Is this Normal ?
Hola,
Recently I purchased an Dedi from Oneprovider.
Basic entry server - Atom C2338 (2cores)
Disk - SSD (128GB)
CPU model : Intel(R) Atom(TM) CPU C2338 @ 1.74GHz
Number of cores : 2
CPU frequency : 1750.071 MHz
Total size of Disk : 116.5 GB (1.9 GB Used)
Total amount of Mem : 3941 MB (78 MB Used)
Total amount of Swap : 1048 MB (0 MB Used)
System uptime : 1 days, 8 hour 30 min
Load average : 0.00, 0.00, 0.00
OS : Ubuntu 18.04.4 LTS
Arch : x86_64 (64 Bit)
Kernel : 4.15.0-88-generic
I/O speed(1st run) : 35.0 MB/s
I/O speed(2nd run) : 51.2 MB/s
I/O speed(3rd run) : 54.6 MB/s
Average I/O speed : 46.9 MB/s
Node Name IPv4 address Download Speed
CacheFly 205.234.175.175 73.1MB/s
Linode, Tokyo2, JP 139.162.65.37 4.29MB/s
Linode, Singapore, SG 139.162.23.4 3.04MB/s
Linode, London, UK 176.58.107.39 16.6MB/s
Linode, Frankfurt, DE 139.162.130.8 28.3MB/s
Linode, Fremont, CA 50.116.14.9 4.80MB/s
Softlayer, Dallas, TX 173.192.68.18 13.1MB/s
Softlayer, Seattle, WA 67.228.112.250 11.0MB/s
Softlayer, Frankfurt, DE 159.122.69.4 29.1MB/s
Softlayer, Singapore, SG 119.81.28.170 8.78MB/s
Softlayer, HongKong, CN 119.81.130.170 7.33MB/s
So, the Disk speeds are normal ?
I mean, for this Trash server whethever is it good or bad ?
  • This isn’t normal. I used to have one of those with a 256GB SSD. Disks speeds weren’t especially good, but still around 250-300 MB/s.
    Oh I see. Must be a bad drive then?
    Probably 1 of 2 things, they have the port set to Sata 2 or the disk is very old and almost dead, or a mix of both.
    Thanked by (1)deepak_leb
  • edited February 2020
    So, "Is this Normal", to not use a decent thread title? :#
    bench.sh test on HDD version, just for comparison.
    Number of cores : 2
    CPU frequency : 1166.667 MHz
    Total size of Disk : 849.4 GB (47.5 GB Used)
    Total amount of Mem : 3931 MB (662 MB Used)
    System uptime : 15 days, 13 hour 26 min
    Load average : 0.87, 0.79, 0.45
    OS : Debian GNU/Linux 10
    Kernel : 5.3.18-1-pve
    I/O speed(1st run) : 107 MB/s
    I/O speed(2nd run) : 110 MB/s
    I/O speed(3rd run) : 109 MB/s
    Average I/O speed : 108.7 MB/s
    CacheFly 205.234.175.175 52.1MB/s
    Thanked by (2)deepak_leb AlSwearengen
    Number of cores : 2
    Am not a techie nor a good English speaker boss ! ?.
    But can learn, if you teach so ;)
    Disk seems failing & they take huge time to replace though. ?.
    Anyway no use of pushing them.
    For the price it seems okay.
    These are dev & fun project purpose right ? @AnthonySmith
    Number of cores : 2
    At least it wasn't "how to x" without a question mark, making the thread look like a how-to guide..
    Thanked by (1)AlwaysSkint
    Noted boss
  • I would install smartmontools and check the SMART data on it, if they have it enabled in the BIOS. Should be able to check lifetime writes or lifetime remaining. Those speeds seem quite low.
