Recommend a monitor tool
I am thinking about a (let's say a simple) all-in-one solution for monitoring:
- sshd login: message on login (who, ip+location ...). Everyday/-hour send report failed/successful login.
- Performance: avg load message after x-hour. Alert on peak load and which process.
- Other metrics but the 2 above are what I really want now.
And most important: message sending using some kind of message platform, not SMS or email. Boxcar seem nice
So my dudes, do you know any available name that does the job or have suggestions that can help me?
nixstats
tks, found out that hetrixtools also has node monitoring
I like that Hetrix is offering them, but I've not found/tried to integrate it with Slack yet.
https://docs.hetrixtools.com/slack-integration/
+1 for Hetrix. I’ve been very impressed with the accuracy and timeliness of their monitoring.
Hetrixtools is very good
