Looking for backup server 10TB
I am in need of a new backup server, as I currently use Mammoth Storage 2022 from Serverica, which offers 8TB of storage, 8GB RAM, and 4 CPUs for $20/month. However, its performance is quite slow, likely due to an excess of virtual machines on the node.
I am searching for an alternative with a similar price range, requiring 8-10TB+ of storage, 10TB of monthly bandwidth on a 1Gbps+ connection, and the ability to support a single website utilized for delivering backup files to my clients. Although access to the site is minimal, it should still efficiently handle server requests when necessary. I would appreciate a solution that is not as oversold as my current server.
Additionally, I would prefer payment in Bitcoin and am open to server locations in the EU, US, or Canada, as the server is solely for backup purposes.
  • @crunchbits has it.
    KangServer.id - Love benchmarking VPS / Server
    Have idling VPS? DM me!
  • I am in need of a new backup server, as I currently use Mammoth Storage 2022 from Serverica, which offers 8TB of storage, 8GB RAM, and 4 CPUs for $20/month. However, its performance is quite slow, likely due to an excess of virtual machines on the node.
    Slow disk or network?
  • AdvinAdvin Hosting Provider
    edited April 2023
    Use a Hetzner Cloud VPS and mount a storage box, cost is like 15 euro for 10TB storage and 2GB RAM VPS.
    Hetzner Cloud VPS in the same location can transfer at 1 Gbps to the Hetzner storage box, so that's why I recommend getting one with the storage box. Connecting from external providers directly to the storage box is a bit slower in my experience =)
    If you want a more simpler solution, Crunchbits is probably the better option, because the Hetzner storage box route requires you to configure it as a CIFS mount in the Cloud VPS rather than having it show up like a standard HDD.
    Here the yabs;
    #                     v2023-03-24                    #
    Thu Apr  6 02:17:42 PDT 2023
    Uptime     : 39 days, 5 hours, 37 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
    CPU cores  : 4 @ 2591.803 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 7.6 GiB
    Swap       : 0.0 KiB
    Disk       : 7.8 TiB
    Distro     : CentOS Linux 7 (Core)
    Kernel     : 3.10.0-1160.59.1.el7.x86_64
    VM Type    : XEN
    Net Online : IPv4
    ISP        : Rica Web Services
    ASN        : AS26832 Rica Web Services
    Host       : Rica Web Services
    Country    : Canada
    Read       | 459.00 KB/s    (114) | 2.34 MB/s       (36)
    Write      | 482.00 KB/s    (120) | 2.54 MB/s       (39)
    Total      | 941.00 KB/s    (234) | 4.88 MB/s       (75)
    Read       | 2.58 MB/s        (5) | 4.38 MB/s        (4)
    Write      | 2.81 MB/s        (5) | 4.52 MB/s        (4)
    Total      | 5.39 MB/s       (10) | 8.90 MB/s        (8)
    Clouvider       | London, UK (10G)          | 956 Mbits/sec   | 934 Mbits/sec   | 76.8 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 85.7 ms
    NovoServe       | North Holland, NL (40G)   | 936 Mbits/sec   | 933 Mbits/sec   | 80.3 ms
    Uztelecom       | Tashkent, UZ (10G)        | 807 Mbits/sec   | 860 Mbits/sec   | 171 ms
    Clouvider       | NYC, NY, US (10G)         | 929 Mbits/sec   | 930 Mbits/sec   | 86.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 985 Mbits/sec   | 959 Mbits/sec   | 42.5 ms
    Clouvider       | Los Angeles, CA, US (10G) | 934 Mbits/sec   | 940 Mbits/sec   | 70.2 ms
    Geekbench 6 test failed. Run manually to determine cause.
    YABS completed in 14 min 18 sec
    I have some concerns about Hetzner's practices, and I try to avoid them. However, I will definitely give a @crunchbits instance a try if it can provide better results. If there are more providers, I'm all in for backup redundancy.
    Thanks for the help so far!
    Thanked by (1)bdl
  • CalinCalin Hosting Provider
    Hello sir it s possible give you
    10 TB HDD Storage (Raid 5)
    10 GB Ram
    4 Dedicated CPU
    1 GBps port speed shared
    10 TB BW download / 10 TB BW upload
    ROmanica location
    20$/month
    Regards,
    Calin
    10 GB Ram
    4 Dedicated CPU
    ROmanica location
    20$/month
    Regards,
    Calin
    Can you give me a link to signup?
    Thank you!
  • @Advin said: Use a Hetzner Cloud VPS and mount a storage box, cost is like 15 euro for 10TB storage and 2GB RAM VPS.
    It's about 40euro/m for 10TB and you don't get anything like 1gbps transfer from it, especially when mounting it as a file system. Other than that, it works pretty well. I have 5TB there and use Borg for backup these days, so I don't have to mess with accessing through a VPS. It also supports rsync and a few other protocols. They additionally have the somewhat more expensive Storage Share product which gives you a Nextcloud server.
    Hello @btchost https://panel.ihostart.com , open ticket on website and post this thread link for create you invoice
    Regards,
    Calin
    edited April 2023
    Guess I misremembered the price, but you absolutely need to mount it or proxy it through a Hetzner Cloud VM in order to hit 1 Gbps. For some reason, I've been able to hit the maximum 1 Gbps on a Hetzner Cloud VM in the same location, or proxying my storage box through a Hetzner Cloud VM and setting up a share on the VM
    Transferring from another provider resulted in throughput grinding to a halt. My assumption is that they somehow limit the traffic from external providers and don't for internal traffic between servers in the same DC.
    It's 20 euro for 10TB
  • edited April 2023
    @btchost said:
    Slow disk
    IMO, something is definitely wrong.
    I have a Mouse package (much smaller) and the speeds I'm getting are very good - like 250 or 280 MB/s (do not recall, as didn't bench it for a while).
    The only difference I noticed is the OS - I use Debian 10 "Storage", which was installed by default. Didn't manage to try other OSes yet due to the lack of time.
    So I would surely start from contacting either @servarica_hani or support and asking them to have a quick look.
