How much power do I need for a seed box?
Curious if a 2 core box with a GB6 score of 600 and multi of 1100 with a large disk will be adequate to handle a a few applications?
Team push-ups!
    edited April 2023
    Yes, unless you wish to transcode :)
    Speed will be limited as you have only 2 Cores.
    P.S Also keep in mind, that apps will be slower than you expect, especially if you have large media.
  • 2 cores + 512 MB RAM + large HDD/SSD + good internet speed is all you need.
    1 core is also enough, but 2 is better. Download speed does not really change if you have 2 or more cores so dont worry about that, but it will limit the number of active torrents. So if you download 5 torrents with 50 max peers, you will get better speeds with 4 or more cores, but this is again limited by your disk speed. If you are using SSD + 1 Gbps (or higher) internet speed, then 4 cores are better.
    If you run other applications, increase RAM accordingly as torrent can easily eat up 512 MB of ram.
  • few years ago i'm running transmission-web+syncthing in ramnode's 128mb vps, it can seed 30+ torrent just fine.
    It was difficult since the vps is too small to run some sort of RSS downloader (like deluge-daemon+rss plugin or flexget+transmission-web) since it consume too much RAM.
    In current year, qbitorrent-nox already have RSS integration (after like a decade waiting lol), so now I have setup qbitorrent-nox + syncthing in virmach's 384MB ram, run just fine with +20 active seeding. can't add more since the disk is limited
    Thanked by (1)tenji
  • 1000 kilowatts.
    1.21 JiggaWattz
    Thanked by (3)Janevski cybertech shallow
  • Stacksocial link (aff) containing a gift of $10 after your first purchase.
  • @shallow said:
    MAX
    No metal for you.
  • It depends. Is turbo on or off?
  • My seedbox is a very old Atom C2350 Dual Core with 4GB of RAM and it works fairly well. The HDD on it is the limiting factor, but if I had an SSD I could probably max out the 1Gbps link it has. Only time it really shows its weakness on the CPU side is when decompressing large archives, so I pull those down locally and decompress.
  • Depends on how heavy the torrent stack is. Optimized client with nothing else running will be fine as long as you don't throw a bunch of torrents at it.
  • How much is this cost?
    $3.50 per month?
  • I have a small vps C2338 2*1.8GHz, GB5 score 298, running transmission, and no problem at all. Speedtest reaches up to 928M( 1G port).
  • @Astro does these comments answer your question?
