OVH KS-LE for transfer (ie/eu account)
ehab
Content Writer
hi,
i have KS-LE for transfer
Next Renewal: Before 24 July 2023 (€12.99 excl. VAT at €16.10 VAT incl.)
Hardware Info:
CPU-Intel Xeon E3-1245v2 - 4c/8t - 3.4 GHz/3.8 GHz
RAM-16 GB 1333 MHz
Data disks-2 x 480 GB HDD SATA Soft RAID
Ipv4 100/1000Mbps
i assume - Ipv6 1000/1000Mbps -
asking price €16.10 + you pay paypal fees.
its easy to transfer servers on same (ie/eu account) , all i need is you OVH handle "nice" e.g : LLNNNNN-ovh i change contacts and should be done in 5 min.
let me know if you are interested, thanks hostaspace for template.
ehab
# Yet-Another-Bench-Script #
# v2023-04-23 #
Sun Jun 18 15:16:00 UTC 2023
Uptime : 11 days, 18 hours, 12 minutes
Processor : Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
CPU cores : 8 @ 3800.000 MHz
AES-NI : ✔ Enabled
RAM : 15.5 GiB
Swap : 2.0 GiB
Disk : 437.7 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.15.107-2-pve
VM Type : NONE
ISP : OVH SAS
ASN : AS16276 OVH SAS
Host : OVH ISP
Country : France
Read | 194.51 MB/s (48.6k) | 281.05 MB/s (4.3k)
Write | 195.03 MB/s (48.7k) | 282.53 MB/s (4.4k)
Total | 389.55 MB/s (97.3k) | 563.59 MB/s (8.8k)
Read | 245.95 MB/s (480) | 261.17 MB/s (255)
Write | 259.02 MB/s (505) | 278.56 MB/s (272)
Total | 504.97 MB/s (985) | 539.73 MB/s (527)
Clouvider | London, UK (10G) | 95.3 Mbits/sec | 509 Mbits/sec | 4.08 ms
Scaleway | Paris, FR (10G) | 95.4 Mbits/sec | 491 Mbits/sec | 4.16 ms
NovoServe | North Holland, NL (40G) | 95.3 Mbits/sec | 926 Mbits/sec | 5.92 ms
Uztelecom | Tashkent, UZ (10G) | 37.5 Mbits/sec | 165 Mbits/sec | 99.1 ms
Clouvider | NYC, NY, US (10G) | 34.1 Mbits/sec | 29.3 Mbits/sec | 76.3 ms
Clouvider | Dallas, TX, US (10G) | 28.8 Mbits/sec | 332 Mbits/sec | 114 ms
Clouvider | Los Angeles, CA, US (10G) | 23.0 Mbits/sec | 41.3 Mbits/sec | 136 ms
Test | Value
Single Core | 743
Multi Core | 2591
Full Test | https://browser.geekbench.com/v6/cpu/1641041
$ lshw -class disk
*-disk:0
description: ATA Disk
product: INTEL SSDSC2KB48
physical id: 0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 0132
serial: PHYF003502XV480BGN
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096 signature=ceaf83fe
*-disk:1
physical id: 1
bus info: scsi@1:0.0.0
logical name: /dev/sdb
version: 0132
serial: PHYF00260CQ7480BGN
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096 signature=6e6333fa
$ smartctl -a /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107-2-pve] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Intel S4510/S4610/S4500/S4600 Series SSDs
Device Model: INTEL SSDSC2KB480G8
Serial Number: PHYF003502XV480BGN
LU WWN Device Id: 5 5cd2e4 1521b435a
Firmware Version: XCV10132
User Capacity: 480,103,981,056 bytes [480 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jun 18 15:34:13 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x05) Offline data collection activity
was aborted by an interrupting command from host.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 32) The self-test routine was interrupted
by the host with a hard or soft reset.
Total time to complete Offline
data collection: ( 2) seconds.
capabilities: (0x79) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 2) minutes.
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 18932
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 42
170 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 40
175 Power_Loss_Cap_Test 0x0033 100 100 010 Pre-fail Always - 2621 (42 65535)
183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error_Count 0x0033 100 100 090 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Drive_Temperature 0x0022 063 060 000 Old_age Always - 37 (Min/Max 22/40)
192 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 40
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 37
197 Pending_Sector_Count 0x0012 100 100 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 1647254
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 2109
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 56
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 1135868
232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 098 098 000 Old_age Always - 0
234 Thermal_Throttle_Status 0x0032 100 100 000 Old_age Always - 0/0
235 Power_Loss_Cap_Test 0x0033 100 100 010 Pre-fail Always - 2621 (42 65535)
241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 1647254
242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 2102093
243 NAND_Writes_32MiB 0x0032 100 100 000 Old_age Always - 3595273
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 18328 -
# 2 Short offline Completed without error 00% 18326 -
# 3 Short offline Completed without error 00% 18326 -
# 4 Short offline Completed without error 00% 18324 -
# 5 Short offline Completed without error 00% 18321 -
# 6 Short offline Completed without error 00% 18320 -
# 7 Short offline Completed without error 00% 2 -
# 8 Short offline Completed without error 00% 2 -
# 9 Short offline Completed without error 00% 1 -
#10 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
$ smartctl -a /dev/sdb
Serial Number: PHYF00260CQ7480BGN
LU WWN Device Id: 5 5cd2e4 15219ff20
Local Time is: Sun Jun 18 15:34:57 2023 UTC
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 23050
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
174 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 22
175 Power_Loss_Cap_Test 0x0033 100 100 010 Pre-fail Always - 2615 (23 65535)
190 Drive_Temperature 0x0022 062 059 000 Old_age Always - 38 (Min/Max 23/41)
192 Unsafe_Shutdown_Count 0x0032 100 100 000 Old_age Always - 22
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 38
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 122878
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 542
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 94
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 1382942
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0
235 Power_Loss_Cap_Test 0x0033 100 100 010 Pre-fail Always - 2615 (23 65535)
241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 122878
242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 2010273
243 NAND_Writes_32MiB 0x0032 100 100 000 Old_age Always - 863529
No Errors Logged
# 1 Short offline Completed without error 00% 22446 -
# 2 Short offline Completed without error 00% 22444 -
# 3 Short offline Completed without error 00% 22444 -
# 4 Short offline Completed without error 00% 22442 -
# 5 Short offline Completed without error 00% 22439 -
# 6 Short offline Completed without error 00% 22438 -
# 7 Short offline Completed without error 00% 3 -
#10 Short offline Completed without error 00% 1 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
it should be SSD my friend
Rotation Rate: Solid State Devicefirst time i read that .. all the time i was thinking its HDD.
so then @ariq01 you are right ... should i change it to SSD ? can't edit now.
