Next generation AMD mobile CPUs
Anyone saving up for the new Ryzen mobile laptops? Damn they look sexy.
Nope.
My Core2Duo i7-2670QM does just fine, TIA.
My current two laptops run on R5 3500u and R7 3750h. Both quad cores, they are fine for laptop.
Raw speed wise though, they are on par with my old i7-4712MQ. But I don't really do CPU intensive tasks on laptops. That's where my main rig with 3900x comes in.
Quoting this becasuse I think this is not quite a shitpost.
Come on, @SSW, all I do is shitposting.
@deank
I upgraded from AMD E-350 circa 2014, to AMD Athlon(tm) II X4 620 circa 2010.
I'd like to get these in something like those multi-server ARM 1U systems.
ExtraVM - High RAM Specials
Yours truly.
