Needed a budget Dedi under 40USD/month (EU/APAC)
Needed a dedicated server baseline requirements are below, No Hetzner pls.
Processor Intel series (newer if possible) 4c/8t
Storage minimum 400Gb
Ram minimum 24GB
Bandwidth: >5Tb at least 1Gbps if possible
Dm or reply if available, Thanks!!
Hello @hostaspace it's possible give you
2x l5630 8c/16t
32 Gb ram
Location Europe/Romania
32 TB BW @ 1 Gbps port speed
1x dedicated IPv4
1x 960 GB SSD Enterprise
For 45 euros/month
Regards
If you can up your budget to within 50-60, you should be able to find alot of provider can provide you in Europe. As for APAC within this budget range, why not consider a VPS instead of DEDI. As APAC cost is really high, for such budget it will be really hard to find.
TemasekTech - AS139859 and AS209187
Building Cloud Technology with Global Network
Official Website - https://www.TemasekTech.com
EU (Italy)
i5 6500
SSD 480GB
RAM 32GB DDR4
10TB @ 1Gbps
€35 + 22% vat if private customer
C1V Hosting is a leading data center, cloud, hosting, and connectivity provider based in Italy. Our state-of-the-art datacenter is located in Pomezia (Rome) and offers a range of services including VPS, dedicated servers, colocation, and connectivity solutions.
The end is nigh.
Because of OP's username.
First thank you all for the response.
Do you provide Ipv6 ??
Yea, somewhat want to save some $$ just because i need for personal research work uses as already have colo and good dedi's. but yea if i cant find any go with AX-44 (EU) or OVH Advance-1 Gen 2 (APAC).
Can @OVHcloud_APAC confirm that the Intel Xeon-E 2386G iGpu working or not ?? as i find that its not even enabled in BIOS.
Thats to much and no raid
Haha, you are very much on Δ-9-tetrahydrocannbinol... the end is nigh or high depending on CB(1) receptor. Better to have some bzd anyway, the username is random not denote my work area.
Hello @hostaspace unfortunetly no , but it s possible make yourself tunnel
Regards,
Calin
DMed you with surprise offer!
https://www.kuroit.com - Managed cPanel Hosting & VPS Hosting in UK
Hi there, unfortunately we don't offer iGPU on the server. We have a bunch of offers currently ongoing : https://www.ovhcloud.com/en/lp/asia-pacific-hosting-deals/
@OVHcloud_APAC when I ordered .ovh domain on ovh website, I paid and the dns order fail ,OVH rejected to refund the money.
it was some months ago.
Get a £30 oneprovider with 2 x 1tb ssd and unlimited traffic on 1gbit. Works perfect for my iso hunting
Hi @nightcat , did you have a ticket # that you can share with us so we can have a look? Thanks!
@OV> @OVHcloud_APAC said:
Thank you very much, it's not a lot of money. I have DM you .
