Looking for an easy to use open source project (pastbin)
Hi everyone
I'm planning to deploy a pastebin on my server to record and share my own python code, any recommendations for open source projects?
Server configuration:
1 vCPU, 1G RAM, 40G HDD
I need this project can use curl command to upload the pasted content, preferably with syntax highlighting (no syntax highlighting is fine, it is also acceptable)
There are many similar projects on Github, I do not know which is better and which is easier to deploy.
Thanks
Privatebin
I found this: https://github.com/matze/wastebin
Just for the demo, it seems pretty good, has anyone used it?
There is no authentication, your service will be open to the public. I'm using zipline and it's pretty good.
Thanks, I ended up choosing zipline and feel very good about it.
