Needed a budget Dedi under 40USD/month (EU/APAC)
Needed a dedicated server baseline requirements are below, No Hetzner pls.
Processor Intel series (newer if possible) 4c/8t
Storage minimum 400Gb
Ram minimum 24GB
Bandwidth: >5Tb at least 1Gbps if possible
Dm or reply if available, Thanks!!
  • CalinCalin Hosting Provider
    Hello @hostaspace it's possible give you
    2x l5630 8c/16t
    32 Gb ram
    Location Europe/Romania
    32 TB BW @ 1 Gbps port speed
    1x dedicated IPv4
    1x 960 GB SSD Enterprise
    For 45 euros/month
    Regards
    Thanked by (1)hostaspace
  • TemasekTechTemasekTech Hosting Provider
    If you can up your budget to within 50-60, you should be able to find alot of provider can provide you in Europe. As for APAC within this budget range, why not consider a VPS instead of DEDI. As APAC cost is really high, for such budget it will be really hard to find.
    TemasekTech - AS139859 and AS209187
    Building Cloud Technology with Global Network
    Official Website - https://www.TemasekTech.com
  • c1vhostingc1vhosting Hosting Provider
    Ram minimum 24GB
    EU (Italy)
    i5 6500
    SSD 480GB
    RAM 32GB DDR4
    10TB @ 1Gbps
    €35 + 22% vat if private customer
    Thanked by (1)ehab
    C1V Hosting is a leading data center, cloud, hosting, and connectivity provider based in Italy. Our state-of-the-art datacenter is located in Pomezia (Rome) and offers a range of services including VPS, dedicated servers, colocation, and connectivity solutions.
  • The end is nigh.
    Because of OP's username.
  • First thank you all for the response. :)
    @Calin said: 1x 960 GB SSD Enterprise
    Do you provide Ipv6 ??
    Yea, somewhat want to save some $$ just because i need for personal research work uses as already have colo and good dedi's. but yea if i cant find any go with AX-44 (EU) or OVH Advance-1 Gen 2 (APAC).
    Can @OVHcloud_APAC confirm that the Intel Xeon-E 2386G iGpu working or not ?? as i find that its not even enabled in BIOS.
    @c1vhosting said: 22% vat if private customer
    Thats to much :'( and no raid
    @deank said:
    The end is nigh.
    Haha, you are very much on Δ-9-tetrahydrocannbinol... the end is nigh or high depending on CB(1) receptor. Better to have some bzd :p anyway, the username is random not denote my work area.
    Hello @hostaspace unfortunetly no , but it s possible make yourself tunnel
    Regards,
    Calin
  • KuroitKuroit Hosting Provider
    Ram minimum 24GB
    DMed you with surprise offer! :)
    https://www.kuroit.com - Managed cPanel Hosting & VPS Hosting in UK
  • OVHcloud_APACOVHcloud_APAC Hosting Provider
    Hi there, unfortunately we don't offer iGPU on the server. We have a bunch of offers currently ongoing : https://www.ovhcloud.com/en/lp/asia-pacific-hosting-deals/
    Thanked by (2)FrankZ hostaspace
  • @OVHcloud_APAC when I ordered .ovh domain on ovh website, I paid and the dns order fail ,OVH rejected to refund the money.
    it was some months ago.
  • Get a £30 oneprovider with 2 x 1tb ssd and unlimited traffic on 1gbit. Works perfect for my iso hunting
    Hi @nightcat , did you have a ticket # that you can share with us so we can have a look? Thanks!
    Thank you very much, it's not a lot of money. I have DM you .
