mc "Midnight Commander" wrong colors and keys
ehabehab Content Writer
edited March 2023 in Help
Hi
I use mc a lot in terminals, in some shared hosting the display and keys are wrong
it looks like this
down keys gives BBB "not working"
I maybe an env and comparing working and this one does not really help.
any advise how to fix deserves a kiss on the hand.
Thanks for any advises.
ehab
GNU Midnight Commander 4.7.0.2
Virtual File System: tarfs, extfs, cpiofs, ftpfs, fish, mcfs, smbfs
With builtin Editor
Using system-installed S-Lang library with terminfo database
With subshell support as default
With support for background operations
With mouse support on xterm and Linux console
With internationalization support
With multiple codepages support
Data types: char 8 int 32 long 64 void * 64 off_t 64 ecs_char 8
env
SHELL=/bin/ovh_ssh
HISTTIMEFORMAT=[%F %T]
PWD=/home/imok
LOGNAME=yoursunny
HOME=/home/somewhere
USERNAME=
LANG=en_US.UTF-8
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
SSH_CONNECTION=1.2.3.4 57474 5.5.5.5 22
TERM=xterm-256color
USER=FRANKZ
SHLVL=1
BASH_ENV=/home/FALZO/.bashrc
LD_LIBRARY_PATH=/mumbly/lupa/libs:
SSH_CLIENT=1.3.4.6 57474 22
OVH_ENVIRONMENT=development
TMOUT=300
OVH_APP_ENGINE_VERSION=3.8
OVH_APP_ENGINE=wsgi
MAIL=/var/mail/xrout
SSH_TTY=/dev/pts/0
_=/usr/bin/env
Thanked by (1)Falzo
  • ehabehab Content Writer
    maybe i tag @Not_Oles he is a shell dude. Any suggestions
    Hi @ehab! Thanks for tagging me. Wow, I wish I could help! I never use mc except when I get dumped into it by certain install scripts. So I am clueless™ about mc. :( But surely someone here at LES will be able to help. Always best wishes!
    Thanked by (1)ehab
  • @ehab said: Thanks for any advises.
    I also use mc a lot, but I haven't seen this kind of issue in a long time
    TERM=xterm-256color
    So you're using xterm -- good
    What does locale show?
    LANG=fr_FR.UTF-8
    LANGUAGE=
    LC_CTYPE="fr_FR.UTF-8"
    LC_NUMERIC="fr_FR.UTF-8"
    LC_TIME="fr_FR.UTF-8"
    LC_COLLATE="fr_FR.UTF-8"
    LC_MONETARY="fr_FR.UTF-8"
    LC_MESSAGES="fr_FR.UTF-8"
    LC_PAPER="fr_FR.UTF-8"
    LC_NAME="fr_FR.UTF-8"
    LC_ADDRESS="fr_FR.UTF-8"
    LC_TELEPHONE="fr_FR.UTF-8"
    LC_MEASUREMENT="fr_FR.UTF-8"
    LC_IDENTIFICATION="fr_FR.UTF-8"
    LC_ALL=
    should this be changed to :
    LANG=en_US.UTF-8
    LC_CTYPE="en_US.UTF-8"
    LC_NUMERIC="en_US.UTF-8"
    LC_TIME="en_US.UTF-8"
    LC_COLLATE="en_US.UTF-8"
    LC_MONETARY="en_US.UTF-8"
    LC_MESSAGES="en_US.UTF-8"
    LC_PAPER="en_US.UTF-8"
    LC_NAME="en_US.UTF-8"
    LC_ADDRESS="en_US.UTF-8"
    LC_TELEPHONE="en_US.UTF-8"
    LC_MEASUREMENT="en_US.UTF-8"
    LC_IDENTIFICATION="en_US.UTF-8"
    LC_ALL=
  • @ehab said: should this be changed to :
    No, a UTF-8 locale is good (whether fr or en)
    Are you using (real) xterm or a console?
    Thanked by (1)ehab
    edited March 2023
    i am using Terminal "ssh", how to find out?
    So you're not using (real) xterm
    Is the system in question running Debian? If so, what does more /etc/default/console-setup show?
    Thanked by (1)ehab
    $ cat /etc/default/console-setup
    cat: /etc/default/console-setup: Aucun fichier ou dossier de ce type
    "No such file or folder"
    Okay, my best guess is that you're not using an appropriate console font for mc
    Does man console-setup give anything?
  • As su -, try dpkg-reconfigure console-setup
  • On my system, the output of more /etc/default/console-setup is:
    # CONFIGURATION FILE FOR SETUPCON
    # Consult the console-setup(5) manual page.
    ACTIVE_CONSOLES="/dev/tty[1-6]"
    CHARMAP="UTF-8"
    CODESET="Lat15"
    FONTFACE="Fixed"
    FONTSIZE="8x16"
    VIDEOMODE=
    # The following is an example how to use a braille font
    # FONT='lat9w-08.psf.gz brl-8x8.psf'
    In the worst case, you could copy this and then log out and in again
    @angstrom , i don't have sudo rights since its a shared env.
    all i can work with is the .bash* files at ~/
    i will continue tomorrow, need to sleep soon
    thanks a lot for you help , talk soon
    Thanked by (1)angstrom
  • edited March 2023
    I see
    mc doesn't work with all console fonts, so I strongly suspect that this is the problem
    Here's a suggestion. First, create the file ~/.console-setup. Then copy the following text into this file:
    CHARMAP="UTF-8"
    CODESET="Lat15"
    FONTFACE="Fixed"
    FONTSIZE="8x16"
    VIDEOMODE=
    Then log out and in and see whether this helps
    (Good night)
  • @ehab said: i am using Terminal "ssh",
    So you may not be using a console after all
    Nevertheless, it wouldn't hurt to try what I suggested just above
  • @ehab I see what you did there. Hugs and kisses ♡♡♡
    Same as @angstrom also using mc a lot, but haven't encountered this issue. I think he is already onto it, so I guess you two will get it fixed somehow.
    Thanked by (1)ehab
    the .console-setup. made sense but unfortunately didn't have any effect.
    thanks for your suggestions thou. I will continue.
    have a nice week ahead.
  • Try a different Terminal emulator?
    Thanked by (1)ehab
    By the way, when you say "Terminal", do you mean the terminal emulator of MacOS?
    I assume that you've checked that mc works on another server but using the same terminal emulator (so that we know that the issue is particular to one server)
    Any chance of using X-forwarding?
    Thanked by (1)ehab
  • edited March 2023
    Another try: on the server, what does more /etc/vconsole.conf show?
    Thanked by (1)ehab
  • edited March 2023
    @ehab said:
    Hi
    If the problem exists on several VPS/servers it is probably in your local settings (on your PC)
    Thanked by (1)ehab
    "From the diamonds nothing is born, from the manure the flowers are born ..."
    F. De Andrè --- Free NAT KVM
    i don't use the mac, but i tried it on macbook and same bad outcome, both colors and keys not good.
    :( no go
    file does not exists.
    only in 2 shared environments. Otherwise all is good.
    @flips said: Try a different Terminal emulator?
    YES
    this fixed my problem
    now that deserves a kiss on the hand
    @Ganonk style
    Thanked by (3)Ganonk Amadex flips
    @angstrom
    i started an alpine docker image and at interactive env
    HOSTNAME=38953153f826
    SHLVL=1
    HOME=/root
    TERM=xterm
    PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    PWD=/
    so i check my current local env
    TERM=xterm-256color
    and changed to
    export TERM=xterm
    vola ... mc is happy
    Thanks to all.... maybe i should put this in the tips.
    high 5 to dear angstrom
  • I was just about to ask: what does dpkg-query -l console-setup show?
    But I guess that we can stop now :)
    Thanked by (1)ehab
  • edited March 2023
    @ehab said:
    @angstrom
    SHLVL=1
    HOME=/root
    TERM=xterm
    PWD=/
    TERM=xterm-256color
    and changed to
    export TERM=xterm
    I'm glad that this works, but needing to use an Alpine docker image for this seems to be (supreme) overkill, if I may say so! :)
    Also, the difference between xterm-256color and xterm shouldn't matter for this -- both should work! I've just tested both, and they both work with mc
    I would still maintain that the original problem is probably a console font issue (but this would be tricky to solve if you don't have admin rights)
    edited March 2023
    just to add another tip
    in the .ssh/config this can be added
    Host somename
      HostName yoursunny.mega-center.mekongvps
      user angstrom
      RemoteCommand TERM=xterm $SHELL
      RequestTTY yes
    last 2 lines are important
    Host somename
      user angstrom
      RequestTTY yes
    Glad that this works, but normally, it shouldn't be necessary to have to stipulate this :)
    Thanked by (1)ehab
  • Thanked by (1)ehab
    AmadexHosting ForumsWebshop: Guide to Start Selling Online • Free Debit Card & Online Bank Account 🤑
  • Maybe you installed the politically correct version?
    Thanked by (1)root
