microLXC Public Test
1678911
  • @yoursunny said:
    Sponsors NexusBytes
    Purged.
    Thanked by (1)ehab
    @Neoon said:
    You can watch it burn if you want.
    Remember when OVH was on fire and there was a screenshot of one if the servers thermals monitoring. Ill be like that
  • Thank you 🇯🇵
  • Hi @Neoon Auckland lxc is having problem I guess.
    I can't ssh into it. Connection refuse.
    I'll try to terminate and re launch.
    The Machine has been rebooted from the ISP, there was no maintenance announcement or anything.
    Besides that, I don't see anything wrong.
  • The Monitoring didn't picked up the reboot, iptables forwarding rules where not applied.
    Should be fixed.
    Should be fixed.
    Everything is working now! ;)
  • 8e93-6011-cf98-0168
    Thank you.
    MicroLXC is lovable.
  • 653b-fb70-08ed-3fce
    Thanks!
  • I dislike the current state of microlxc.
    The ongoing issues with LXD, ongoing Network issues in some Locations, does not really reach the quality level I wanted to provide.
    Plus, I can only code for a few hours per day and I have a lot of projects to code on.
    Hence I made the decision to close the registration for new accounts, for now.
    No, I don't have in mind to kill the project, however, purging LXD and replacing it internally with Proxmox, which is more reliable in the long run.
    Yea I know Bookworm is going to ship with LXD, without snap, however I don't know if this would make LXD feasible again.
    That would be a thing to figure out.
  • Likely in 4-6 weeks I am going to have 1-2 nodes available to carry out a test for Debian 12 / Bookworm with LXD.
    This Test will be Public as before, however time limited.
    Approximately 3 months, up to 6 months, if it's a success indefinitely.
    At this point I would either switch the rest of the systems to Debian 12 or Proxmox.
    Thanked by (3)terrorgen adly ElonBezos
  • Mentally strong people use plain LXC.
    lxc-create
    lxc-unpriv-start
    lxc-unpriv-attach
    LXC has fewer layers.
    It allows more precise control and customization.
    Is the code still open? Nothing related appears on GitHub anymore.
    It was never open source.
    lxc-create
    lxc-unpriv-start
    lxc-unpriv-attach
    I don't think LXD itself is to blame, I rather think, that additional shit what is shipped with snap packages, are causing issues.
    The shit I have seen with Ubuntu 20.04 and snap, applications before never having issues and out of the sudden, are slower and randomly crashing or getting unresponsive.
    Chromium on Ubuntu, its a crap experience.
    You are loosing like 20%-30% alone on performance.
    Thanked by (1)bdl
    Perhaps it is NanoKVM I was thinking of? I remember a NanoKVM-Tools repo.
    Yea, I removed the NanoKVM-Tools repo, since it was outdated and kinda janky.
    if there is interest, I might upload the better code and network setup.
    Thanked by (3)adly ariq01 Wonder_Woman
  • IPv6 died in NL, working on it.
    Thanked by (1)carlin0
    Fixed.
    Thanked by (3)Brueggus carlin0 ElonBezos
  • @Neoon I saw on your signup page you are asking for "public key" instead of "password" for the VPS setup. This is very good thing to do and I hope more and more providers starts doing this. Using a password for a server, specially if you enable root ssh access, is VERY insecure.
    Thanked by (3)Erisa Ganonk Neoon
  • edited April 2023
    I decided to spin up a microlxc instance in Auckland last night to run a few mtrs to my other servers, but it looks like something went slightly wrong with IPv6 setup. It's the debian template if that's relevant.
    In the control panel the address is ... ::2, but the container actually has a randomised address in the same /64.
    There doesn't seem to be an /etc/network/interfaces, so not sure this gets set up in lxc. Is this configured host-side or can I just make the interfaces file like I would on a KVM instance?
    make the interface file
    Thanked by (1)ralf
    "From the diamonds nothing is born, from the manure the flowers are born ..."
    F. De Andrè --- Free NAT KVM
    If your VM or Container gets a /64 IPv6, the initial IPv6 is randomly (by mac) assigned by dnsmasq.
    It doesn't update in the Panel, yet.
    Thanked by (1)ralf
    I pushed a patch, the current IPv6 should be now reflected in the Panel.
    However, only for new Deployments or if you Reinstall your VM, since the database still has the old ::2 as record.
    Thanked by (1)ralf
  • @Abdullah dropped a fat SG Machine, which gives me the opportunity to use a different storage backend.
    Hence I likely open the registration again, since the other stuff is delayed, so this can be tested meanwhile.
  • @Ganonk said:
    SG is not ready jet, IPv6 is not working as expected, will hopefully get it fixed this week.
    Thanked by (1)Ganonk
  • New ETA for SG is Friday.
    Thanked by (3)Wolveix Ganonk ElonBezos
  • NL was down, its partially back up, prob. router issue.
    As of right now, someone is looking into it.
    Thanked by (2)Ganonk carlin0
    No update yet, still waiting for the Subnet to get routed.
