If you could not use a package manager e.g. yum/apt what which OS would you choose?
InceptionHostingInceptionHosting Hosting ProviderOG
As per the title, what would be your OS of choice and why if package managers were not available due to lack of ram?
Personally I think I might be tempted to actually go for FreeBSD.
Asking because I am considering putting up some mini containers free for community members that pass certain landmarks but in order to automate the crap out of it so it is very light touch management I am only going to offer a single OS.
Thanked by (1)jureve
  • Slackware, as that's what I always used to use, or OpenBSD I think
    Thanked by (2)skorous uptime
    hmm never considered slack, might see if its even remotely possible to build a vz7 template for slack yet (ever)
    It would seem not :( :-1:
  • Why is it not possible? Does it depend on what the host kernel supports? Never really done anything with vz7 like that
    Well I mean it might be possible, but there is no EZ template package for it yet so the entire structure needs to be setup.
    VZ7 is very different, you cant just hand it a tar ball and say "off you go!"
    Currently it nativity handles:
    centos-6-x86_64-ez.noarch : Centos 6 (for AMD64/Intel EM64T) Template set
    centos-7-x86_64-ez.noarch : Centos 7 (for AMD64/Intel EM64T) Template set
    centos-8-x86_64-ez.noarch : Centos 8 (for AMD64/Intel EM64T) Template set
    debian-10.0-x86_64-ez.noarch : Debian 10.0 (for AMD64/Intel EM64T) Template set
    debian-7.0-x86_64-ez.noarch : Debian 7.0 (for AMD64/Intel EM64T) Template set
    debian-8.0-x86_64-ez.noarch : Debian 8.0 (for AMD64/Intel EM64T) Template set
    debian-9.0-x86_64-ez.noarch : Debian 9.0 (for AMD64/Intel EM64T) Template set
    fedora-23-x86_64-ez.noarch : Fedora 23 (for AMD64/Intel EM64T) Template set
    sles-11-x86_64-ez.noarch : SUSE Linux Enterprise Server 11 (for AMD64/Intel EM64T) Template set
    sles-12-x86_64-ez.noarch : SUSE Linux Enterprise Server 12 (for AMD64/Intel EM64T) Template set
    sles-15-x86_64-ez.noarch : SUSE Linux Enterprise Server 15 (for AMD64/Intel EM64T) Template set
    suse-42.1-x86_64-ez.noarch : OpenSuse 42.1 (for AMD64/Intel EM64T) Template set
    suse-42.2-x86_64-ez.noarch : OpenSuse 42.2 (for AMD64/Intel EM64T) Template set
    suse-42.3-x86_64-ez.noarch : OpenSuse 42.3 (for AMD64/Intel EM64T) Template set
    ubuntu-14.04-x86_64-ez.noarch : Ubuntu 14.04 (for AMD64/Intel EM64T) Template set
    ubuntu-16.04-x86_64-ez.noarch : Ubuntu 16.04 (for AMD64/Intel EM64T) Template set
    ubuntu-17.10-x86_64-ez.noarch : Ubuntu 17.10 (for AMD64/Intel EM64T) Template set
    ubuntu-18.04-x86_64-ez.noarch : Ubuntu 18.04 (for AMD64/Intel EM64T) Template set
    vzlinux-6-x86_64-ez.noarch : VzLinux 6 (for AMD64/Intel EM64T) Template set
    vzlinux-7-x86_64-ez.noarch : VzLinux 7 (for AMD64/Intel EM64T) Template set
    That sets up up with the structure to then build templates and gives you a structure, package manager links, networking setup scripts etc.
    example (rough)
    # ls /vz/template/centos/7/x86_64/config/app/
    cyrus-imap/   devel/        jre/          jsdk/         mailman/      mod_ssl/      mysql/        php/          postgresql/   spamassassin/ tomcat/       vsftpd/
    # ls /vz/template/centos/7/x86_64/config/os/default/
    ct2vm                distribution         mirrorlist           package_manager      post-cache           pre-cache            summary              version
    description          environment          osrelease            packages             post-install         release              upgradable_versions
    Then you need to setup the default package sets:
    # cat /vz/template/centos/7/x86_64/config/os/default/packages
    authconfig
    yum
    rpm
    wget
    vim-minimal
    nano
    initscripts
    iproute
    iptables
    iptables-services
    openssh-clients
    openssh-server
    tar
    unzip
    bzip2
    gzip
    bash
    sudo
    Then finally after that (and about 10 other steps/checks) you can actually build a deployable EZ template for OpenVZ 7
    Then you need to link the template to the network setup scripts (which dont exist for slack) so that networking actually works on container deployment.
    So It may be possible but I would probably need to copy another OS template structure, update all the repo links, scripts etc and then MAYBE it would work.
    Essentially you setup the environment for it then it self auto builds and installs the OS and generates an EZ template from the structure you hand it, you can then use that template for every container going forward or you can remove the lock file and have it do a full fresh pull of all packages from the OS repo upon every container deployment.
    Very very different to OpenVZ 6.
    I did create an initial set of EZ templates (very minimal) for everyone to use a while back: http://185.164.137.206/vz7/
    I will add centos 8 to that when I get a minute.
    Thanked by (2)isunbejo uptime
  • From that list of available templates I guess Debian would have the smallest footprint.
    I've never used it, but I heard Arch has a small footprint as well, but it's not on the list.
  • edited January 2020
    Just curious: is the container OpenVZ 7? If so, then FreeBSD wouldn't run anyway, would it?
    FreeBSD has a package manager. Indeed, if I'm not mistaken, it offers a choice of two package managers.
    How little RAM? I think that apt/Debian can manage with as little as 128 MB on KVM.
    Thanked by (1)uptime
  • ehabehab Content Writer
    i didn't read what is before this post because i am totally exhausted.
    if the main reason not to use a package manager is the resource constraints then i would go alpine.
    in fact if you look at the [ Mini root filesystem ] its so f.small 6MB one can actually just compile some app and let it run ....
    alpine
    @angstrom said: Just curious: is the container OpenVZ 7? If so, then FreeBSD wouldn't run anyway, would it?
    That right, I was hoping while typing that that beehive or whatever it was called project actually went somewhere for bsd containers, sadly it sis not.
    @angstrom said: How little RAM? I think that apt/Debian can manage with as little as 128 MB on KVM.
    1/3 core, 32MB Ram, 3GB Disk, 33GB BW.
    Fun little free box to get the creative juices flowing.
    I was working on the assumption that anything you need will have to be compiled.
  • @AnthonySmith said: 1/3 core, 32MB Ram, 3GB Disk, 33GB BW.
    Okay, yes, that's small!
  • WSSWSS Retired
    I don't think you can get a single thing to run in that with OVZ7 other than Alpine, and possibly Void, since it'll need to be able to utilize the newer kernel. If it was a KVM, I'd say OpenBSD - I've got a production service running in 64M/3G.
    @WSS said: I'd say OpenBSD - I've got a production service running in 64M/3G.
    I guess I could look at using KVM.
  • WSSWSS Retired
    Here's my stripped down kernel config to save you some time: http://bsd01.ny.bangpath.tech/TINY.txt
    Thanked by (1)Daniel
    My two cents: I would say at least 64 MB on OpenVZ 7 and at least 128 MB on KVM, otherwise it would be too much of a pain for the user ...
  • WSSWSS Retired
    Wuss.
    Wuss.
    Ain't nobody gonna compile their own kernel for a tiny VPS in 2020 -- except for you!
  • @AnthonySmith said: That right, I was hoping while typing that that beehive or whatever it was called project actually went somewhere for bsd containers, sadly it sis not.
    ?? My understanding is bhyve is more like KVM.
    Iocage is the new hot tool for Jails, and that might be closer to what you're thinking of.
    I see, it has been years since I read about it to be honest.
    Thanked by (1)FlamingSpaceJunk
    If I receive such a box, I'll run Go programs only.
    Go only depends on kernel, and doesn't even need libc.
    Go can run on any Linux distribution, as well as FreeBSD.
    To access the machine and install Go, I'll request the following to be preinstalled:
    • dropbear or other sshd
    • sftp-server
    • tar
    • xz
    • git (good to have)
    Everything else, I'm going to delete as they waste RAM.
  • arch linux, if you are okay with a rolling release model as base OS. If arch, then pacman is the obvious choice.
    Other options:
    • lxc/runc/docker containers through podman
    • docker-swarm
    • k8s
  • I'm surprised no one mentioned gentoo
  • WSSWSS Retired
    edited January 2020
    Kind of hard to compile a pgcc kernel with 32MB of RAM.
  • Second @WSS, would run Alpine. Have a few single purpose tiny VMs (usually LXC) and am running Alpine w/o issues - but when I say tiny I'm talking 128/256MB not 32, lol.
    what are 3GB of disk for? =]
    That page is really a blast from the past :)
    @comi said: what are 3GB of disk for? =]
    This entire forum uses less than that :)
    No, it was a bad joke that it's tough to compile stuff on 32MB, but you can swap it out to 3GB disk, since you compile less often than use yum/apt.
    I know it's ridiculous, I was trying to be funny.
    Thanked by (1)Amitz
  • I remember compiling 2.0.x kernels on a i486 ThinkPad with 16 MB of RAM. It wasn't super fast, but not painfully slow, either. :)
    Bah. 1.9 kernel compiles on 386 hardware ran overnight! :)
    Edit: I think it was after around the 1.9 series that I moved over to Debian Bo, which was the first time I had a 2.0 series kernel. Dang that makes me feel old.
    Now that I think about it, I would probably treat the container like Linux from Scratch, and just drop binaries and libraries as needed. Everything would get compiled on a build server, and then get copied over.
    The little container would probably be more useful with a build system attached to it.
