Looking for a BGP VPS in the Netherlands
Hi,
I'm looking for a VPS + BGP session somewhere in the Netherlands.
My desired specs:
2 CPU Cores
2 GB RAM
10 GB SSD
2 TB Traffic/mo (I usually stay well below 1 TB)
1 IPv4 + /64 IPv6
BGP Session
Budget: around USD 30/year. I'm fine with a reasonable one-time fee for the BGP session.
I'm sure Rick (Bakker-IT) can help you out
https://v6node.com
Check bgp.services
TBH with this price you may consider to buy a regular VPS + BGP tunnel
Also if you decided to buy a VPS + BGP, then it's not a bad idea to find a provider who provides NL-IX port
@Brueggus Do all your dnscry.pt nodes have BGP enabled? Anycast?
No, none of them has. That'd be pretty awesome but also pretty expensive.
