IPv6: 1x /64 does that mean over a trillion IPs?
evnixevnix OG
edited January 2020 in General
I see VPS providers give out /64 IPV6
does that mean over a trillion or whatever unique IPs for a single VPS?
A bit of waste if that's the case
My Personal Blog ๐ŸŒŸ๐ŸŒŸ Backups for $1 ๐Ÿ”ฅ๐Ÿš€
ยซ1
    The entire IPv6 address space is about 340,282,366,920,938,463,463,374,607,431,768,211,456, which is approximately 340 undecillion, or 340 billion billion billion billion, addresses. I believe giving you about 0.00000000000000000000000008% of the IPs available is not really a waste.
    Thanked by (1)evnix
    CC must be laughing
  • @evnix /64 is, what, 18,446,744,073,709,551,616 addresses? That's enough to individually address each cell of your body.
    @foxone underestimates though, by my maths 2^-64 is 5.4210109e-20, so 5.42e-18% of the total address space. My maths is usually wrong though.
    Thanked by (1)evnix
  • Don't forget, one of the design reasons behind the enormous /64 subnet is so that hosts within it can participate in IPv6 without using DHCP or pre-allocated addresses, they can randomly generate a local address with no realistic risk of a clash.
    By design it's not intended that the address space WITHIN a /64 subnet will ever become heavily populated. Dividing up the IPv6 address space globally is all about the upper half (64 bits) of the address space not the full 128 bits.
    Thanked by (1)evnix
    Why no 64bit address?
  • Each /64 is enough for an entire space faring planet when we have inter stellar travel !!
    I bet there will be no hoarding!
    But will it be enough for multi-dimensional travel?
  • @Delong said: But will it be enough for multi-dimensional travel?
    You have a point, likely not with the infinite possibilities!
  • WSSWSS Retired
    Waiting for "No Man's Sky" patch to address this.
  • @WSS said: Waiting for "No Man's Sky" patch to address this.
    Well, he did promise it in the demo ?
  • RahulRahul OG
    edited January 2020
    @evnix said: I see VPS providers give out /64 IPV6
    Not a waste when its, IPv6 and the Internet of Things.
    Thanked by (2)evnix Amitz
  • WSSWSS Retired
    ..because everyone's poorly maintained 10 year old garage door opener that barely supports WPA2 in 2030 should be exposed to the world at large.
  • DanielDaniel OG
    edited January 2020
    @evnix said: A bit of waste if that's the case
    It's not a waste; it's required for some features to work properly. IPv6 was intentionally designed this way. See https://etherealmind.com/allocating-64-wasteful-ipv6-not/
    It's actually quite useful even on one server/VPS, as containers (LXC, Docker, etc) on the VPS can automatically get a public-facing IPv6 address, without you having to manually configure one. It's definitely useful to get at least a /64 on a home internet connection, as each one of your devices can get its own IP and not have to deal with NAT.
    Some providers will give you a /56, /52 or /48 range if you ask nicely, which lets you have your own subnetting.
    Thanked by (1)evnix
  • FHRFHR Hosting ProviderOG
    There is this great device called firewall.
  • WSSWSS Retired
    ...which are generally glorified NAT boxes in the majority of residences, except when IPv6 is involved with consumer hardware.
  • its not a waste
    Using a subnet prefix length other than a /64 will break many features of IPv6, amongst other things Neighbor Discovery (ND), Secure Neighborship Discovery (SEND) [RFC3971], privacy extensions [RFC4941], parts of Mobile IPv6 [RFC4866], PIM-SM with Embedded-RP [RFC3956], and SHIM6 [SHIM6]. A number of other features currently in development, or being proposed, also rely on /64 subnet prefixes.
    https://tools.ietf.org/html/rfc5375
  • edited January 2020
    We must conserve IPv6 space, so it doesn't suffer the same fate of IPv4.
    IP addresses are like an open buffeT and we ate them all.
    Those nice sweets people offer on a plate during celebrations, well taking one won't hurt, let's take another one and another, after a while - i can't possibly eat any more, but, let's take another one, the stomach has to take one for the team...
    While some people who can't reach the plate because i am pinching their hands with the fork while hugging the plate are left stranded, starving for sugars, transfattyacids and some proteins. Life is cruel...
  • I have TunnelBroker on OpenWrt home router and I requested a /48 following online guides.
    I found each of my devices takes about four addresses.
    Am I wasting too many addresses? Should I release the /48 and go back to /64?
  • @Janevski said: We must conserve IPv6 space, so it doesn't suffer the same fate of IPv4.
    There's enough IPv6 addresses for each human on Earth to have trillions of addresses, so no worries there :)
    @yoursunny said: I have TunnelBroker on OpenWrt home router and I requested a /48 following online guides.
    /48 is fine, particularly if you want to do any subnetting (ie. you want to create multiple /64 subnets yourself).
    There's really no concern about wasting addresses.
    You could give a /48 to every man, woman and child on earth and have only used up most of a single /15 worth of space, or 0.003% of the entire IPv6 space.
    and
    there are 240 trillion /48 allocations, which means every human on earth can receive 300,000 /48 allocations and we still won't be out
    (from https://serverfault.com/questions/588561/why-is-arin-etc-allocating-such-large-blocks-of-ipv6-addresses)
    Thanked by (2)Abdullah Janevski
  • IPv6 is future-proof, period.
    Thanked by (1)Clouvider
  • @Daniel said: There's enough IPv6 addresses for each human on Earth to have trillions of addresses, so no worries there
    Problem is, everyone thinks human population will reach 8 to 10 billion and shrink rapidly from there.
    We already see this trend in developed countries and everyone thinks this trend will continue in other countries as they get educated.
    But what if this assumption doesn't hold true? Currently the population is only limited due to earth's resources.
  • WSSWSS Retired
    Then we'll return to IPX/SPX as GOD and COUNTRY intended.
    Thanked by (2)skorous uhu
  • @WSS said: Then we'll return to IPX/SPX as GOD and COUNTRY intended.
    Now that's what I call a collision domain.
    Thanked by (1)WSS
  • WSSWSS Retired
    I really want to see this CD. Obviously this will be the first song:
    Thanked by (1)skorous
    If population reaches an unsustainable level there is a very dark way of getting population back to a sustainable level.
    I hope this won't happen.
    Thanked by (1)Abdullah
  • @terrorgen said: If population reaches an unsustainable level there is a very dark way of getting population back to a sustainable level.
    lol nope.
  • VPNVPN OG
    edited January 2020
    Here are the recommendations of IANA according to RFC3177:
    • /48 in the general case, except for very large subscribers.
    • /64 when it is known that one and only one subnet is needed by design.
    • /128 when it is absolutely known that one and only one device is connecting.
    We may think that servers need /128 at best, but /64 is better, as the sysadmin can have the great flexibility of choosing what address (and ports) to use for each application. Let's not also forget that Ipv6 blacklists usually list the whole /64 block. So /48 and /64 is much better for servers.
    Meanwhile we could start developing IPv8, for that moment when humanity will start exploring this galaxy by bending space. Maybe, by the time IPv8 is ready, companies like ColoCrossing and Scaleway will have proper IPv6 on their datacenters. Only time will tell, I don't know what future brings, I just hope that my organic body will sustain me long enough to see it all happening.
    There's no future in address based systems. IPv9 was developed and still ran out of addresses. https://tools.ietf.org/html/rfc1606
    The future belongs in a purely name based system, in which every packet carries a name (of any length), and routers deliver packets directly by name. You'll never run out of addresses again because we don't need any to begin with. https://named-data.net/project/execsummary/
    Thanked by (1)WSS
  • WSSWSS Retired
    But it all depends on what tag your packet identifies itself as..
