1blu vServer 4R 1CPU/4G/60GSSD 12euro/y + .DE Domain
pr0lzpr0lz OG
edited January 2020 in Reviews
Hi all,
1blu is a german provider that offers pretty cheap vps from time to time. This time I could not resist and wanted to check them out. Price non recurring, only first 12 month for this price.
https://www.1blu.de/server/vserver/
General
They have a manual provisioning process and you need to call them to approve the order. They do not offer IPv6 as far as I know.
Edit: Also included: 1 .DE Domain for the year.
Benchmarks
Done with preinstalled centos7 image.
bench
CPU model : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
Number of cores : 1
CPU frequency : 2399.926 MHz
Total size of Disk : 59.0 GB (0.9 GB Used)
Total amount of Mem : 4096 MB (46 MB Used)
Total amount of Swap : 0 MB (0 MB Used)
System uptime : 0 days, 4 hour 14 min
Load average : 0.00, 0.06, 0.10
OS : CentOS 7.7.1908
Arch : x86_64 (64 Bit)
Kernel : 3.10.0
I/O speed(1st run) : 538 MB/s
I/O speed(2nd run) : 531 MB/s
I/O speed(3rd run) : 526 MB/s
Average I/O speed : 531.7 MB/s
Node Name IPv4 address Download Speed
CacheFly 205.234.175.175 76.5MB/s
Linode, Tokyo2, JP 139.162.65.37 4.87MB/s
Linode, Singapore, SG 139.162.23.4 5.16MB/s
Linode, London, UK 176.58.107.39 76.2MB/s
Linode, Frankfurt, DE 139.162.130.8 65.1MB/s
Linode, Fremont, CA 50.116.14.9 6.94MB/s
Softlayer, Dallas, TX 173.192.68.18 12.1MB/s
Softlayer, Seattle, WA 67.228.112.250 11.3MB/s
Softlayer, Frankfurt, DE 159.122.69.4 83.3MB/s
Softlayer, Singapore, SG 119.81.28.170 9.19MB/s
Softlayer, HongKong, CN 119.81.130.170 6.55MB/s
nench
nench.sh v2019.07.20 -- https://git.io/nench.sh
benchmark timestamp: 2020-01-22 12:49:57 UTC
`Processor: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz` `CPU cores: 1` `Frequency: 2399.926 MHz` `RAM: 4.0G` `Swap: -` `Kernel: Linux 3.10.0 x86_64`
Disks:
ploop55056 60G HDD
`CPU: SHA256-hashing 500 MB` `3.007 seconds` `CPU: bzip2-compressing 500 MB` `8.970 seconds` `CPU: AES-encrypting 500 MB` `2.678 seconds`
ioping: seek rate
min/avg/max/mdev = 39.6 us / 61.8 us / 20.9 ms / 130.3 us
ioping: sequential read speed
generated 13.3 k requests in 5.00 s, 3.24 GiB, 2.66 k iops, 664.0 MiB/s
`dd: sequential write speed` `1st run: 525.47 MiB/s` `2nd run: 460.62 MiB/s` `3rd run: 544.55 MiB/s` `average: 510.22 MiB/s`
IPv4 speedtests
your IPv4: 178.254.18.xxxx
`Cachefly CDN: 70.67 MiB/s` `Leaseweb (NL): 68.27 MiB/s` `Softlayer DAL (US): 11.36 MiB/s` `Online.net (FR): 59.34 MiB/s` `OVH BHS (CA): 14.20 MiB/s`
No IPv6 connectivity detected
`-------------------------------------------------` `nench.sh v2019.07.20 -- https://git.io/nench.sh` `benchmark timestamp: 2020-01-22 12:50:53 UTC` `-------------------------------------------------` `Wed Jan 22 11:50:00 CET 2020`
CPU cores: 1
RAM: 4.0G
Swap: -
`Disks:` `ploop55056 60G HDD`
3.345 seconds
8.477 seconds
2.600 seconds
`ioping: seek rate` `min/avg/max/mdev = 44.4 us / 63.8 us / 12.1 ms / 122.5 us` `ioping: sequential read speed` `generated 13.7 k requests in 5.00 s, 3.35 GiB, 2.75 k iops, 686.7 MiB/s`
1st run: 516.89 MiB/s
2nd run: 544.55 MiB/s
3rd run: 563.62 MiB/s
average: 541.69 MiB/s
`IPv4 speedtests` `your IPv4: 178.254.18.xxxx`
Cachefly CDN: 59.38 MiB/s
Leaseweb (NL): 88.35 MiB/s
Softlayer DAL (US): 11.60 MiB/s
Online.net (FR): 93.48 MiB/s
OVH BHS (CA): 17.38 MiB/s
yabs
# Yet-Another-Bench-Script #
# v2020-01-08 #
`Wed Jan 22 11:50:00 CET 2020` `Basic System Information:` `---------------------------------` `Processor : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz` `CPU cores : 1 @ 2399.926 MHz` `AES-NI : ? Enabled` `VM-x/AMD-V : ? Enabled` `RAM : 4.0G` `Swap : 0B` `Disk : 59G`
dd Sequential Disk Speed Tests:
| Test 1 | Test 2 | Test 3 | Avg
Write | 781 MB/s | 571 MB/s | 601 MB/s | 651.00 MB/s
Read | 2.4 GB/s | 2.1 GB/s | 2.1 GB/s | 2.20 GB/s
`iperf3 Network Speed Tests (IPv4):` `---------------------------------` `Provider | Location (Link) | Send Speed | Recv Speed` `| | |` `Bouygues Telecom | Paris, FR (10G) | 679 Mbits/sec | 890 Mbits/sec` `Online.net | Paris, FR (10G) | 625 Mbits/sec | 897 Mbits/sec` `Severius | The Netherlands (10G) | busy | busy` `Worldstream | The Netherlands (10G) | busy | 890 Mbits/sec` `wilhelm.tel | Hamburg, DE (10G) | 621 Mbits/sec | 891 Mbits/sec` `Biznet | Bogor, Indonesia (1G) | 210 Mbits/sec | 168 Mbits/sec` `Hostkey | Moscow, RU (1G) | 206 Mbits/sec | 745 Mbits/sec` `Vultr | Piscataway, NJ, US (1G) | busy bits/sec | busy bits/sec` `Velocity Online | Tallahassee, FL, US (10G) | 137 Mbits/sec | 250 Mbits/sec` `Airstream Communications | Eau Claire, WI, US (10G) | 98.7 Mbits/sec | 199 Mbits/sec` `Hurricane Electric | Fremont, CA, US (10G) | 197 Mbits/sec | 202 Mbits/sec`
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 2251
Multi Core | 2026
Full Test | https://browser.geekbench.com/v4/cpu/15161324
Have not done anything with the machine but wanted to share if someone is interested. Look at the benches yourself and see if its something of interest for you.
Please request more benchmarks if you want.
Not affiliated with the hoster in any way btw.
Thanked by (1)pxno
  • Shame its limited to 12 months, IONOS did that recurrings.
  • true, recurring would be nice.
    But if you are flexible enough you can jump to another provider after 12 month and wait for their next special offer.
    They do them quite often I think.
  • Why does the yabs report show a higher score for single core than multi core?
    Multi core benchmarks, make only sense on multi core cpu's.
    If you run multiple of these on a single core, for whatever reason, obviously since you are running multiple the average goes down by the times you run it.
    Thanked by (1)Xenos
    Seems they only allow German customers
    really? did you try?
    If thats the case that sucks. But it is possible as the website is german only, they want you to call a german number and provide only bank transfer as payment.
    Tried to sign up but only have Germany
  • vyasvyas OGRetired
    edited January 2020
    He already spent his lunch money on the cool hot Hostdoc Fr Ryzen :-)
    Thanked by (1)cybertech
    That caught me off guard :tongue: it's actually delaying my consolidation
    Et the, @cybertech ? Seems consolidating is in the air.
