Wishosting Boxing Day 2019 Special
Wishosting's interface is very different from the usual WHMCS/SolusVM/Virtualizor providers. It took a while to understand how it works but once familiar, things are about the same.
Apart from the usual templates and a couple of linux iso images, they now have netboot.xyz for just about any live install.
Very competitive offer, good performance for advertised specs. If by next year it is still as good, definitely will make it to personal top provider list.
Note the geekbench score is taken over multiple attempts; it is the mode value.
Boxing Day 2019
https://browser.geekbench.com/v4/cpu/15089322
2 vCPU core Xeon E5-2670v2 Unlimited CPU cores 2.9GHz Turbo
4GB ECC RAM
100GB SSD
Linux/Windows OS
Bandwidth 1Gbps
Traffic 5TB
1 IPv4
Location - Kansas City, Missouri
[root@cybertech ~]# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 2
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 58
Model name: Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS)
Stepping: 9
CPU MHz: 2493.750
BogoMIPS: 4987.50
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 4096K
NUMA node0 CPU(s): 0,1
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl cpuid tsc_known_freq pni pclmulqdq ssse3 cx16 pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm pti ssbd ibrs ibpb stibp fsgsbase smep erms xsaveopt md_clear
CPU model : Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS)
Number of cores : 2
CPU frequency : 2493.750 MHz
Total size of Disk : 100.0 GB (1.9 GB Used)
Total amount of Mem : 3939 MB (118 MB Used)
Total amount of Swap : 0 MB (0 MB Used)
System uptime : 0 days, 2 hour 38 min
Load average : 0.53, 0.16, 0.08
OS : CentOS 7.7.1908
Arch : x86_64 (64 Bit)
Kernel : 5.4.6-1.el7.elrepo.x86_64
I/O speed(1st run) : 1.3 GB/s
I/O speed(2nd run) : 1.4 GB/s
I/O speed(3rd run) : 1.1 GB/s
Average I/O speed : 1297.1 MB/s
Node Name IPv4 address Download Speed
CacheFly 205.234.175.175 88.6MB/s
Linode, Tokyo2, JP 139.162.65.37 9.19MB/s
Linode, Singapore, SG 139.162.23.4 5.19MB/s
Linode, London, UK 176.58.107.39 9.71MB/s
Linode, Frankfurt, DE 139.162.130.8 12.0MB/s
Linode, Fremont, CA 50.116.14.9 28.0MB/s
Softlayer, Dallas, TX 173.192.68.18 70.8MB/s
Softlayer, Seattle, WA 67.228.112.250 30.2MB/s
Softlayer, Frankfurt, DE 159.122.69.4 8.84MB/s
Softlayer, Singapore, SG 119.81.28.170 5.83MB/s
Softlayer, HongKong, CN 119.81.130.170 7.78MB/s
CPU: SHA256-hashing 500 MB
2.222 seconds
CPU: bzip2-compressing 500 MB
6.131 seconds
CPU: AES-encrypting 500 MB
1.844 seconds
ioping: seek rate
min/avg/max/mdev = 52.7 us / 71.0 us / 5.75 ms / 34.6 us
ioping: sequential read speed
generated 24.0 k requests in 5.00 s, 5.85 GiB, 4.79 k iops, 1.17 GiB/s
[root@cybertech fio-2.0.9]# ./fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=64k --iodepth=64 --size=4G --readwrite=randrw --rwmixread=50
test: (g=0): rw=randrw, bs=64K-64K/64K-64K, ioengine=libaio, iodepth=64
fio-2.0.9
Starting 1 process
test: Laying out IO file(s) (1 file(s) / 4096MB)
Jobs: 1 (f=1): [m] [-.-% done] [870.4M/864.3M /s] [13.1K/13.9K iops] [eta 00m:00s]
test: (groupid=0, jobs=1): err= 0: pid=12525: Tue Dec 31 14:06:42 2019
read : io=2050.5MB, bw=893467KB/s, iops=13960 , runt= 2350msec
write: io=2045.6MB, bw=891343KB/s, iops=13927 , runt= 2350msec
cpu : usr=11.62%, sys=50.49%, ctx=31548, majf=0, minf=5
IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=99.9%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
issued : total=r=32807/w=32729/d=0, short=r=0/w=0/d=0
Run status group 0 (all jobs):
READ: io=2050.5MB, aggrb=893467KB/s, minb=893467KB/s, maxb=893467KB/s, mint=2350msec, maxt=2350msec
WRITE: io=2045.6MB, aggrb=891342KB/s, minb=891342KB/s, maxb=891342KB/s, mint=2350msec, maxt=2350msec
Disk stats (read/write):
sda: ios=30001/29856, merge=0/0, ticks=4837/125110, in_queue=115807, util=94.57%
# Yet-Another-Bench-Script #
# v2019-10-08 #
Tue Dec 31 13:50:27 +08 2019
Processor : Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS)
CPU cores : 2 @ 2493.750 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 3.8G
Swap : 0B
Disk : 100G
Disk Speed Tests:
| Test 1 | Test 2 | Test 3 | Avg
Write | 360.00 MB/s | 329.00 MB/s | 361.00 MB/s | 350.00 MB/s
Read | 1336.18 MB/s | 1088.95 MB/s | 1379.76 MB/s | 1.27 GB/s
Bouygues Telecom | Paris, FR (10G) | 882 Mbits/sec | 404 Mbits/sec
Online.net | Paris, FR (10G) | 881 Mbits/sec | 277 Mbits/sec
Severius | The Netherlands (10G) | 839 Mbits/sec | 268 Mbits/sec
Worldstream | The Netherlands (10G) | 874 Mbits/sec | 228 Mbits/sec
wilhelm.tel | Hamburg, DE (10G) | 871 Mbits/sec | 352 Mbits/sec
Biznet | Bogor, Indonesia (1G) | 470 Mbits/sec | 42.3 Mbits/sec
Hostkey | Moscow, RU (1G) | 843 Mbits/sec | 431 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 925 Mbits/sec | 758 Mbits/sec
Airstream Communications | Eau Claire, WI, US (10G) | 929 Mbits/sec | 698 Mbits/sec
Hurricane Electric | Fremont, CA, US (10G) | busy | busy
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 2492
Multi Core | 4703
Full Test | https://browser.geekbench.com/v4/cpu/15089372
Conclusion:
and why isn't @exception0x876 here
send him an invite.. he may not get OG tag in time
I would probably make a high priority ticket on this.
Have him Join and we all will vouch for him!!
Absolutely agreed, Michael is definitely an OG of awesome deals. The price is great and the CPU policy is relaxing to me (cannot accidentally get killed for "cpu abuse") and anything you need Michael hooks it up (particularly if you ask politely and respectfully of course) :-)
A bench monster. Hot ready
What was the price for this?
$3.99/mth , $9.99 /QTR
i can definately vouch for wishosting as been with for almost a year and those guys are best value for money
Is @exception0x876 here yet?
I have gotten an....exception for him to get provider tag here, and have also informed Michael about this. It's up to Michael now whether he....Wish to join
Edited Wrong thread
@cyberte>; @cybertech said:
@cybertech excellent work! (I just read your comment now to discover I may have been duplicating your efforts, with some delay over the holidaze ...)
HS4LIFE (+ (* 3 4) (* 5 6))
U also invited him? Cool the more the merrier.
Thanks guys I am in.
Welcome onboard sir! Start this year with some smashing deals
Welcome! Waiting for LES Exclusive deal!
Indeed! Your first order is to have a LES exclusive deadpool-inducing deal!
hola @exception0x876
!pro-tip for those who don't already know: Wishosting deal of the day
Protip 2: Pay quarterly for best pricing.
Tip 3: pay with confidence
Tip 4: Use FatPal.
"Humanity is f*cked up" - Jay
Pay with confidence using Fatpal for the deal of the day for quarterly terms.
VPS reviews and benchmarks |
Now what's left is to Wish for the deal to come!
What? This deal is coming back?
Sometimes I like to check in with services running, especially since this box has had some uptime issues in the very beginning, but was professionally informed and fully resolved with detailed explanation on the whole process.
During my ticket with provider, I was told this feature isn't available (not that I needed it either), but suddenly after the fix and reboot, it is supported
to some it may be a big bonus, what can you spot from below?
Did a
diff
, it is VMX"Humanity is f*cked up" - Jay
@cybertech @FAT32 note that the OpenNebula setup might also allow slicing up your resources (given that you have multiple cores) ... though might have to jump through some hoops with only 1 IPv4 address
By the way might want to keep an eye on the current deal of the day - was out of stock last time I checked but I hear there might be moar after first batch of orders is processed ...
I am trying to reduce my idling collection
I cant believe how you guys can still keep your spending on hosting so low even though you bought machines like this.
Can't afford not to get deals like this one ... Pay with Confidence!
