@deank said:
I just pay for Tube premium. Given how much I watch/listen it, I feel it's worth it.
Not paying for a cable service certainly frees up the budget a lot. I don't even watch TV. Haven't watched it for at least a decade.
Same here.. paying for premium is far better instead of compromise the Google account
Protip: If you have an Indian IP address or VPN/VPS, purchase your Youtube Premium Subscription through that, costs me about 23 AUD (15 USD) for 1 year of Premium, don't need to use the Indian VPS again except for renewal.
I think I spun up a Vultr VM in Mumbai with OpenVPN AS preinstalled for about 20 minutes, cost me about an extra 1 cent for the 20 minutes of VPS usage.
ReVanced is working great on non-rooted device. And the last microG release is really (finally) using less battery!
Google Play blocked the installation. It says Unsafe App Blocked.
If it's a side-loaded apk, Google will always give you the "unknown third party apl, potentially dangerous" ⚠️🚨. This happens with any third party app you try to install usually. Not sure if there was an extra warning in your scenario aside from the standard one? The standard one you would also get when sideloading AdGuard, FossDroid or any other apk. Fwiw, if my Xiaomi Avast powered Antivirus (installed by default) does actually do its job, technically, all apps I install (even third party ones outside of Playstore) are automatically scanned by Xiaomi's Avast Scanner prior to the installation completing. W
Fwiw, with New Pipe it didn't trigger any warning from Avast
But this one prevented me to install it.
Just an okay button.
The usual warning, can be skipped easily.
there should be a dropdown or something from which you can still allow it.
I can't install Youtube Music, Spotify patched works great though.
Yeah, I think there is something that doesn't look clickable above the Okay button. Try that.
@Fritz said:
Oke I got everything sorted.
I have to disable Google Play Protect.
Downloaded the APK from 3rd party site, unsigned version.
ApkPure/Apkmirror/FOSSDroid is what I usually use for this (or, if available always the apk download on the official developer's site; e.g. AdGuard APK from their website rather than APKPure/Mirror).
It's unfortunate that YouTube Vanced is no longer available, but it's good to know that there are other alternatives out there. Thanks for the heads up.
Will that work on non-rooted device?
https://microlxc.net/
Edit: me dumb w/ foreign currency conversions
ytdl.pro - Free to use Youtube-DL Cloud Downloader
Been using Smart Tube on android for years never had a problem.
Never use YouTube unless I am on mobile so just having an android app is cool with me.
As every app threatening google. Does it mean it's unsafe for you?
Yes
ThemeForest Profile
ThemeForest Profile
Just need to allow side-loaded apks most likely. https://www.xda-developers.com/how-to-sideload-install-android-app-apk/
Warning can be skipped.
Should look smth like this:
which microG you are using?
one comes with vanced manager or another one developed by some developers of revanced?
ThemeForest Profile
Just signup for YouTube Argentina and pay 1,20€/m.
