Recommend a monitor tool
I am thinking about a (let's say a simple) all-in-one solution for monitoring:
- sshd login: message on login (who, ip+location ...). Everyday/-hour send report failed/successful login.
- Performance: avg load message after x-hour. Alert on peak load and which process.
- Other metrics but the 2 above are what I really want now.
And most important: message sending using some kind of message platform, not SMS or email. Boxcar seem nice ![]()
So my dudes, do you know any available name that does the job or have suggestions that can help me?
nixstats
tks, found out that hetrixtools also has node monitoring
I like that Hetrix is offering them, but I've not found/tried to integrate it with Slack yet.
https://docs.hetrixtools.com/slack-integration/
+1 for Hetrix. I’ve been very impressed with the accuracy and timeliness of their monitoring.
Hetrixtools is very good
