2650271547
thanks @Advin @ewang
excited to try out this panel
Your Order Number is: 3670540117
Wanna try it out. Thanks
Order Number: 8603160811
Thank you
Your Order Number is: 4201719223
Really interested in trying out the new panel for home use.
