If you could not use a package manager e.g. yum/apt what which OS would you choose?
2»
  • alpine linux / apk
  • @rajprakash said:
    Bah. 1.9 kernel compiles on 386 hardware ran overnight! :)
    Edit: I think it was after around the 1.9 series that I moved over to Debian Bo, which was the first time I had a 2.0 series kernel. Dang that makes me feel old.
    Well, you win. I never ran Linux on a i386! :)
  • Debian minimal, or if not feasible, Alpine Linux as a second choice.
    Based on available automation it’s looking like a minimal Debian image is the way to go.
    The containers would be NAT/v6?
    yup
    Infact I have decided I am going to get started on that today.
    The current VZ7 Debian template I have is about as minimal as possible already :)
    Included packages:
    #debian10
    apt
    openssh-client
    openssh-server
    wget
    nano
    iputils-ping
    Thanked by (1)jureve
    So having actually played with this, and experimented with real world use, no package manager in 2020 is not going to be an experience anyone would be interested, it took me an hour to satisfy the dependencies of gcc and that was using dpkg.
    Looks like the best combo is 32mb ram and 64mb vswap, just about allows apt to run on a debian 10 container.
  • WSSWSS Retired
    That would be perfectly adequate with Alpine, you know...
    The issue is I cannot create/maintain an alpine template for vituozzo 7.
    maybe I could make an auto conversion script and inject it in to the template.
    edited February 2020
    With 32MB even alpine struggles it seems on vz7.
    48MB however seems to be the sweet spot.
    This might just work out.
  • WSSWSS Retired
    If you build it using the virt-build, and just run with your VZ7 kernel it should be good enough for anyone who actually wants to do something with it.
  • WSSWSS Retired
    This will inject on VZ6; might need to change to get it to bootstrap with 7. Not a fan of how it's done, but evidently it works.
    https://gist.github.com/trimsj/c1fefd650b5f49ceb8f3efc1b6a1404d
    nano
    I want to apt purge nano but there's no apt.
    yep, tested it on vz7 works fine.
    I will try and find some time tomorrow, I was going to be fence posting but it looks like its going to rain all day.
    I should just be able to extract the hds file from the debain 8 tar.lz4 template (the smallest one) and ploop mount it and insert a first boot script to run that, it takes about 2 - 3 minutes to run MAX so should work fine.
  • WSSWSS Retired
    Ploop is still a thing in 7? I thought both that and SymFS were gonna go to the dump.
    I've built an OVZ Alpine container with marginal effort before. Just be aware it can't sort properly so it's going to install 3.9
    nope they stuck with ploop, I don't expect it to go anywhere soon.
    Something to do with the opimised ext4 for CS for virtuozzo 7 cluster nodes.
    Personally I truly hate it but it sure is a hell of a lot less problematic than it used to be.
    simfs is a thing of the past.
  • WSSWSS Retired
    Nothing quite like more corrupt systems.
